Archive for polysix.
Re: [PolySix] Tuning
2001-06-05 by Ian Harris
I'm also having a tuning problem with my Poly 61. One end of the keyboard is in tune and it gets more and more of of tune as you go towards the bass end. Any suggestions on how to fix it?
Ian Harris
iharris@bentspike.com
http://www.bentspike.com
To: PolySix@yahoogroups.com
Sent: Wednesday, June 06, 2001 7:12 PM
Subject: [PolySix] Tuning
Hey-
Hope everyone is doing well. I'm having a minor problem with my poly6. I have to adjust the tuning knob to be very flat to get the "proper" tuning. I'd swear I've seen where you can open it up and get right to the source to get the tuning pot back on track. Any truth to this, or is there the external TUNE knob only to adjust this? Thanks everyone.
Ian
Yahoo! Groups Sponsor
Yahoo! Website Services- Click Here!
PolySix-unsubscribe@egroups.com
PolySix "Digiest" Page: http://www.ing.umu.se/~me96kus/p6digi.html
Tuning
2001-06-06 by goxflee@aol.com
Hey-
Ian
Re: Tuning
2003-04-07 by ghwelles
I have the exact same problem with my Poly six. Anyone have any
suggestions?
Re: [PolySix] Re: Tuning
2003-04-07 by David Davis
Mine is like that too!
To be honest, I've never really found it to be that big a
problem, but I have wondered if there's a simple
calibration I could do to fix it...?
--- ghwelles <GHWelles@bbklaw.com> wrote: > --- In
> end of the
> as you go
> have any
> suggestions?
> http://www.acc.umu.se/~amber/Poly6
> http://docs.yahoo.com/info/terms/
http://www.felinedream.co.uk
Yahoo! Plus
For a better Internet experience
http://www.yahoo.co.uk/btoffer
2003-04-07 by Johannes Hausensteiner
I do not know about the Poly-61; as far as I know it has DCOs, which
generate the frequency in a digital manner. So out of tune in only
a region of the keyboard is per definition "not possible"...
The Poly-6 is different. It is truly analog - at least in this aspect.
There are 6 independent VCOs; each can be tuned seperately with two
potis: low/high, addtionally there are three overall potis
(low/mid/high). Even more, Polysix is using so called "strechted
tuning". This means it is slightly out of tune intentionally; to
gain more movement in the sound. The manual says, this is about
8..12cents over the whole KBD range. I strongly recommend that you
follow the adjustment procedure given in the service manual - at
least the first time you do it. Once you know how it behaves and
which poti is doing what, you can turn away from DVMs, oscilloscopes,
and tuners and trust your ears..
If you do not have the adjustment procedure, let me know; I can send
it to you.
>>>end of the
>>>as you go
>>>have any
>>>suggestions?
> Yahoo! Plus
> PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6
2003-04-07 by Henry Welles
Thanks for the reply:
I have the procedure form the manual, and it was very unclear, and
referred to VRs that did not exist and did not refere to ones that did
(The old verses new production problem.) Mine is a new production
board. What do each of the VR's do? On the 367 board there are VR1,
VR2. VR3, VR4, VR14, a D#-E4 VR, etc.
Any help is appreciated.
>>> jo.synth@crossnet.at 04/07/03 02:19PM >>>
it to you.
>>>end of the
>>>as you go
>>>have any
>>>suggestions?
