Archive for polysix.
Power supply voltages
2016-02-13 by Bob Grieb
When you get it all up and working, you will need to set the trimpots
on the KLM-367 board as described in the calibration steps. Setting
them in the same position as they were on the old board by eye
is not really a good way to do it, since the other components in
the circuit may have been replaced (new resistors from China). So
you need to re-do the calibration. Usually the first step would be
to set the supply voltages to their exact values, if you have a meter that you trust.
Of course, changing the voltages may require that you re-tune the voices,
but you should probably do that anyway. I don't know when that was last
done to your Poly Six. If you have reason to think the 366 board trimmers
are fine as they are, then you should not change the power supply rails,
as that could affect the settings.
Bob
On Sat, 2/13/16, jw_dewdney@yahoo.com [PolySix] <PolySix@yahoogroups.com> wrote:
Subject: Re: [PolySix] Re: PROGRESS!!!!
To: PolySix@yahoogroups.com
Date: Saturday, February 13, 2016, 5:03 PM
i checked them yes - many times - and the 5v was
constantly at 4.96 and the 15 v at 14.92 or something - both
seemed MORE than close enough... (?)
#yiv0284512244 #yiv0284512244 --
#yiv0284512244ygrp-mkp {
0;padding:0 10px;}
#yiv0284512244 #yiv0284512244ygrp-mkp hr {
border:1px solid #d8d8d8;}
#yiv0284512244 #yiv0284512244ygrp-mkp #yiv0284512244hd {
0;}
#yiv0284512244 #yiv0284512244ygrp-mkp #yiv0284512244ads {
margin-bottom:10px;}
#yiv0284512244 #yiv0284512244ygrp-mkp .yiv0284512244ad {
padding:0 0;}
#yiv0284512244 #yiv0284512244ygrp-mkp .yiv0284512244ad p {
margin:0;}
#yiv0284512244 #yiv0284512244ygrp-mkp .yiv0284512244ad a {
#yiv0284512244 #yiv0284512244ygrp-sponsor
#yiv0284512244ygrp-lc {
font-family:Arial;}
#yiv0284512244ygrp-lc #yiv0284512244hd {
margin:10px
#yiv0284512244ygrp-lc .yiv0284512244ad {
#yiv0284512244 #yiv0284512244actions {
#yiv0284512244 #yiv0284512244activity {
#yiv0284512244 #yiv0284512244activity span {
font-weight:700;}
#yiv0284512244 #yiv0284512244activity span:first-child {
text-transform:uppercase;}
#yiv0284512244 #yiv0284512244activity span a {
#yiv0284512244 #yiv0284512244activity span span {
color:#ff7900;}
.yiv0284512244underline {
text-decoration:underline;}
#yiv0284512244 .yiv0284512244attach {
0;width:400px;}
#yiv0284512244 .yiv0284512244attach div a {
#yiv0284512244 .yiv0284512244attach img {
#yiv0284512244 .yiv0284512244attach label {
#yiv0284512244 .yiv0284512244attach label a {
#yiv0284512244 blockquote {
margin:0 0 0 4px;}
#yiv0284512244 .yiv0284512244bold {
#yiv0284512244 .yiv0284512244bold a {
#yiv0284512244 dd.yiv0284512244last p a {
#yiv0284512244 dd.yiv0284512244last p span {
span.yiv0284512244yshortcuts {
margin-right:0;}
#yiv0284512244 div.yiv0284512244attach-table div div a {
#yiv0284512244 div.yiv0284512244attach-table {
width:400px;}
#yiv0284512244 div.yiv0284512244file-title a, #yiv0284512244
div.yiv0284512244file-title a:active, #yiv0284512244
div.yiv0284512244file-title a:hover, #yiv0284512244
div.yiv0284512244file-title a:visited {
#yiv0284512244 div.yiv0284512244photo-title a,
#yiv0284512244 div.yiv0284512244photo-title a:active,
#yiv0284512244 div.yiv0284512244photo-title a:hover,
#yiv0284512244 div.yiv0284512244photo-title a:visited {
#yiv0284512244 div#yiv0284512244ygrp-mlmsg
