50g group photo
50g
Archive for 50g.
HOW TO..... ON THE HP50G
2009-02-18 by J
Hello Group!! It was a great idea to have a group like this. I have a question: HOW DO I GO BACK TO THE HOME MENU when I am stuck on some other manu? To make it clear: I want to find which key or combination will clear the screen and put me on the home menu. I often get stuck and spend half hour to get back to a clean menu with the 7 numbers on the left and start over. There has to be a way. On the Ti-84 I used to have you could always go back to "home" very easily. Please help!
Re: [50g] HOW TO..... ON THE HP50G
2009-02-18 by pDale Campbell
Well, I'm sure someone will post a quick-key combo to do it, but in the mean-time, you can press {<-},{FILES (APPS)} to bring up a directory tree. Use the up-arrow to move the highlight to the HOME dir, then press {CHDIR (F1)}.
pDale Campbell
2009-02-18 by Ben Atzert
Hello, there is another way to quickly reach the {Home} Directory.
Just left-shift "VAR" [UPDIR]
repeat this step until your screen says {Home} (Second line top-left)
To reach the stack-screen (the one with the numberd lines) just use
"Cancel" (it's the ON-Key, bottom-left) that's works fine for me.
I wish you good luck and great results with your HP50G ;-)
Sincerly Ben Atzert
> {CHDIR (F1)}.
> pDale Campbell
Re: HOW TO..... ON THE HP50G
2009-02-18 by vincentgoudreault
Just execute the "HOME" command. Type HOME using the alpha mode, and
press ENTER.
Beats looking for it under various menus.
CBVG
2009-02-18 by shristov
To return to HOME directory:
* press and HOLD left shift key
* press UPDIR.
Sinisa
----- Originalna poruka -----
Pošiljalac: pDale Campbell <pdalec@...>
Datum: Sreda, Februar 18, 2009 13:35
Tema: Re: [50g] HOW TO..... ON THE HP50G
Primalac: 50g@yahoogroups.com
Cc: professorman40@...
(F1)}.
> pDale Campbell
> <BR>> <!-- #ygrp-mkp{ border: 1px solid #d8d8d8; font-family: Arial; margin: 14px 0px; padding: 0px
14px; } #ygrp-mkp hr{ border: 1px solid #d8d8d8; } #ygrp-mkp #hd{ color: #628c2a; font-size: 85%; font-
weight: bold; line-height: 122%; margin: 10px 0px; } #ygrp-mkp #ads{ margin-bottom: 10px; } #ygrp-mkp
.ad{ padding: 0 0; } #ygrp-mkp .ad a{ color: #0000ff; text-decoration: none; } --><BR>>
> <BR>> <!-- #ygrp-sponsor #ygrp-lc{ font-family: Arial; } #ygrp-sponsor #ygrp-lc #hd{ margin: 10px 0px; font-
weight: bold; font-size: 78%; line-height: 122%; } #ygrp-sponsor #ygrp-lc .ad{ margin-bottom: 10px; padding:
0 0; } --><BR>>
> <BR>> <!-- #ygrp-mlmsg {font-size:13px; font-family: arial,helvetica,clean,sans-serif;*font-
size:small;*font:x-small;} #ygrp-mlmsg table {font-size:inherit;font:100%;} #ygrp-mlmsg select, input,
textarea {font:99% arial,helvetica,clean,sans-serif;} #ygrp-mlmsg pre, code {font:115% monospace;*font-
size:100%;} #ygrp-mlmsg * {line-height:1.22em;} #ygrp-text{ font-family: Georgia; }
#ygrp-text p{ margin: 0 0 1em 0; } dd.last p a { font-family: Verdana; font-
weight: bold; } #ygrp-vitnav{ padding-top: 10px; font-family: Verdana;
font-size: 77%; margin: 0; } #ygrp-vitnav a{ padding: 0 1px; }
#ygrp-mlmsg #logo{ padding-bottom: 10px; } #ygrp-reco { margin-bottom: 20px; padding: 0px;
} #ygrp-reco #reco-head { font-weight: bold; color: #ff7900; }
#reco-category{ font-size: 77%; } #reco-desc{ font-size: 77%; } #ygrp-vital a{
text-decoration: none; } #ygrp-vital a:hover{ text-decoration: underline; }
#ygrp-sponsor #ov ul{ padding: 0 0 0 8px; margin: 0; } #ygrp-
sponsor #ov li{ list-style-type: square; padding: 6px 0; font-size: 77%; }
#ygrp-sponsor #ov li a{ text-decoration: none; font-size: 130%; } #ygrp-
sponsor #nc{ background-color: #eee; margin-bottom: 20px; padding: 0 8px; }
#ygrp-sponsor .ad{ padding: 8px 0; } #ygrp-sponsor .ad #hd1{ font-family:
Arial; font-weight: bold; color: #628c2a; font-size: 100%; line-
height: 122%; } #ygrp-sponsor .ad a{ text-decoration: none; } #ygrp-sponsor .ad
a:hover{ text-decoration: underline; } #ygrp-sponsor .ad p{ margin: 0;
} o{font-size: 0; } .MsoNormal{ margin: 0 0 0 0; } #ygrp-text tt{ font-size:
120%; } blockquote{margin: 0 0 0 4px;} .replbq{margin:4} dd.last p span { margin-right: 10px; font-
family: Verdana; font-weight: bold; } dd.last p span.yshortcuts { margin-right: 0; } div.photo-title a, div.photo-
title a:active, div.photo-title a:hover, div.photo-title a:visited { text-decoration: none; } div.file-title a, div.file-title
a:active, div.file-title a:hover, div.file-title a:visited { text-decoration: none; } #ygrp-msg p { clear: both;
padding: 15px 0 3px 0; overflow: hidden; } #ygrp-msg p span { color: #1E66AE; font-weight: bold; }
div#ygrp-mlmsg #ygrp-msg p a span.yshortcuts { font-family: Verdana; font-size: 10px; font-weight:
normal; } #ygrp-msg p a { font-family: Verdana; font-size: 10px; } #ygrp-mlmsg a { color: #1E66AE; }
div.attach-table div div a { text-decoration: none; } div.attach-table { width: 400px; } --><BR>>
* press UPDIR.
