50g group photo
50g
Archive for 50g.
newbie eqw question
newbie eqw question
2008-04-15 by alanthegringo
After entering an equation with the equation writer, with one variable
such a 'x', how do you evaluate 'x' for the equation?
It seems like using the equation writer might be easier than
programming. For programming, do you start with << >> button, and
finish with the left arrow prg button?
My old HP15c was simple to program; an example would be:
g prg
f prgm
f LBL A
STO 0
SIN
1/x
STO1
RCL 0
g x^2
3
RCL 1
X
g RTN
g PRG
if x = 3, then f(x) = 21.26 (using radians)
Could this be programmed easier with the HP50G?
Re: [50g] newbie eqw question
2008-04-15 by Don Hart
I can't follow the code you gave, never used a 15c.
But if you want to evaluate a function for values you
enter individually, one of the many ways is to
"define" a softkey for it. Say the function is
f(x)=sin(1/x). Enter it as 'f(x)=sin(1/x)' by pressing
the '' key first then typing in the function followed
by enter. Then press the def key (left shift 2 on the
49g, probably the same on the 50g) and you should see
a soft key labeled f. Now to evaluate the function at
3 just press 3 and then the f soft key.
To enter a program press the <<>> key and enter the
program between those delimiters. Press enter and the
program will be on the stack which you can then store
under a variable name of your choice. You'll really
need to RTFM to learn programming.
> with one variable
> equation?
> easier than
> >> button, and
> would be:
> g prg
> f prgm
> f LBL A
> STO 0
> SIN
> 1/x
> STO1
> RCL 0
> g x^2
> 3
> RCL 1
> X
> g RTN
> g PRG
> Thanks
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
> you
> pressing
> followed
> the
> see
> at
The soft key with the label of f, sorry.
2008-04-15 by Nancy Von Essen
Alan   text message attached below  --  try it    Ed
g prg
f prgm
f LBL A
STO 0
SIN
1/x
STO1
RCL 0
g x^2
3
RCL 1
X
g RTN
g PRG
2008-04-16 by Alan Golightly
thanks
----- Original Message ----
To: 50g@yahoogroups.com
Sent: Tuesday, April 15, 2008 6:31:25 PM
Subject: Re: [50g] newbie eqw question
g prg
f prgm
f LBL A
STO 0
SIN
1/x
STO1
RCL 0
g x^2
3
RCL 1
X
g RTN
g PRG
between 0000-00-00 and 9999-99-99
Re: newbie eqw question
2008-04-16 by vincentgoudreault
variable
> g prg
> f prgm
> f LBL A
> STO 0
> SIN
> 1/x
> STO1
> RCL 0
> g x^2
> 3
> RCL 1
> X
> g RTN
> g PRG
> Thanks
Here is one of the possible equivalent in HP50:
<< -> a << a SIN INV a SQ 3 / * >> >>
where "<<" is the double caret program delimiter, and "->" is the
little assignement arrow.
Save that program by entering a variable name on the stack,
say "Demo", and pressing STO>. This will add a soft key labelled
Demo, and using the program is only a matter of entering the "x"
walue you want to use (actually, it is called "a" in the program...)
and pressing the soft button corresponding to Demo.
One thing to remember is that the HP50 does not use explicit memory
reference (STO 1; RCL 0) to access data; it does so symbolically,
hence the assignement to "a" at the beginning of the program, which
takes whatever value is on the stack and puts it into "a". From then
on, anytime it sees "a", the calculator will bring back the current
value of "a".
In your program, you are saving the result of 1/SIN(x) into memory 1
(STO 1); in the case of the program above, I just leave that value on
the stack, something you could also have done with your HP15; but if
retaining that value is significant in a more elaborate program, it
could have been put in another local variable by adding the statements
-> b
and then using "b" instead of "RCL 1". Just remember that having a
value assigned with the -> function calls for using anotehr layer
of "<< >>" delimiter, as the local variable applies to that sub-
function.
CBVG
One last thing to remember: since this program uses local variables,
the value of "a" as it stands is not retained at the conclusion of the
program. That is what the "<< >>" delimit: the scope of that variable.
CBVG
2008-04-16 by Juan C.
Hello Alan, In order to evaluate that function you have two options (I suppose you are in RPN):
1. You can use DEF.
'FUNC(X)=SQ(X)/(3*SIN(X))' [ENTER] [leftShift] DEF
DEF is associated to key [2]
to run press [3] [VAR] FUNC and you get 21.258502...
2. If you want, you can evaluate the function as a program, you don't need variables for a small function, just manipulate the stack.
«  DUP SQ SWAP SIN / 3 /  »  'FUNC' [STO]
again, to run press [3] [VAR] FUNC and you get 21.258502...
Re: [50g] Re: newbie eqw question
2008-04-17 by Alan Golightly
Thanks Juan, that helps clear some things up for me.
So you input 'variable name(x)= whatever equation, and then DEF;
which stores that variable name under VAR.
Next, how would you delete that variable, and could you accidentally
overwrite a pre-stored variable name that came with the calculator?
- Alan
Sent: Wednesday, April 16, 2008 4:14:04 PM
Subject: [50g] Re: newbie eqw question
1. You can use DEF.
'FUNC(X)=SQ( X)/(3*SIN( X))' [ENTER] [leftShift] DEF
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
2008-04-18 by Juan C.
 To delete a variable put the name of the variable enclosed with single quotes like 'FUNC' press [ENTER] and then [TOOL] and PURGE (associated to [F6]) if you press [VAR] it is not there anymore).  If you realize that you didn't want to delete the variable, right after you execute the command PURGE, you still can recover it with this procedure:
  • firsrt, press [leftShift] ANS (associated with [ENTER]) and you get the object that was stored in the variable in level 2: and the variable name in level 1:
  • second, at this point just press [STO], your variable is back in the directory.
Don't worry too much about using variable names predefined for special purposes, its very unlikely. I try not to work in the HOME directory, create your own directory.
2008-04-18 by Alan Golightly
thanks
Sent: Thursday, April 17, 2008 8:31:24 PM