#yiv0284512244ygrp-msg p a span.yiv0284512244yshortcuts {
#yiv0284512244 .yiv0284512244green {
color:#628c2a;}
#yiv0284512244 .yiv0284512244MsoNormal {
margin:0 0 0 0;}
#yiv0284512244 o {
font-size:0;}
#yiv0284512244 #yiv0284512244photos div {
float:left;width:72px;}
#yiv0284512244 #yiv0284512244photos div div {
border:1px solid
#666666;height:62px;overflow:hidden;width:62px;}
#yiv0284512244 #yiv0284512244photos div label {
#yiv0284512244 #yiv0284512244reco-category {
font-size:77%;}
#yiv0284512244 #yiv0284512244reco-desc {
font-size:77%;}
#yiv0284512244 .yiv0284512244replbq {
margin:4px;}
#yiv0284512244 #yiv0284512244ygrp-actbar div a:first-child {
#yiv0284512244 #yiv0284512244ygrp-mlmsg {
sans-serif;}
#yiv0284512244 #yiv0284512244ygrp-mlmsg table {
font-size:inherit;font:100%;}
#yiv0284512244 #yiv0284512244ygrp-mlmsg select,
#yiv0284512244 input, #yiv0284512244 textarea {
#yiv0284512244 #yiv0284512244ygrp-mlmsg pre, #yiv0284512244
code {
font:115% monospace;}
#yiv0284512244 #yiv0284512244ygrp-mlmsg * {
line-height:1.22em;}
#yiv0284512244 #yiv0284512244ygrp-mlmsg #yiv0284512244logo {
padding-bottom:10px;}
#yiv0284512244 #yiv0284512244ygrp-msg p a {
font-family:Verdana;}
p#yiv0284512244attach-count span {
#yiv0284512244 #yiv0284512244ygrp-reco
#yiv0284512244reco-head {
#yiv0284512244 #yiv0284512244ygrp-reco {
#yiv0284512244 #yiv0284512244ygrp-sponsor #yiv0284512244ov
li a {
li {
ul {
margin:0;padding:0 0 0 8px;}
#yiv0284512244 #yiv0284512244ygrp-text {
font-family:Georgia;}
#yiv0284512244 #yiv0284512244ygrp-text p {
margin:0 0 1em 0;}
#yiv0284512244 #yiv0284512244ygrp-text tt {
font-size:120%;}
#yiv0284512244 #yiv0284512244ygrp-vital ul li:last-child {
border-right:none !important;
#yiv0284512244
Re: Power supply voltages
2016-02-13 by jw_dewdney@yahoo.com
yes I am pretty firmly in the 'don't fix it if it ain't broke' school... and I was really pleased how consistent all four voice circuits sounded thus far.... I'd like to battle one daemon at a time but not make any new ones until I've got the others conquered first... gah!! (if it's not one thing it's another) - so i'm trying not to rock the boat TOO much... since I seem to have a talent to take things from bad to worse sometimes - at least it feels like it lately! :)
2016-02-15 by jw_dewdney@yahoo.com
SO - I'm back at it now - I proceeded to rig up something for the 56K resistor (47K + 9.1K) but when I adjust VR1 to JUST light things up and then disconnect the resistor- I don't get either Bank A OR Pgm 1 lighting up. What does that mean?? My voltage drop on the +5v supply is 0.25v.
Re: [PolySix] Re: Power supply voltages
2016-02-15 by Bob Grieb
Does anything change when you remove the resistor?
Try connecting your scope to the reset input to the CPU
and set it to auto trigger. Connect the resistor.
Turn the trimmer to just light up everything. You should
see RESETb low at that time. Now remove the resistor.
You should see RESETb go high. If all of that works,
then the reset circuit is set properly and is working.
As to why you are not getting the proper LEDs when the CPU
is running, we can treat that as a separate issue if reset is
working properly.
Bob
On Mon, 2/15/16, jw_dewdney@yahoo.com [PolySix] <PolySix@yahoogroups.com> wrote:
Subject: [PolySix] Re: Power supply voltages
Date: Monday, February 15, 2016, 1:00 AM
is 0.25v.
