50g group photo
50g
Archive for 50g.
50g Tips
50g Tips
2006-10-21 by John Dearing
50g TIPS
Please submit yours to share!  --John
ABBREVIATIONS USED: PLUS: The “+” symbol, when shown between two keys without spaces or commas, means press and hold the first key, press and release the second key, then release the first key. LS = Left Shift key. RS = Right Shift key. ◄ ► ▲ ▼ = the cursor control keys. STO = STO► [the STORE key].
TO GET THE “UPDATE CODE” PROMPT TO UPDATE ROM WITHOUT USING PAPERCLIP: Press ON+F6 [press and hold ON, press and release F6, release ON]; wait about 3 seconds for a menu of options; press and release ON, then immediately press and hold both the + and the – keys for 2-3 seconds; release both keys, see “1. UPDATE CODE  2. SELFTEST”; press 1 to update ROM without having to use a paperclip in the reset hole. To cancel, press 2 to start the selftest, then cancel that with ON+F3.
"HOLDED" KEY COMBINATIONS: On the 50g, if you press Left Shift [or Right Shift] and release, then press another key, that key press combination is different than if you press Left Shift [or Right Shift] and hold it while you press the next key. The rc.p keycode (row column . plane) for the held keys is now rc.ph (where h is 1 for held key and 0 for non-held key).
EXACT & APPROXIMATE MODE TOGGLE: RS+ENTER.
REAL & COMPLEX MODE TOGGLE: LS+TOOL.
PUT BACK TICKS ON THE STACK: If you right-shift (hold) the EQW key ('), you will put back ticks on the stack which will use the Algebraic compiler to parse your command while in RPN mode.
TO LIST CONTENTS OF ALL VARIABLES IN SCREEN: Press RS, ▼ [Right Shift, Cursor Down]. Press ON to cancel.
UNIT CONVERSIONS MADE EASY: Unit conversions like yd^3→m^3 can be keystroke-intensive. To make it easy, have flag 117 (Soft MENU) checked, and RPN mode selected. Example: convert 100 yd^3 to m^3: press RS, UNITS, VOL, type ‘100’, yd^3 [see “100_yd^3”], LS, m^3. See “76.4554857984_m3”. You only have to use CONVERT if you have some units that aren’t on the menus, like ‘qt/hr’. Even then, you can store that unit in a variable, and make a custom menu with it (along with the units you regularly use). Then this method (with LS, the left-shift key) works the same way.
FRACTIONAL EXPONENTS: Why do I get a complex number when I evaluate '(-1)^(2/3)'? Because the machine returns a complex principal solution for expressions with fractional exponents. To get a real-valued result to the above, use the x√y key:  'XROOT(3,(-1)^2)' or 'XROOT(3,SQ(-1))'.
STORE VARIABLES: Example: Store 'π*r2' in variable A1:
ALG:  'π*r^2    STO  A1  ENTER
RPN Method 1:  π  r  ENTER  2  yx  *  A1  STO
RPN Method 2a:  'π*r^2    A1  STO
RPN Method 2b:  'π*r^2  ENTER  A1  STO
PURGE VARIABLES:
ALG:  TOOL  PURGE  VAR  [press variable softkey]  ENTER
RPN Method 1:  VAR  '  [press variable softkey]  ENTER  TOOL  PURGE
RPN Method 2:  VAR  {  [press one or more variable softkeys]  ENTER  TOOL  PURGE
Re: 50g Tips
2006-10-21 by Scott
--- In 50g@yahoogroups.com, "John Dearing" <JSDearing@...> wrote:
> 50g TIPS
* The User Keyboard is your friend. Third-party libraries freely
available from www.hpcalc.org further enhance the custom keyboard's
mode. For example, I have the UTOOL library configured on the long-
hold units key and USIMP (from the lib) on the long-hold convert
key. With USIMP (or similar) on the LH Convert, an unfamiliar SI
unit explosion gets reduced to standard units.
* Similarly, better object viewers are available, as well as slick
editors and full command references available at your fingertips!
* For dynamic verb completion (useful if you program on your
calculator), install emacs 2.11g and store the extable2 library on
an SD card. You will have a complete SysRPL development tool
available that mostly resides on the SD card, thus sparing your
memory.
* To enter complex numbers in a different angle mode while in the
editline (e.g., DEG instead of RAD), begin entry of the complex
number "(RE," and then press the angle key (Alpha-RS 6, rc.p=84.6)
to key in an angle. While here, you can either assign a user key
assignment (with a TakeOver command--see SysRPL programming guides)
to change the angle format immediately; OR, press MODE and change
the angle mode from the dialog box.
* Use compression for large files. The OT49 library includes a BZ
compressor (the BZ compressor is also available elsewhere) and other
useful utilities. The files can be made to automatically
decompress, thereby saving memory.
* Get the free programming environment Debug4x from
www.debug4x.com. It includes a copy of EMU48 that has a functional
HP50g emulator for Windows. Yes, that's right--you can have a 50g
running on your Windows box. No more Windows Scientific
Calculator :)
* Connect your HP50g to your USB port on your computer to save
battery power when doing your homework :)
* Read the extended manual. It has a lot of useful information.
* Use your calculator often and practice, practice, practice.
--Scott
Re: 50g Tips
2006-10-24 by mike
Add these to the wiki site on the links page!
> 50g TIPS
release ON, then immediately press and hold both the + and the â€"
> UNIT CONVERSIONS MADE EASY: Unit conversions like yd^3â†'m^3 can be
> ALG: 'π*r^2 ► STO A1 ENTER
> RPN Method 2a: 'π*r^2 ► A1 STO
> PURGE VARIABLES:
TOOL PURGE