> Yahoo! Plus
2003-04-10 by Johannes Hausensteiner
The description in the adjustment procedure is for the
"Old Production", you are right. This maps as follows to the
"New Production" (n.b. old/new is only valid for the KLM-366 board,
all other boards are just one version)
| OLD | NEW | meaning |
Overall pots:
| VR1 | VR1 | tune mid |
| - | VR2 | tune high |
| VR3 | VR3 | tune low |
| VR4 | VR4 | EG intensity |
| VR5 | VR5 | KBD tracking |
| - | VR13| KBD track offs|
| - | VR14| DAC MSB adj |
| | | ("D#4 - E4") |
|KLM396| VR15| tune mid |
| VR1 | | |
Voice pots:
| VR6 | VR6 | VCF resonance |
| VR7 | VR6 | VCF offset |
| VR8 | VR8 | VCF cutoff |
| VR9 | VR9 | VCA adjust |
| VR10 | VR10| VCO tune low |
| VR11 | VR11| VCO tune high |
| VR12 | VR12| EG time |
Be sure to move the sliding switch towards the back, which is normal
tuning, when doing the tuning procedure. The service manual is not
clear in this point (maybe better for "Old Production"). When finished
you (may) move it towards the front and enable the stretched tuning.
You can verify the tuning mode easily with a tuner when playing a high
note: when switching the sliding switch back and forth the lower pitch
is normal tuning, the higher pitch is stretched tuning, which adds even
more richness and movement to the sound.
I do it this way:
1) move the overall tuning pots VR2, VR3 (hi, low) to center position
2) move VR10, VR11 of unit 0 to center position.
3) now tune unit 0 with the overall pots, using a chromatic tuner.
this can be a little tricky, as all pots are influencing each other.
you may adjust VR10 and/or VR11 to gain perfect tuning at low/high
notes.
4) use (overall) pots VR14, VR15 to find the best compromise in
deviation from ideal tuning during the whole scale (dont forget to
change the footage switch on the control panel; i.e. the lowest note
is C0 at a 16' setting, the highest not is C5 at 4')
5) when satisfied with tuning unit 0 take a break; your ears will need
it!
check that pots are about in the middle; none should be cranked to
one edge; you can get into trouble later on!
6) then tune units 1..5 *to unit 0*! dont tune units 1..5 individually!
7) check tuning with a 6-voice-same-note-chord in chord memory
Dont be disturbed that you cannot make it perfect! It is 6
*independent* oscillators with analogue circuitry - they never will
be 100% perfect. After all, thats what we folks want!
8) Switch SW1 to front position and enjoy the "Schwebung" (dont know
the English word..) created by the stretched tuning. Note the
difference between the 6-voice-same-note-chord and Unison mode!
Thats ... extraordinary!
Btw. if you are in this that deep you may remove D1 from KLM-366. This
gives you both Saw and Pulse wave *at the same time* in "SAW" position.
You still can kill the pulse wave by turning the PW control fully
clockwise for a saw-only setting.
I hope this helps
Johannes
2003-04-10 by Henry Welles
THANKS I will try that immediately!
>>> jo.synth@crossnet.at 04/10/03 01:49PM >>>
Overall pots:
| | | ("D#4 - E4") |
| VR1 | | |
Voice pots:
even
I do it this way:
other.
notes.
note
it!
individually!
will
position.
I hope this helps
Johannes
did
VR1,
2003-04-11 by Tony Allgood
> Switch SW1 to front position and enjoy the "Schwebung" (dont know the
I must admit having tuned a few P6s in my time, I prefer the sound of
unstretched tuning on any synth. Whilst I can understand the need to
stretch tune pianos, I don't really see the point of doing this to VCOs.
The harmonics are locked to the fundamental whatever the base frequency
is tuned to.
I tuned my own P6 to true linear fashion. The sound of it fitted in
better into my mixes, and it sounded better on its own.
Tony Allgood Penrith, Cumbria, England
Oakley Sound Systems www.oakleysound.com
Modular Synthesisers www.oakleysound.com/projects.htm
2003-04-11 by David Davis
Yeah, this sounds wierd to me?!
Pianos get stretch-tuned because their strings don't
behave like perfect linear harmonic oscillators,
so the harmonics generated by strings are slightly
sharp (? I think it is...)
If you didn't stretch tune it, you'd hear (for instance)
beats when you play a simple octave, as the 1st harmonic
on the lower note would be out of tune with the fundamental
of the upper note...
....but the Polysix's VCOs surely produce sawtooth
and rectangle waves where the harmonics are linear?
