50g group photo
50g
Archive for 50g.
Is it possible to somehow enter derivations
2008-05-21 by Brad Pollard
Hello,
Longtime 48gx user and now have a 50g. though I never used
any "advanced" functions on either calculator.
any ways, I am now having to spend time with some resident students,
and wish that there was a way I could store (somewhat) long
mathematical derivations in my 50g. I don't think the equation editor
fits this bill (I don't want to put in variables).
Any ideas?
Brad
Re: [50g] Is it possible to somehow enter derivations
2008-05-22 by Don Hart
Are you talking about the series of equations going
from the given one to the solution (aka, "showing your
work")? Or are you talking about derivatives? Maybe an
example of what you want to do would help explain your
question.
You don't say what you want to do with them. A list is
a good structure to put multiple items in.
I don't know how you're going to store anything
without putting it in a variable, either directly or
using a program that uses variables.
--- Brad Pollard <bpollard@...> wrote:
> Hello,
> never used
> resident students,
> (somewhat) long
> the equation editor
> Any ideas?
> Thanks,
> Brad
Re: Is it possible to somehow enter derivations
2008-05-25 by Brad Pollard
Yes, a "show your work" is what I'm going after I guess.... something
where I can write out the derivation that includes integral signs,
etc. but yea, obviously I don't need or want variables as such
What is the "list" that you speak of?
any help is appreciated...
Brad
> question.
> > Hello,
> > never used
> > resident students,
> > (somewhat) long
> > the equation editor
> > Any ideas?
> > Thanks,
> > Brad
Re: [50g] Re: Is it possible to somehow enter derivations
2008-05-26 by Don Hart
Actually, the equation editor is not a bad way to
enter expressions. It's been completely revamped from
that of the hp48 is very useful now. But, of course.
you can enter expressions directly to the stack.
A list has many uses but in your case it can aggregate
several expressions into one object. Lets say you have
expression1, expression2, and expression3 on the stack
at levels 1 thru 3. If you enter 3 then press "prg" on
the keyboard then "type" on the softmenu and then
->list on the softmenu you'll end up with...
{expression1 expression2 expression3} on level 1 of
your stack. You can get back what you had by pressing
obj-> on the softmenu, and then do a "drop". For more
info check your manual.
Now, if you don't want to save this list in a
variable, you can leave it on the stack. But it's not
a good idea to leave objects on the stack and expect
them to stay there for long. For instance, an errant
program can cause a reset and you can lose the entire
stack.
> guess.... something
> integral signs,
> variables as such
> Brad
> going
> your
> Maybe an
> your
> > question.
> list is
> or
> > > Hello,
> > > never used
> some
> > > resident students,
> > > (somewhat) long
> think
> > > the equation editor
> variables).
> > > Any ideas?
> > > Thanks,
> > > Brad
