Vintage Synth Repair
Index last updated: 2026-04-28 23:41 UTC
Roland Jupiter 4 VCO width problem
2014-06-30 by nico678@...
Hi everybody,
I'm trying to repair a Roland Jupiter 4.
I can't adjust the VCo width properly on one of the voice module.
The width adjustment potentiometer is at the maximum but the octaves are not in tune on this voice.
Anybody has an idea what could be the cullprit?
Thank you!
Nicolas
Hi everybody,
I'm trying to repair a Roland Jupiter 4 on one of the voice module.
I can't adjust the octaves properly with the VCO width potentiometer at the maximum.
Any help would be greatly appreciated!
Thank you!
Nicolas
Re: Roland Jupiter 4 VCO width problem
2014-07-04 by Scott Frye
On this model , doesnt the microprocessor "READ" the value of that pot on a continual basis?
If so, check the solder /wire connections to the pot and check continuity from the pot leads back to the IC is runs through
Scott Frye
Audio-fixation.net
Vermont
