50g group photo
50g
Index last updated: 2026-03-31 01:21 UTC
Weird things with my calc.
2007-05-07 by azn_4ko
Well I just took out 1 of the AAA batteries (it was turned off when I
took it out) and then I put it back in because I was look at the
battery label. When I turned it on, the font was back to default (it
was larger than then font I used previously) and the KEYTIME was put on
default again so that every time I pressed a key really fast: 55, only
one 5 would show up..
So I don't know why it reset, should I take out the batteries again and
see if it does it again?-- Okay I've taken all of the batteries out
this time and put them back in and my memory doesn't restart anymore.
However, my analog clock in the top right hand corner keeps on flashing
like the connection isn't right or something. =/
Re: Weird things with my calc.
2007-05-20 by jbmbryant
It sounds like the battery just isn't seated properly. Just press
firmly on it and spin the battery lengthwise, along it's axis. You may
need to do a warmstart (ON-A-F) after, but that should do it.
I hope this helps.
Cheers
