AW: [PolySix] Problems with the 74LS08
2004-01-26 by Ullrich Peter
Hi Stef!
If you use HCT-parts that have TTL levels you should have luck...
Ciao
Peter
(o o)
--oOOO--(_)--OOOo------------------------------------------------------
Ing. Peter Ullrich
Hardware & Software Developer / Electronic Musician
Kapsch TrafficCom AG Vienna / Austria
http://www.kapsch-trafficcom.com/
*Tel: +43 (0)50 811 2265
* Fax: +43 (0)-50 811 2209
*EFax: +43 (0)50 811 992265
.oooO *Email: mailto:peter.ullrich@kapsch.net
( ) Oooo. ----------------------------------------------------
\ ( ( ) Private Homepage: http://www.ullrich.at.tt
-----\_)----) /--------------------------------------------------------
(_/
This e-mail and any attachment and the included information are confidential,
protected by copyright and intended solely for the use of the named
recipient(s). If you are not the named recipient any disclosure, copying,
distribution or retention of this e-mail is prohibited and may be unlawful. If
you are not the intended recipient, please inform us immediately, delete this
e-mail and all attachments from your system, and refrain from taking any other
action in reliance to this e-mail.
>i have two questions: First, should it be a problem to use 74HC08/7408The HC-Parts have CMOS logic levels...
>instead of the original 74LS08? I´ve figured out strange problems with
>using them (specially with IC31).
Ciao
Peter
(o o)
Ing. Peter Ullrich
(_/
