200e
Index last updated: 2026-04-28 22:38 UTC
Re: [200e] 260e question
2009-06-26 by don hassler
Modelmaker??? wow...
Hard to get past that one.
Anyway, Ezra, I think you addressed the external audio fm before, & confirmed that fm direct from the mod esc worked better.
It wasn't clear whether this was ever something that could be addressed firmware, but beyond that, sort of related, is there any sort of behind the panel block diagrams of these modules?
For example, does the mod osc go through conversion, or is it's path digital, versus the external in?
More questions:
Does the 261e waveshape functions occur after conversion as analog?
Could the 259e waveshape tables emulate extreme audio rate fm?
--- On Fri, 6/26/09, ezra buchla <ezra.buchla@gmail.com> wrote:
> From: ezra buchla <ezra.buchla@gmail.com>
> Subject: Re: [200e] 260e question
> To: 200e@yahoogroups.com
> Date: Friday, June 26, 2009, 1:42 PM
>       they do not suffer from the same artifacts to the
> same degree
> yasi help me make some sounds with that thing! for the
> modelmaker.
> On Fri, Jun 26, 2009 at 10:38 AM, buchlajoe <buchlajoe@yahoo.
> com> wrote:
> > Hi all. Can anyone describe if the fm inputs on the
> 260e behave like the
> > same fm in's on the 261e or 259e ? Or do they
> sound like a more traditional
> > fm in. I find the fm in's on the 259e and 261e to
> be a bit "grainy" Thanks.
> > Joe
2009-06-26 by ezra buchla
really hating yahoo's stupid sidebar formatting right now....
you know, we need to record demonstrative parameter sweeps for the line6
plugin . haha
the ext. audio is sampled, as you'll realize is necessary since the
pre-waveshaping sines (main and mod) are digital ( was i've mentioned here
before). digital phase incrementing == no drift, recall arbitrary
frequencies with precision, etc
so the internal modulation can all be calculated in one fell swoop, no block
diagram required, not so for arbitrary audio
it's all a bit mixed up really, and the terms don't always mean what people
expect them to
> More questions:
yes the waveshaper is 100% analog, very close to old 258
no, i don't think so. they can emulate extreme gnarly audio kahunas though.
(sorry, i am thinking about the beach today.)
>  __._,_.__
>   Recent Activity
> <http://groups.yahoo.com/group/200e;_ylc=X3oDMTJmOWFoNjRqBF9TAzk3MzU5NzE0BGdycElkAzE0NDkzMTQzBGdycHNwSWQDMTcwNTAzMjE0NARzZWMDdnRsBHNsawN2Z2hwBHN0aW1lAzEyNDYwMzkwNzE->
2009-06-26 by Chris Muir
> wrote:
>> More questions:
Typo... it is very close to the old 259, not the 258.
- C
Chris Muir
cbm@well.com
http://www.xfade.com
