MG / LFO Q1 transistor replacement.
2014-03-09 by <josh.nursing@gmail.com>
Archive for polysix.
2014-03-10 by <backshall1@bellsouth.net>
2014-03-10 by Bob Grieb
2014-03-10 by Adrian Corston
On 10/03/14 1:14 PM, backshall1@bellsouth.net wrote:
The 2SK and 2N parts have different pin-outs. The clone board is designed for a 2N transistors. To put one on an old original KLM-367 you would have to do the “crossed legs” thing. Actually, I think the Gate is still in the middle, so you would just put it in backwards, no bent legs, just reversed Source and Drain. I’ve been using 2N3819 without problems on the clone boards, and it still seems to be available at Mouser in the US. You could always be the first to try 2N7000 and let us know. I don’t know enough about FET characteristics to say what the 7000 would do in this circuit. DIYstompboxes.com has some discussion about what other people have tried as a replacement for 2SK30A in some guitar pedals.Don BackshallFrom: josh.nursing@gmail.comSent: Sunday, March 9, 2014 11:51 AMSubject: [PolySix] MG / LFO Q1 transistor replacement.
2014-03-10 by Bob Stewart
2014-03-10 by <josh.nursing@gmail.com>
2014-03-10 by Chromatest J. Pantsmaker
On Mon, Mar 10, 2014 at 9:39 AM, <josh.nursing@gmail.com> wrote:
Don, true for being careful about the pinout: I did the cross-legged thing with a transistor in my Poly-800 but I don't like it much as between the legs and the sheath, there's not much clearance unless you do some careful leg twisting.Bob, thanks for the pointer about using another JFET and not a MOSFET. The MPF102 seems to fit.Tayda is very cool, although they don't have everything I would have liked. Futurlec beats them on price on the SK this time.Thanks all.
2014-03-11 by <josh.nursing@gmail.com>
2014-03-15 by The Old Crow
On 3/9/2014 10:51 AM, josh.nursing@gmail.com wrote:
What would be a good replacement for Q1 in the MG circuit?
The original seems to be 2SK30A.
Jed's updated parts list for the clone suggests a 2N7000 (not tested I think).
From some web research, a substitute may be the MPF102.
Would these last two work?
2014-03-15 by <josh.nursing@gmail.com>
2014-03-15 by <chipaudette@yahoo.com>
2014-03-24 by <josh.nursing@gmail.com>
2014-03-25 by <josh.nursing@gmail.com>
