50g group photo
50g
Archive for 50g.
Prospective buyer questions: hard case? Linux? Solar recharge? AC power?
2009-03-02 by David Bush
I am considering a 50g purchase. Has anyone here used the hard
protective shell advertised at
http://www.calculatorsource.com/ob-3000.html
There is a link on that product page to a clear "soft" case which
allows operation while in the case. How would you compare this soft
case to a sealable plastic baggie?
The HP website offers a ROM upgrade to version 92. My OS is Kubuntu
Linux 8.10. Does the supplied "connectivity kit" software work under
Wine? Would you recommend I get an SD card reader/writer for my PC?
is 2 GB the most memory in an SD card that the 50g can handle? Are
there any specific dealers for an SD card that you would recommend?
Is any rechargeable battery pack recommended? Is there a solar powered
recharger which will recharge said battery pack, if one exists?
Has anyone developed a power supply to run off of standard 110V AC for
operation without batteries?
Thanks!
Re: Prospective buyer questions: hard case? Linux? Solar recharge? AC power?
2009-03-02 by Tim Wessman
Nope. It won't be fun to use though. If you are looking to use it for
something rugged you should get a case from http://pssllc.com, but the
case itself will run about 100$. It also gives you the ability to run
AA bateries, run it over with a truck, shoot it with a .22 cal rifle,
submerge it, etc. It isn't something to "protect" a calculator in your
bag.
You don't really need any additional case. It comes with a slip cover
and you remove it to use the calc.
That is a mislabel. The latest ROM is 2.09.
> My OS is Kubuntu
While you can use a connectivity kit, and there is an open source one
that runs on OSX and linux, don't bother. The SD card is much easier
to use and you will have less problems. Just get a card reader. They
can be had for a few dollars at most.
Yes. You don't really need that much memory though. Any SD card maker
is fine. Don't buy one of the "super ultra high speed ones" as they
won't give any performance benefit. The regular ones are plenty fast.
Yes. AAA recharagables work great, but they do drain by themselves
while just sitting (all standard rechargables do) so if you only use
it a little bit a month, regular AAAs are the way to go.
Nope. You could find a solar powered AAA charger, but it would be
expensive.
It runs off the miniUSB connector. Any AC->USB adapter plus the
standard mini USB cable will work fine.
TW
Re: [50g] Re: Prospective buyer questions: hard case? Linux? Solar recharge? AC power?
2009-03-02 by Marcus Fazzi (Anunakin)
You can install Conn4x on Linux using Wine
I here on Gentoo Linux 32bit/2008.0 with kernel 2.6.28 and Wine 1.1.11
WINEPREFIX=~/hp50win wine /media/NARIKO/SoftHP/Conn4x_English.exe
ln -s /dev/ttyUSB2 ~/hp50win/dosdevices/com1
Wine creates a Icon on Desktop and on Kmenu, or Gnome Menu
You USER need to stay on UUCP group...
This works very well here...
2009/3/1 Tim Wessman <timwessman@...>
bag.
> My OS is Kubuntu
expensive.
TW
Marcus Fazzi
オープンソースコード いきかた!
http://anunakin.blogspot.com/
http://www.vivaphp.net