#yiv2370670852 #yiv2370670852 --
#yiv2370670852ygrp-mkp {
0;padding:0 10px;}
#yiv2370670852 #yiv2370670852ygrp-mkp hr {
#yiv2370670852 #yiv2370670852ygrp-mkp #yiv2370670852hd {
0;}
#yiv2370670852 #yiv2370670852ygrp-mkp #yiv2370670852ads {
#yiv2370670852 #yiv2370670852ygrp-mkp .yiv2370670852ad {
padding:0 0;}
#yiv2370670852 #yiv2370670852ygrp-mkp .yiv2370670852ad p {
margin:0;}
#yiv2370670852 #yiv2370670852ygrp-mkp .yiv2370670852ad a {
#yiv2370670852 #yiv2370670852ygrp-sponsor
#yiv2370670852ygrp-lc {
font-family:Arial;}
#yiv2370670852ygrp-lc #yiv2370670852hd {
margin:10px
#yiv2370670852ygrp-lc .yiv2370670852ad {
#yiv2370670852 #yiv2370670852actions {
#yiv2370670852 #yiv2370670852activity {
#yiv2370670852 #yiv2370670852activity span {
font-weight:700;}
#yiv2370670852 #yiv2370670852activity span:first-child {
#yiv2370670852 #yiv2370670852activity span a {
#yiv2370670852 #yiv2370670852activity span span {
color:#ff7900;}
.yiv2370670852underline {
#yiv2370670852 .yiv2370670852attach {
0;width:400px;}
#yiv2370670852 .yiv2370670852attach div a {
#yiv2370670852 .yiv2370670852attach img {
#yiv2370670852 .yiv2370670852attach label {
#yiv2370670852 .yiv2370670852attach label a {
#yiv2370670852 blockquote {
margin:0 0 0 4px;}
#yiv2370670852 .yiv2370670852bold {
#yiv2370670852 .yiv2370670852bold a {
#yiv2370670852 dd.yiv2370670852last p a {
#yiv2370670852 dd.yiv2370670852last p span {
span.yiv2370670852yshortcuts {
margin-right:0;}
#yiv2370670852 div.yiv2370670852attach-table div div a {
#yiv2370670852 div.yiv2370670852attach-table {
width:400px;}
#yiv2370670852 div.yiv2370670852file-title a, #yiv2370670852
div.yiv2370670852file-title a:active, #yiv2370670852
div.yiv2370670852file-title a:hover, #yiv2370670852
div.yiv2370670852file-title a:visited {
#yiv2370670852 div.yiv2370670852photo-title a,
#yiv2370670852 div.yiv2370670852photo-title a:active,
#yiv2370670852 div.yiv2370670852photo-title a:hover,
#yiv2370670852 div.yiv2370670852photo-title a:visited {
#yiv2370670852 div#yiv2370670852ygrp-mlmsg
#yiv2370670852ygrp-msg p a span.yiv2370670852yshortcuts {
#yiv2370670852 .yiv2370670852green {
color:#628c2a;}
#yiv2370670852 .yiv2370670852MsoNormal {
margin:0 0 0 0;}
#yiv2370670852 o {
font-size:0;}
#yiv2370670852 #yiv2370670852photos div {
#yiv2370670852 #yiv2370670852photos div div {
border:1px solid
#yiv2370670852 #yiv2370670852photos div label {
#yiv2370670852 #yiv2370670852reco-category {
font-size:77%;}
#yiv2370670852 #yiv2370670852reco-desc {
font-size:77%;}
#yiv2370670852 .yiv2370670852replbq {
margin:4px;}
#yiv2370670852 #yiv2370670852ygrp-actbar div a:first-child {
#yiv2370670852 #yiv2370670852ygrp-mlmsg {
sans-serif;}
#yiv2370670852 #yiv2370670852ygrp-mlmsg table {
#yiv2370670852 #yiv2370670852ygrp-mlmsg select,
#yiv2370670852 input, #yiv2370670852 textarea {
#yiv2370670852 #yiv2370670852ygrp-mlmsg pre, #yiv2370670852
code {
#yiv2370670852 #yiv2370670852ygrp-mlmsg * {
#yiv2370670852 #yiv2370670852ygrp-mlmsg #yiv2370670852logo {
#yiv2370670852 #yiv2370670852ygrp-msg p a {
p#yiv2370670852attach-count span {
#yiv2370670852 #yiv2370670852ygrp-reco
#yiv2370670852reco-head {
#yiv2370670852 #yiv2370670852ygrp-reco {
#yiv2370670852 #yiv2370670852ygrp-sponsor #yiv2370670852ov
li a {
li {
ul {
#yiv2370670852 #yiv2370670852ygrp-text {
#yiv2370670852 #yiv2370670852ygrp-text p {
margin:0 0 1em 0;}
#yiv2370670852 #yiv2370670852ygrp-text tt {
font-size:120%;}
#yiv2370670852 #yiv2370670852ygrp-vital ul li:last-child {
#yiv2370670852
Hi Bob - I ASSUME it's working correctly (the reset) since the lights go off when I disconnect it. As previously mentioned I measure a 0.25v drop with the resistor in place across the +5v supply test point. As for the behaviour on the resetb pin- i will have to report to you later. Thanks!
OK. If the lights go on when you connect the resistor
and off when you disconnect it, then no need to scope reset,
I guess. Maybe start scoping some other signals to continue
your debug efforts.
Bob
Subject: Re: [PolySix] Re: Power supply voltages
Date: Monday, February 15, 2016, 6:05 PM
you later. Thanks!
