50g group photo
50g
Archive for 50g.
hp programmimg book
hp programmimg book
2008-07-31 by alanthegringo
I used to have a HP41C, and bought a book from a company in Orgeon.
It was written like with cartoons, and verrry easy to understand.
Does anyone remember this company, and do they still exist?
The book was in a spiral bound format.
Re: [50g] hp programmimg book
2008-07-31 by Alan Golightly
This was the book; wish they made one for the 50G!   Easy Course in Programming the Hp-41 (Easy Course Series) (Paperback)by Ted Wadman (Author), Chris Coffin (Author)
--- On Thu, 7/31/08, alanthegringo <alanthegringo@...> wrote:
Subject: [50g] hp programmimg book
To: 50g@yahoogroups.com
Date: Thursday, July 31, 2008, 7:52 AM
2008-08-01 by Fatih Can
I'd definitely buy one!!!
--- On Thu, 7/31/08, Alan Golightly <alanthegringo@...> wrote:
Subject: Re: [50g] hp programmimg book
Date: Thursday, July 31, 2008, 5:56 AM
To: 50g@yahoogroups. com
polar to rectangular
2008-08-04 by Alan Golightly
How do you exchange rect to polar and back?
just change modes?
Date: Thursday, July 31, 2008, 10:51 PM
Re: [50g] polar to rectangular
2008-08-04 by Edward Wingate
I have to do this a lot, and on the 48 it was simple.  On the 50g it isn't.  The options are to change modes, or to install the Keyman and OT49+ libraries and then use the Topkeys+ program to assign rectangular/polar/spherical to left-shift-hold long-press SPC.
The second option is a lot simpler than it sounds, and makes life easy. You also get deg/rad on left-shift-hold short-press SPC.
There may be other options, but those are the ones I know of.
EKW
just change modes?
2008-08-04 by Don Hart
In case you've had trouble finding the menu and assuming the 50 is the same as the 49, you can try...
PRG -> NXT -> MODES -> ANGLE
With the coordinate on the stack, pressing RECT or CYLIN will make switch accordingly.
--- On Sun, 8/3/08, Alan Golightly <alanthegringo@...> wrote:
Subject: [50g] polar to rectangular
Date: Sunday, August 3, 2008, 6:56 PM
just change modes?
thanks,
I think I am liking my old HP15C a LOT! :P
--- On Sun, 8/3/08, Don Hart <ddhart1@...> wrote:
Subject: Re: [50g] polar to rectangular
Date: Sunday, August 3, 2008, 10:29 PM
just change modes?
2008-08-05 by Don Hart
As someone has already mentioned, you can assign these commands to a key so they'll be more easily executed. The program Keyman at www.hpcalc.org helps you configure your keyboard or you can do something like this...
Put <<CYLIN>> on the stack
Put 21.1 on the stack (that's the key at row 2 column 1 of the keyboard. You can pick another key to assign to)
Press (or just enter) ASN & press "enter"
Put <<RECT>> on the stack
Put 21.2 on the stack (that's the key at row 2 column 1 of the keyboard. You can pick another key to assign to)
Then, with the the coordinate on the stack, press the key at 21 to convert to polar. Or press left shift and then the key at 21 to convert to rectangular (the .2 part in 21.2 means left shift).
The key at 21 on the hp49 is the "apps" key I suspect it's the same on the hp50.
Oh, and you have to turn on user mode (lefthift alpha) for the new key assignments to work.
You can read up on things like ASN, RCLKEYS, STOKEYS etc.
That's just one way of doing it. You can read up on CUSTOM menus for another way to customize your hp50.
Have fun.   :)
Date: Monday, August 4, 2008, 5:54 AM
thanks,
just change modes?
Re: polar to rectangular
2008-08-10 by ramwriter3k
Wow! I didn't get any of that...sorry. I can switch modes
(rectangular, polar, spherical); is there a way to CONVERT polar
coordinates to rectangular - quick and easy? (i.e. theta = pi over 3
to (x,y) push a button(or two) and bingo!)
Do I have to upload something to my 50g to do it?
