As far as I can tell my HP50g will always use the value a variable has
on a parent directory if there is no value set for it on the current
directory. How can I make it totally ignore whatever value a variable
has on its parent directories?
I don't think there's a way to turn off this 'feature'. You just have to become diligent in deleting variables when you're thru with them. Or just use the HOME directory or create a scratch directory right below the HOME directory.
Come to think of it, didn't someone recently post a program to delete vars from all higher directories? Maybe that will work for you.
> From: usedwhenneeded <usedwhenneeded@...>
> Subject: [50g] Stop 50g from assuming for a certain variable the value it had on a parent direc
> To: 50g@yahoogroups.com
> Date: Thursday, September 25, 2008, 2:44 PM
> variable has
> the current
> a variable
> Thanks for caring.