#yiv0777466308 #yiv0777466308 --
#yiv0777466308ygrp-mkp {
0;padding:0 10px;}
#yiv0777466308 #yiv0777466308ygrp-mkp hr {
#yiv0777466308 #yiv0777466308ygrp-mkp #yiv0777466308hd {
0;}
#yiv0777466308 #yiv0777466308ygrp-mkp #yiv0777466308ads {
#yiv0777466308 #yiv0777466308ygrp-mkp .yiv0777466308ad {
padding:0 0;}
#yiv0777466308 #yiv0777466308ygrp-mkp .yiv0777466308ad p {
margin:0;}
#yiv0777466308 #yiv0777466308ygrp-mkp .yiv0777466308ad a {
#yiv0777466308 #yiv0777466308ygrp-sponsor
#yiv0777466308ygrp-lc {
font-family:Arial;}
#yiv0777466308ygrp-lc #yiv0777466308hd {
margin:10px
#yiv0777466308ygrp-lc .yiv0777466308ad {
#yiv0777466308 #yiv0777466308actions {
#yiv0777466308 #yiv0777466308activity {
#yiv0777466308 #yiv0777466308activity span {
font-weight:700;}
#yiv0777466308 #yiv0777466308activity span:first-child {
#yiv0777466308 #yiv0777466308activity span a {
#yiv0777466308 #yiv0777466308activity span span {
color:#ff7900;}
.yiv0777466308underline {
#yiv0777466308 .yiv0777466308attach {
0;width:400px;}
#yiv0777466308 .yiv0777466308attach div a {
#yiv0777466308 .yiv0777466308attach img {
#yiv0777466308 .yiv0777466308attach label {
#yiv0777466308 .yiv0777466308attach label a {
#yiv0777466308 blockquote {
margin:0 0 0 4px;}
#yiv0777466308 .yiv0777466308bold {
#yiv0777466308 .yiv0777466308bold a {
#yiv0777466308 dd.yiv0777466308last p a {
#yiv0777466308 dd.yiv0777466308last p span {
span.yiv0777466308yshortcuts {
margin-right:0;}
#yiv0777466308 div.yiv0777466308attach-table div div a {
#yiv0777466308 div.yiv0777466308attach-table {
width:400px;}
#yiv0777466308 div.yiv0777466308file-title a, #yiv0777466308
div.yiv0777466308file-title a:active, #yiv0777466308
div.yiv0777466308file-title a:hover, #yiv0777466308
div.yiv0777466308file-title a:visited {
#yiv0777466308 div.yiv0777466308photo-title a,
#yiv0777466308 div.yiv0777466308photo-title a:active,
#yiv0777466308 div.yiv0777466308photo-title a:hover,
#yiv0777466308 div.yiv0777466308photo-title a:visited {
#yiv0777466308 div#yiv0777466308ygrp-mlmsg
#yiv0777466308ygrp-msg p a span.yiv0777466308yshortcuts {
#yiv0777466308 .yiv0777466308green {
color:#628c2a;}
#yiv0777466308 .yiv0777466308MsoNormal {
margin:0 0 0 0;}
#yiv0777466308 o {
font-size:0;}
#yiv0777466308 #yiv0777466308photos div {
#yiv0777466308 #yiv0777466308photos div div {
border:1px solid
#yiv0777466308 #yiv0777466308photos div label {
#yiv0777466308 #yiv0777466308reco-category {
font-size:77%;}
#yiv0777466308 #yiv0777466308reco-desc {
font-size:77%;}
#yiv0777466308 .yiv0777466308replbq {
margin:4px;}
#yiv0777466308 #yiv0777466308ygrp-actbar div a:first-child {
#yiv0777466308 #yiv0777466308ygrp-mlmsg {
sans-serif;}
#yiv0777466308 #yiv0777466308ygrp-mlmsg table {
#yiv0777466308 #yiv0777466308ygrp-mlmsg select,
#yiv0777466308 input, #yiv0777466308 textarea {
#yiv0777466308 #yiv0777466308ygrp-mlmsg pre, #yiv0777466308
code {
#yiv0777466308 #yiv0777466308ygrp-mlmsg * {
#yiv0777466308 #yiv0777466308ygrp-mlmsg #yiv0777466308logo {
#yiv0777466308 #yiv0777466308ygrp-msg p a {
p#yiv0777466308attach-count span {
#yiv0777466308 #yiv0777466308ygrp-reco
#yiv0777466308reco-head {
#yiv0777466308 #yiv0777466308ygrp-reco {
#yiv0777466308 #yiv0777466308ygrp-sponsor #yiv0777466308ov
li a {
li {
ul {
#yiv0777466308 #yiv0777466308ygrp-text {
#yiv0777466308 #yiv0777466308ygrp-text p {
margin:0 0 1em 0;}
#yiv0777466308 #yiv0777466308ygrp-text tt {
font-size:120%;}
#yiv0777466308 #yiv0777466308ygrp-vital ul li:last-child {
#yiv0777466308