Scott
Re: [50g] Re: polar to rectangular
2008-08-10 by Don Hart
You can get to the commands that do that by pressing, in order, PRG -> NXT -> MODES -> ANGLE
Then, with the coordinate on the stack, press RECT or CYLIN will make switch accordingly. This will convert ALL coodinates on the stack no matter what level they're on. You don't have to do anything special other than navigate to the commands.
You can also assign those commands to almost any key on the keyboard as outlined in message #487. Then they'll be directly accessible without any such navigation.
Does that clear it up? If not, please post a question more spacific as to where you're having a problem.
--- On Sun, 8/10/08, ramwriter3k <attkbeast@...> wrote:
> From: ramwriter3k <attkbeast@...>
> Subject: [50g] Re: polar to rectangular
> Date: Sunday, August 10, 2008, 3:45 PM
> modes
> polar
> pi over 3
> Thanks,
> Scott
RE: [50g] Re: polar to rectangular
2008-08-11 by Jeremy Hawdon
If your calculator is in rectangular mode. You can enter a complex number in polar form : ( r alpha right-shift 6 theta enter , and it will be immediately converted.
From: 50g@yahoogroups.com [mailto: 50g@yahoogroups.com ] On Behalf Of ramwriter3k
Sent: 10 August 2008 23:46
Scott
2009-06-11 by tony
Does anyone know how to switch function between polar to rectangular and rectangular to polar using the softkeys or a better way then going into mode and changing it this way?
Also is there a softkey or shortcut for the angle symbol(polar),such as the one on the hp 48?
Thnak you
Tony
2009-06-11 by rickwendel763242
I spent the last week and a half reading 1000 pages of broken, illiterate nonsense. Everything is trial and error with the HP50G. I've owned the calculator for over two years and the idiots at HP still can't hire a 9th grader to write a useful manual for them. The only way I've found to convert from polar to rectangular and vise versa is to write a program which will appear on a soft key in the directory you choose. I just started trying to figure out how to program, but programming is twice as ridiculous as figuring out the conversion. The commands for inputing a variable are two lines long and make no sense. Then the variable has to be purged afterwards... Absolutely idiotic...
2009-06-11 by Don Hart
There are different ways to toggle the polar mode. You can assign a program like...
<< IF -16 FS? THEN -16 CF ELSE -16 SF END >>
...to a little used key
Or you can put it into a custom (CST) menu, which is what I did.
Since it sounds like you're a former 48 user, I've attached a custom menu I wrote when I first got my 49 -- should work on a 50. It made my transition from the 48 easier. Rename it to CST and store it in the HOME directory. Press CUSTOM on the keyboard to use it. The polar toggle is under the TOGGLE soft key. Modify as you see fit.
The angle symbol is at [ALPHA] [RIGHT-SHIFT] 6
--- On Wed, 6/10/09, tony <anthonypicariello@...> wrote:
> From: tony <anthonypicariello@...>
> Date: Wednesday, June 10, 2009, 6:55 PM
> Thnak you
> Tony
>     mailto:50g-fullfeatured@yahoogroups.com
If you use local variables, you don't have to purge them. They're never stored (STO). Or you can PURGE the stored vars in your program right before it ends.
And you don't have to use the INFORM or INPUT for getting input in the middle of a program. You can put a prompting string on the stack and use the HALT command. The following example illustrates this. After entering a number in response to the prompt, you then press the CONT key.
<< 2 3 * "enter a number" HALT SWAP DROP 4 * *>>
or << 2 3 * "enter a number" HALT SWAP DROP DUP 'X' STO 4 * *>>
...if you want to store it.
--- On Wed, 6/10/09, rickwendel763242 <rickwendel763242@...> wrote:
> From: rickwendel763242 <rickwendel763242@...>
> Date: Wednesday, June 10, 2009, 7:19 PM
2009-06-13 by Juan C.
They recommend to learn to use the hp 50g by reading the manuals of the hp 48 or hp 49, I have learned some things by reading the hp 48 manual. There is also the advanced user guide for the hp 49 which is very useful.
