flag settings
2008-08-14 by Rachelle
Archive for 50g.
2008-08-16 by Don Hart
--- On Thu, 8/14/08, Rachelle <rspencer1005@...> wrote:
> From: Rachelle <rspencer1005@...>
> Subject: [50g] flag settings
> To: 50g@yahoogroups.com
> Date: Thursday, August 14, 2008, 10:42 AM
> When I recall the current flag settings for my calculator, I
> get a
> series of numbers and letters. Can anyone tell me how these
> correspond
> to which flags are set? Will the current flag settings
> apply with the
> calculator in user mode?
> Thanks !
2008-08-18 by Rachelle
--- In 50g@yahoogroups.com, Don Hart <ddhart1@...> wrote:
> Hey Rachelle,
> When you execute the RCLF command you get a list of 2 "binary"
integers. The 1st one is the state of the system flags, the 2nd is
the user flags. They are supposed to be a direct mapping of the flag
settings, 1 if the flag is set, 0 if not, with flag -1 (or 1,
respectively) being the least significant (rightmost) digit. To see
these integers as only 1's & 0's, do MTH -> BASE -> BIN. That will
switch your display from the HEX mode you apparently have it in.
> Unlike the flag browser, all of the flags are represented, so you
can see, for instance, the state of flag 4 or 5 etc. Some of the
settings need more than one bit, the 3 way toggle between RECT,
CYLIN, & SPHERE is one of them, if I recall correctly.
> If you do a RCLF and then store the list under a name such as
MYFLAGS, you can then recall the list to the stack and do a STOF to
restore the state of the flags. You can keep a copy of your favorite
flag settings in MYFLAGS in case you want to experiment with the
flag settings and then return to where you were before you made any
changes.
> The flags should be the same if you're in user mode except for the
flag that sets the user mode.
> Hope that helps
> > get a
> > correspond
> > apply with the
> > Thanks !
> > Yahoo! Groups Links
2008-08-18 by Don Hart
> Subject: [50g] Re: flag settings
> Date: Monday, August 18, 2008, 3:31 AM
> Do I need to save the flag settings in the format they are
> in now,
> or in binary?
> Thanks so much !
> Rachelle
> wrote:
> > Hey Rachelle,
> "binary"
> 2nd is
> the flag
> 1,
> digit. To see
> it in.
> represented, so you
> of the
> RECT,
> such as
> STOF to
> favorite
> with the
> made any
> changes.
> mode except for the
> > Hope that helps
> calculator, I
> > > get a
> how these
> > > correspond
> settings
> > > apply with the
> > > Thanks !
> > > Yahoo! Groups Links
