50g group photo
50g
Archive for 50g.
BODE-ROUTH
BODE-ROUTH
2008-04-16 by Simone
Hello, I'm learning to use program BODE-ROUTH
(http://www.hpcalc.org/details. php? id=3176), that it uses NEOPOLYS
(http://www.hpcalc.org/details. php? id=3169). But when I try to
insert the negative coefficients or negative roots of the polynomial
at the numerator and at the denominator, and trying to trace the
diagram, for example Bode, give back error to me:
NEG Error: Bad Argument Type or
ABS Error: Bad Argument Type!
I have tried also on the emu48 but the behavior is the same one.
e.g.:
2: {1 -2 1}
1: {1 -3 2 -1}
2: {1 2 1}
1: {{0 1 -2 -3}}
With all the positive values they do not give error to me. Someone can
help me? Best regards, Simone.
Re: BODE-ROUTH
2008-04-16 by OLLIVIER
Hello,
Sorry but for me it's ok, I have any problems.
May be it's a problem with your flag?!?!
Nico
Re: BODE-ROUTH
2008-04-17 by Tim Wessman
More than likely yoy have ZINTs instead of reals. If the numbers
don't have a '.' at the end, they are a symbolic object. Many of the
older programs later ported to the 49 never changed things to make it
work. Set you calc to approximate so you will get this
{ 1. -2. 3. } instead of {1 -2 3}
TW
Re: BODE-ROUTH
2008-04-17 by Simone
--- In 50g@yahoogroups.com, "OLLIVIER" <nicolas.ollivier@...> wrote:
> Hello,
> Nico
Which flag?
Simone
Re: BODE-ROUTH
2008-05-24 by Simone
> e.g.:
> 2: {1 -2 1}
> 1: {1 -3 2 -1}
> 2: {1 2 1}
> 1: {{0 1 -2 -3}}
I have resolved the problem using the key [-] and not [+/-]
Simone
Re: BODE-ROUTH
2008-05-24 by arthurford4142
> Simone
Thanks for writing back with the resolution of your problem. This is a
good tip; it's going in my "tips" folder.
Re: [50g] Re: BODE-ROUTH
2008-07-10 by ucho oddone
Are you sure it wasn't the aprox thing that TW told you?
That's very weird, I never had that problem when I used those programs for Control systems!
But my calc was, as I remember, in Approximation mode.
it just seem strange to enter [-]  instead of [+/-]
> e.g.:
> 2: {1 -2 1}
> 1: {1 -3 2 -1}
> 2: {1 2 1}
> 1: {{0 1 -2 -3}}
Simone
Re: BODE-ROUTH
2008-10-07 by Simone
INPUT METHOD:
a) first [+/-] and then number -> NEG Error: Bad Argument Type or ABS
b) first [-] and then number -> ok
c) first number and then [+/-] -> ok
programs for
> Control systems!
> > --- In 50g@yahoogroups.com <50g%40yahoogroups.com>, "Simone"
<gems_tux@>
> > > e.g.:
> > > 2: {1 -2 1}
> > > 1: {1 -3 2 -1}
> > > 2: {1 2 1}
> > > 1: {{0 1 -2 -3}}
Someone can
> > Simone
