Wiardgroup
Index last updated: 2026-04-28 23:41 UTC
Fetafarms cool Mini-Wave expander?
2005-10-17 by grantrichter2001
I added a picture from the Pacific SDIY get together of some cool looking modules.
They look like Mini-Wave PROM expanders, but I don't know.
Fetafarm - Nice work on the faceplates, care to share the details with us?
Re: Fetafarms cool Mini-Wave expander?
2005-10-17 by dhylander
--- In wiardgroup@yahoogroups.com, "grantrichter2001" <grichter@a...>
looking modules.
with us?
I sold Kevin at Fetafarms a Expander PCB last spring.
Dave
Re: Fetafarmer's cool Mini-Wave expander?
2005-10-17 by supisuzoi
Hey!  Glad people liked the panels : )  I've been too busy trying to build my synth to stop
and take pictures of everything, so the SDIY meeting was a great opportunity to show
some of that stuff.
Laying on its side on the left of the photo was my v2 MiniWave panel - standard features,
except for the inverted out jack coming from Dave's MiniWave Expander.  I liked it quite a
lot, but I was always irked by the binary bank/wave indicators.  They're fine for reading
static values, but once once you modulate them, they just turn into blinky lights.  Since
one of the most powerful features of the MiniWave is creative modulation of waves and
banks (and PROMs, if you're so endowed), I wanted to get these indicators displaying in a
format that was instantly recognizable to my brain - decimal 1-16.
A friend quickly pointed me to the 4514 family - a chip that can take 4 binary inputs (like
we have one the MiniWave), and output the corresponding decimal values.  I used a pair of
these to handle the job, and the results are beautiful and immediately informative.
Now I must say at this point that I know nothing about electronics beyond an intro course
in college and some general notions of logic.  I'm an adept assembler, but can't engineer
the simplest of circuits on my own.  Therefore I have no way to troubleshoot the problems
that have arisen from implementing this mod; others will surely find them trivial, and I
thank you in advance for your insight ; }
I removed the transistors at the LED outputs on the MiniWave PCB, and grabbed the signals
directly from vias nearby the MiniWave's ADCs.  Those feed to the respective inputs of the
4514s, which are currently living on +5V similarly tapped from a PCB point (via by the
lower-left corner of U11).  Each 4514 output runs through a 1K resistor to an LED.  The
LEDs are two concentric circles with the ground pins of each bent 90 degrees to form a
bus ring that leads to a single ground point on the MiniWave PCB.
Now for the problems:
I have a lot of noise on the output of the MiniWave.  It's been suggested that using a
separate +5V supply for the mod might alleviate this.
There are faint "misfires" on LEDs at times.  I think this might be an amplification of the
(unavoidable?) error present in the original circuit, where a value that sits right between
two stages (often 7-8 if I remember my experience correctly) will cause a flickering
between the two stages.  This is purely speculation.
Clocking the MiniWave frequency into the mid-audio range causes a weird LED
phenomenon.  If you imagine that the stages are swept with a sawtooth, so that in my ring
configuration you see a single dot traversing a circular path, increasing the frequency will
eventually produce a ring, where all LEDs are essentially lit at all times.  The strange part is
that continuing to increase the frequency causes the ring to "break open" at a single point,
receding symetrically until only a single LED remains lit.  The phenomenon makes me
imagine a phase-cancellation analogy.  I'm told that the 4514s should be able to handle
speeds well beyond the audio range.
Anyhow, all that remains to the design is the manual PROM-select switch which lies inside
the bank/wave indicator rings.  Oh, and Grant, I duplicated the Wiard logo script by
digitizing a photo of my Boogie's panel, and hand-tracing the paths in Illustrator.  I
assumed that you wouldn't mind, since I'm not going around selling bootleg Wiard gear ;
Cheers to everyone out there - the Synth-DIY meeting reminded me that there are still a
lot of creative people around.  Always a refreshing sight in these times : P
Kevin
