I think some of the internal functions use the radian
mode only, so it switches whether you like it or not
and there's not much you can do to prevent that.
You can assign a key (or create a custom menu) to
toggle degree/radian back & forth. In either case, you
can use something like the following code to do the
toggle.
IF -17. FS?
THEN -17. CF
ELSE -17. SF
--- In
50g@yahoogroups.com, "benatzert" <benatzert@...>
wrote:
> Dear HP50G-Group,
> i have one problem and could'nt find a solution, yet.
> I love to use my calc in exact-mode, but sometimes
because of my
> calculations (some real-number instead of fractions)
i'm asked to
> switch into approximation-mode. The mode itself is no
problem, but it
> allways changes my Angle-System from "Degrees" into
"Radians" and i
> have to change it back everytime. Because of the
different Angle my
> workaround at the moment is to change any real into a
fraction...and
> stay in exact-mode but maybe there is just one
little option i've
> missed ;-)
> It would greatly increase my workspeed if someone has
a solution for me.
> Sincerly Ben
