----- Original Message ---- From: Tim Wessman <timwessman@...> To: 50g@yahoogroups.com Sent: Tuesday, March 6, 2007 4:51:18 PM Subject: [50g] Re: Any printer for hp50g
> Is there any possibility to connect a printer to hp50g. > Can i connect hp82240B printer..
Set
the I/O parameter to IR (by doing 104 MENU IOPAR IR)
Then
you can use the print functions (they are under 104 MENU
PRINT)
If I
remember well, you could need to set the delay to 1 (by 104 MENU PRINT PRTPA 1
DELAY) for allowing enough time for the printer to flush the buffer in case of
"intensive" calculator output.
Regards
Philippe
-----Message d'origine----- De : 50g@yahoogroups.com
[mailto:50g@yahoogroups.com]De la part de yilmaz
aktan Envoyé : mardi 6 mars 2007 16:10 À :
50g@yahoogroups.com Objet : Re: [50g] Re: Any printer for
hp50g
Hello
Tim
How
can i solve this problem...
A.Yilmaz
AKTAN
<timwessman@yahoo. com> To: 50g@yahoogroups. com Sent:
hp50g
I print my data on hp82240b printer.But what about a printer which is used by my notebook.
Is there any possibility to connect my hp50g to this printer with using a serial cable or ir.
If so, how can make/find such a serial cable..
Regards
A.Yilmaz AKTAN
----- Original Message ---- From: Philippe Salmon <phsalmon@...> To: 50g@yahoogroups.com Sent: Tuesday, March 6, 2007 10:33:32 PM Subject: RE: [50g] Re: Any printer for hp50g
There is no problem.
Set the I/O parameter to IR (by doing 104 MENU IOPAR IR)
Then you can use the print functions (they are under 104 MENU PRINT)
If I remember well, you could need to set the delay to 1 (by 104 MENU PRINT PRTPA 1 DELAY) for allowing enough time for the printer to flush the buffer in case of "intensive" calculator output.
Regards
Philippe
-----Message d'origine--- -- De : 50g@yahoogroups. com [mailto:50g@ yahoogroups. com]De la part de yilmaz aktan Envoyé : mardi 6 mars 2007 16:10 À : 50g@yahoogroups. com Objet : Re: [50g] Re: Any printer for hp50g
Hello Tim
How can i solve this problem...
A.Yilmaz AKTAN
----- Original Message ---- From: Tim Wessman <timwessman@yahoo. com> To: 50g@yahoogroups. com Sent: Tuesday, March 6, 2007 4:51:18 PM Subject: [50g] Re: Any printer for hp50g