Sinisa
(F1)}.
> pDale Campbell
0 0; } --><BR>>
2009-02-18 by Don Hart
The part about getting to the home directory has already been answered. But, is clearing the screen a separate question? The CLEAR command will do that; it's right-shift + clear on the hp49 & probably the same on the 50g.
> From: J <professorman40@...>
> Subject: [50g] HOW TO..... ON THE HP50G
> To: 50g@yahoogroups.com
> Date: Wednesday, February 18, 2009, 4:09 AM
2009-02-19 by matthiasrampke
Hi J,
I think we'll have to check some terminology here.
I assume with "a clean menu with the 7 numbers on the left" you mean
the stack display. If your calc is in RPN mode you can always get
there by pressing ON (repeatedly if needed). You can clear out any
numbers/items there with CLEAR (RSHIFT <=).
The HOME directory is the basic place to put variables etc. On the HP
calcs the Memory is organized in a Drive/Folder structure, much like
on a desktop computer. You can have a look at it with the file manager
(FILES).
In general: with the HP49(+) HP introduced some features to help
novice users, namely Algebraic mode and Choose Boxes.
The first everybody should abandon immediately. The HP command set and
interface are just not built for it, and it will slow anybody down.
Learning RPN is a matter of minutes, mastering it a matter of
practice. When you see it creep into how you view formulae (i.e.
inside-out), you will know you're there. It's worth it.
Choose Boxes (i.e. the full-screen menus popping up all the time) are
a great way of learning your way around the (admittedly sometimes
confusing) menu structure. Once you get to know which-is-which and
what-is-where you can speed up your work considerably by changing flag
117 to Soft MENU. Then most menus will only use the keys A–F (try it
out, you'll see). They no longer obscure the stack, allowing you to
work much more fluently, especially if you often need several items
(units, commands…) from the same or "close" menus.
Have fun, M.
PS: please DON'T YELL!!1!
Re: [50g] Re: HOW TO..... ON THE HP50G
2009-02-19 by Fred Hoeldtke
You need a private teacher as  you are very lost.  Are there any schools, math lessons or programming
groups near you.   MY SUGGESTION IS LEARN ON AN OLD HP48G PERHAPS FROM YAHOO OR OTHER ,  GET THE BOOKS AND 98 PERCENT AT
YOUR LEVEL WILL APPLY.
Sent: Thursday, February 19, 2009 10:02 AM
Subject: [50g] Re: HOW TO..... ON THE HP50G
Hi J,
(FILES).
Have fun, M.
Internal Virus Database is out of date.
Checked by AVG - http://www.avg.com
Version: 8.0.176 / Virus Database: 270.9.17/1847 - Release Date: 12/13/2008 4:56 PM
2009-02-20 by mike
To get back to the home menu you can simply type alpha alpha home
that's turning on the alpha lock and just typing home.
cheers Mick
> From: matthiasrampke
> Hi J,
> (FILES).
> 117 to Soft MENU. Then most menus will only use the keys A-F (try it
> (units, commands.) from the same or "close" menus.
> Have fun, M.
12/13/2008 4:56 PM
Matrix manipulation
2009-02-20 by pDale Campbell
I have looked and looked to no avail...  Can someone tell me how, in a user RPL program, I can recall the matrix entry at cell [2,5] into the X register?  How about storing X into cell [3,5]?
pDale Campbell
Re: Matrix manipulation
2009-02-20 by tranka2010
Use GET:
3: [[ matrix ]]
2: {2,5}
1: GET
Use PUT
4: [[ matrix ]]
3: {2,5}
2: X <-- value
1: GET
The Advanced User's Guides at http://www.hpcalc.org/details.php?id=2998
or http://h10032.www1.hp.com/ctg/Manual/c00554621.pdf
have all the UserRPL commands explained in great detail.
> pDale Campbell
Re: [50g] Re: Matrix manipulation
--- On Fri, 2/20/09, tranka2010 <pepin_torres@...> wrote:
> --- pDale Campbell <pdalec@...> wrote:
> > [How can I] recall the matrix entry at cell
> Use GET: [...]
> Use PUT [...]
Thank you!!!
pDale Campbell
