Vintage Synth Repair
Index last updated: 2026-04-14 00:11 UTC
Alesis QS6.1 output hum
2015-11-12 by arnaldo.ortega@...
Hi All,
I have an Alesis QS6.1 that developed a subtle but annoying hum in the audio outs (main and phones) after around 10 years of good service. I'm suspecting of capacitor malfunction in the power supply.
Has anyone ever serviced the power circuit capacitors in the QS6.1? Were you able to eliminate the hum by replacing them?
~ACO
Re: [vintagesynthrepair] Alesis QS6.1 output hum
2015-11-13 by John Karns
I don't have a QS6, but the power supply caps are the most likely cause of the problem. They are usually not difficult to replace once you get the synth opened up, and the values of the capacitors are not critical. The rule of thumb is to replace with caps of equal or greater capacity. The only way to find out if they are causing the hum is to replace them. Usually they are not expensive to buy compared to some other types of components such transformers, for example.
2015-11-15 by Daniel Forró
And equal or greater voltage :-)
Daniel Forro
On Nov 14, 2015, at 1:57 AM, John Karns johnkarns@...
> example.
Re: OT Xmas music
2015-12-23 by Daniel Forró
Hi everybody,
enjoy some Christmas music on my new YouTube channel if you
celebrate :-)
Daniel Forró - Forrotronics
Re: [vintagesynthrepair] Korg PE1000 vibrato repair
2016-01-12 by Daniel Forró
I've got KORG PE1000 and could repair some problems like not working
tones and other usual stuff on the instrument which was not used for
long time.
Now everything works except one vibrato oscillator - LFO.
There are three LFO's, first one controls first three tones on the
keyboard, second one the next three notes, third one the next three
notes and this pattern is repeated throughout the keyboard. So I have
now vibrato on keys 4 to 9, then 13 to 18, etc. Coupler notes one
octave higher follow the same pattern but shifted, because note one
octave up use different LFO. Very clever idea, which helps to get more
animated sound - all LFO's have the same speed and depth (controlled
by pots) but different phase.
So I suppose one LFO doesn't work. By measuring voltages at LFO
outputs (points 50, 53 and 54 in schematics on the page 7) it was
confirmed - while LFO 2 and 3 have changing triangle wave on the
outputs and voltage changes from approx. 6.5 to 7.5 Volts, LFO 1
output gives steady 7.11 Volts.
I have attached Service Manual and I'd like to ask more experienced
electronic gurus here:
- Which component in LFO circuit would you considered faulty with the
highest probability? I don't want to change all of them... Could be
only one half of LM3900 working and the other faulty? Or is it
transistor?
- How I can find which component is faulty? I have digital voltmeter
and oscilloscope....  Can I find wrong component by measuring and
comparing voltages in different locations of the LFO 2 or 3?
Thanks for any hint...
Daniel Forro
P.S.: If attachments are not allowed here, I will send Service manual
by PM, or it can be found here for download:
http://elektrotanya.com/?q=showresult&what=korg%20pe-1000&kategoria=&kat2=schematics
2016-01-13 by Daniel Forró
long time.
transistor?
Daniel Forro
2016-01-15 by narfman96@...
Hi Daniel,
I would replace the bad LM3900 if you are certain the output is stuck at 7 volts. Compare the outputs to the other LFO's. Pin 5 is output 1, pin 4 is output 2, pin 9 is output 3, and pin 10 is output 4. If you can find the offending output voltage stuck at 7 volts you have the bad chip. Everything downstream will be 7 volts too. This is what a tech that works on op amps all the time would call stuck at the rails (power supply voltage).
HTH, Fran
P.S. I did not send that other email. Sorry I never replied. We've been busy learning new material plus I've been out booking more gigs. Added some 90's tunes for the millennium crowd..... The Alibi Band
2016-01-18 by Daniel Forró
Hi, Fran,
you were absolutely right, it was that opamp. Now new one sits in the
socket and everything works :-)
Your band looks well! I wish you lot of gigs and fans!
Daniel Forro
On Jan 15, 2016, at 10:32 AM, narfman96@... [vintagesynthrepair]
wrote:
> Hi Daniel,
> HTH,  Fran
> Band
> The Alibi Band
> Home Music Media Gigs Contact
> View on www.thealibiband.net
> Preview by Yahoo
