Vintage Synth Repair
Index last updated: 2026-04-28 23:41 UTC
Inverter boards for keyboard LCD backlight
2014-04-10 by NoëlBuhagiar
Hello guys,
Does anyone know from where I could get some inverter boards for keyboard LCD backlight at a reasonable price?
Preferably the ones that work on 5V supply (not 12V).
Thanks for your help,
noel
europe
Re: [vintagesynthrepair] Inverter boards for keyboard LCD backlight
2014-04-11 by Daniel Forró
I buy here:
http://www.backlight4you.com/
No connection with them, just very satisfied customer.
Maybe it's good to buy both, new EL foil and proper inverter, to be
sure they will work together.
Daniel Forro
On 11 Apr, 2014, at 7:24 AM, NoëlBuhagiar wrote:
> Hello guys,
> noel
> europe
2014-04-11 by NoëlBuhagiar
Thanks Daniel
perhaps, I did not specify enough what I’m after
the backlight is of the fluorescent tube type about 4 inches
so the inverter is different in this case, that works from 5V
Thanks again,
noel
Sent: Friday, April 11, 2014 2:20 AM
To: vintagesynthrepair@yahoogroups.com
Subject: Re: [vintagesynthrepair] Inverter boards for keyboard LCD backlight
I buy here:
Maybe it's good to buy both, new EL foil and proper inverter, to be sure they will work together.
Daniel Forro
  Hello guys,
  noel
  europe
RE: [vintagesynthrepair] Inverter boards for keyboard LCD backlight
2014-04-12 by John Rose
I know this is not directly related but may give some other scope for thought.
I am currently looking at replacing the EL backlights with LED based ones, the problem is that getting hold of the right size can be difficult so I am working on the idea of using the diffuser panel out of old laptop screens that can easily be cut to the desired size and then attaching some dual high output LED’s that are designed for back illumination, the LED’s are available in a variety of colours and also have a much longer life expectancy than the foils as well as doing away with the high voltages associated with the inverters. At the moment I have an Akai 3000 which has a totally dead backlight so I will probably use this as a test project and will probably go for a red backlight as I think this will be quite pleasing to look at.
Many thanks
John Rose
(www.astrodevelopments.com)
From: vintagesynthrepair@yahoogroups.com [mailto:vintagesynthrepair@yahoogroups.com] On Behalf Of NoëlBuhagiar
Sent: 11 April 2014 22:15
Thanks Daniel
Thanks again,
noel
I buy here:
Daniel Forro
Hello guys,
noel
europe
2014-04-13 by Daniel Forró
It's possible to buy new EL foils for example here, I have good
experience with their products:
They offer also inverters for the case also old inverter is dead.
Another possibility is to use modern display with LED backlight and do
small modifications - add limiting resistor, omit the inverter...
It's possible - most of instruments with displays follow standards
like T6963 for bigger graphical displays or HD44780 for character
displays.
I did such exchange in more of my older gear.
The only problem can be space  - LED backlighted displays are thicker
and not fit into some instruments. Then only new EL foil is the
solution. Hopefully one day thin displays will come to market, maybe
OLED type...
Daniel Forro
> for thought.
> Many thanks
> John Rose
2014-04-14 by NoëlBuhagiar
Hi John, yes that is a good idea
I have done this on a Korg module although wasn’t that easy due to thickness restrictions
fitted l.e.d backlight strip of amber colour as found best
the original backlight consisted of a mini-pcb that had minute dual colour l.e.d.s fitted
as this was not found I fitted larger type l.e.d.s in strip form and feeded them from
a 12V supply taken at a point from the main board supply cct.
for the moment I am unlucky as I do not have diffuser available from a scrap screen
thanks for your feedback, noel
Sent: Saturday, April 12, 2014 3:57 PM
Subject: RE: [vintagesynthrepair] Inverter boards for keyboard LCD backlight
Many thanks
John Rose
Thanks Daniel
Thanks again,
noel
I buy here:
Daniel Forro
Hello guys,
noel
europe
