50g group photo
50g
Archive for 50g.
Complex Roots
Complex Roots
2008-12-31 by joecolannino
Does anyone have a program written for the HP 50G that will give all
complex roots of a number? For example,the cube roots of -1 are
{[1+sqrt(3)]/2, -1, and [1-sqrt(3)]/2 } but the HP 50G will give only
the first. Trying to evaluate the cube root of 2+11i it chokes
altogether though the answers are clearly {2+i, -1.866+1.232i
(approx), -0.1340-2.232i (approx)}.
Joe
Re: [50g] Complex Roots
2009-01-01 by Don Hart
Make sure you're in complex & approx modes, then SOLVEX the equation x^3 + 1 = 0
For the other case, SOLVEX the equation x^3-2-11*i=0
--- On Wed, 12/31/08, joecolannino <joecolannino@...> wrote:
> From: joecolannino <joecolannino@...>
> Subject: [50g] Complex Roots
> To: 50g@yahoogroups.com
> Date: Wednesday, December 31, 2008, 1:15 PM
> give all
> -1 are
> will give only
> chokes
> -1.866+1.232i
> Joe
RE: [50g] Complex Roots
2009-01-01 by Jeremy Hawdon
Here is a little program for finding the  approximate nth roots of a Gaussian integer:
%%HP: T(3)A(R)F(.);
\<< OVER ABS OVER XROOT UNROT SWAP ARG 0 PICK3 1 -
  FOR j 2 \pi * j * OVER + i * PICK3 / EXP 4. PICK * 4. ROLLD
  NEXT DROP NIP \->LIST
  \<< \->NUM
  \>> MAP
It takes z and n from the stack and returns a list of values for z^ (1/n)
Jeremy
From: 50g@yahoogroups.com [mailto: 50g@yahoogroups.com ] On Behalf Of joecolannino
Sent: 31 December 2008 21:16
{[1+sqrt(3)] /2, -1, and [1-sqrt(3)]/ 2 } but the HP 50G will give only
Joe
2009-01-01 by Joe Colannino
Don, that was really helpful.  It will be easy enough to write a program to do this automatically.  When I do so, I’ll share it with the group.  Thanks again!
Joe
From: 50g@yahoogroups.com [mailto:50g@yahoogroups.com] On Behalf Of Don Hart
Sent: Wednesday, December 31, 2008 10:56 PM
Subject: Re: [50g] Complex Roots
--- On Wed, 12/31/08, joecolannino <joecolannino@ sbcglobal. net> wrote:
> From: joecolannino <joecolannino@ sbcglobal. net>
> To: 50g@yahoogroups. com
> give all
> -1 are
> will give only
> chokes
> -1.866+1.232i
> Joe
Re: Complex Roots
2009-01-01 by Juan C.
Hello Joe, if you want to get the n root of a number b, you have to
solve the equation x^n-b=0, to solve this you have to use the command
PROOT which needs as argument a vector with the coefficients, in this
case [1 0...0 -b] and you get back a vector with all the roots, How
many zeros do you need in your vector? n-1 zeros. If you enter first b
and then n, your program can be something like this:
-> n
<< 1 SWAP NEG
2 n
START
0 SWAP
NEXT
n 1 + ->ARRY PROOT
b can be real or complex and n an integer grater than 1.
Everybody in the group have a nice year.
Re: Complex Roots
2009-01-03 by Don Hart
Also note that if you've set the 'exact' mode, the
solution to x^2+1=0 will give the results in an algebraic
form.
And you don't have to have the '=0' part. I put it in to
make it easier to see what's going on.
--- In 50g@yahoogroups.com, "Joe Colannino"
> do this automatically. When I do so, I'll share it
> again!
> Joe
> _____
> = 0
> <mailto:joecolannino%40sbcglobal.net> sbcglobal.net>
> sbcglobal.net>
> > To: 50g@yahoogroups. <mailto:50g%40yahoogroups.com>
com
that will
> > give all
roots of
> > -1 are
50G
> > will give only
2+11i it
> > chokes
> > -1.866+1.232i
> > Joe
