how do i install and execute a program? but please step by step...
2008-05-23 by tooshorttoremain
Archive for 50g.
2008-05-23 by Dave Boyd
> i have found many info on the net but neither worked. i have put theOne thing about the HP-50G: there are a lot of modes and settings and
> file on an sd. and then i copy it to the port 2. then i soft reset it (
> i press on and f3 together). and it is attached . i got it till now,
> but how do i run the program. is there an execute button im missing?
2008-05-24 by Charles Chindenga
2008-06-07 by Brad Pollard
--- In 50g@yahoogroups.com, "Charles Chindenga" <cfortuh@...> wrote:
> To execute a program on SD card just type
> :3:NAME OF PROGRAM
> Then press EVAL
> - original message -
> Subject: Re: [50g] how do i install and execute a program?
> From: Dave Boyd <boydda@...>
> Date: 23/05/2008 18:36
reset it (
now,
missing?
and
> different ways to do things that will affect how you do things. I
will
> assume, for this explanation, that you have set flag 117 to use
SOFT
> menus instead of CHOOSE menus. Do that first, please. (Press
MODE,
> then F1 to get to FLAGS, then scroll down and make sure that flag
117 is
> set to "SOFT menu", then OK and OK.) Now most (but not all) of the
> menus will present themselves on the menu line instead of popping
up a
> box; you can choose items with one of the top row of keys, the F-
keys,
> F1 through F6. There's a lot of useful things this allows you to
do,
> which the CHOOSE-menus will not allow, which you will find out
about later.
> How you run the program depends on the particular program and what
> programmer wanted to do. Some programs attach themselves to the
APPS
> menu, in which case, press APPS and pick it from the list. If your
does
> not appear in the APPS list, it may be a LIBRARY, in which case,
press
> the orange RIGHT-SHIFT key, then the 2 key, to get to the LIB
menu. Now
> the attached libraries will be displayed on the menu line. Look
for the
> library you attached. If you don't see it, press NXT until you
do. If
> you find it, press the key for that menu item, and the commands
from
> that library should be displayed. Now you can press one of the F-
keys
> to run the command. (You may have to have some items on the stack
if
> the command is a math operation or something like that.)
> If you DON'T find it, it's possible the program was not a LIBRARY,
which
> means it was either a DIRECTORY, or simply a PROGRAM, in which case
you
> have to do something else; let me know.
> Dave Boyd
> "If we hit that bullseye, the rest of the dominoes will fall
> like a house of cards. Checkmate." -Capt. Zapp Brannigan,
D.O.O.P.
2008-06-08 by Tim Wessman
> so I am trying to install this program:This one is better: http://www.hpcalc.org/details.php?id=6306
> http://www.hpcalc.org/details.php?id=4394
> any ways, pressing FORMO only brings up "Library 1010: FORM..." ontoIt is a library. Store it in port 2. Either by using the filer or
> the stack.
> Lastly, is there an easy way to change directories up a levelUPDIR on the keyboard.
> (without going to the Files buttom)?