Thus there'd be no need for stretch tuning...
Unless the PS-6 VCOs are a bit wierd!?
Personally, I'm no great fan of equal temperament,
and love mucking around with microtunings and stuff -
but the PS6 stretch-tuning calibration doesn't sound
like the ability to alter temperament (ie, change the
value of the various "semitones" in the scale) ...
--- Tony Allgood <oakley@techrepairs.freeserve.co.uk>
wrote: > > Switch SW1 to front position and enjoy the
"Schwebung"
> (dont know the
> the sound of
> the need to
> doing this to VCOs.
> base frequency
> is tuned to.
> fitted in
Yahoo! Plus
Re: Tuning
2003-04-11 by ghwelles
OK Johannes, I tried your tuning method . . . and it WORKS! My Synth
now is in tune. THANKS. They should call you, like Steve Martin's
heroic dog, "Lifesaver".
--- In PolySix@yahoogroups.com, Johannes Hausensteiner <jo.synth@c...>
> Overall pots:
> | | | ("D#4 - E4") |
> | VR1 | | |
> Voice pots:
finished
high
pitch
even
> I do it this way:
position
other.
low/high
> notes.
to
note
need
> it!
to
individually!
will
This
position.
> I hope this helps
> Johannes
did
are VR1,
Tuning
2006-04-23 by sdlarch1
I am having a terrible time tuning my PolySix. I can get all 6 banks
in tune with each other no problem.
I cannot get C0, C3, and C6 in tune at the same time. To keep
consistency, I checked each C on the same bank.
I've been through the calib procedure to no avail.
Can someone guide me to a potential point of failure?
Re: Tuning
2006-04-24 by gil_we
Try to get only the first oscillator in tune first.
GENTLY take all SSM's out except of the first oscillator,a
and press the Unison key. Now you can hear sound with every note you
play.
Use VR11, VR12, VR1, VR3, VR15 to get the scale perfect.
This is a lot of trial and error. Start with positioning them all to
the center. Use VR15 from time to time to correct to the right pitch of
A440 for example.
Let me know how it works.
2006-04-26 by Sam Larch
You mean VR 10 instead of 12, right?
It's like I don't have enough throw in the pots. The most logical approach
I see is that I would center all VRs 1, 3, 10, 11, & 15 - and then use vr15
to center C3. With these settings, C1 is way (+200 cents) sharp, and C6 is
way (-200 cents) flat. I can't swing tune high and low far enough apart to
get the complete range in tune.
What damage could be caused by adding resistance to the pots (high and low)
to get more swing out of them?
> play.
> A440 for example.
> YAHOO! GROUPS LINKS
> - Visit your group "PolySix <http://groups.yahoo.com/group/PolySix>"
> on the web.
> - To unsubscribe from this group, send an email to:
> PolySix-unsubscribe@yahoogroups.com<PolySix-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> - Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service <http://docs.yahoo.com/info/terms/>.
You know, I got those backwards. The low end is flat and the high end is
sharp.
> approach I see is that I would center all VRs 1, 3, 10, 11, & 15 - and then
> use vr15 to center C3. With these settings, C1 is way (+200 cents) sharp,
> and C6 is way (-200 cents) flat. I can't swing tune high and low far enough
> apart to get the complete range in tune.
> low) to get more swing out of them?
> > play.
> > A440 for example.
> > YAHOO! GROUPS LINKS
> > - Visit your group "PolySix<http://groups.yahoo.com/group/PolySix>"
> > on the web.
Re: Tuning
2006-05-06 by darke_one666
change the opto on the filter pcb, I'll put money on it
Re: Tuning
Change the opto, this usually causes the tunig to be impossible to
set up..
approach
use vr15
and C6 is
apart to
and low)
> On 4/24/06, gil_we <gil_we@...> wrote:
banks
you
> > play.
to
pitch of
> > A440 for example.
> > YAHOO! GROUPS LINKS
> > on the web.
