Index last updated: 2026-04-05 20:27 UTC
1 OCT vs 2 OCT
1 OCT vs 2 OCT
2007-12-10 by mathroutine
how obvious is the difference between the 1 OCT and 2 OCT setting?
When I have only the sub osc playing (PW all the way to the right) I
can't hear the difference when I change the switch. I think maybe my 2
OCT is burnt out or something? Thanks.
Re: [PolySix] 1 OCT vs 2 OCT
2007-12-10 by jure zitnik
it could be a battery leak problem, i had this switch malfunctioning as well.
jure
> PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6
Re: 1 OCT vs 2 OCT
2007-12-11 by dizz662000
Hi Math,
  It's very obvious. With those settings, going from 1 OCT to 2 OCT
should drop down an octave. Sounds like you have a problem. You might
try cleaning the switch to start with.
regards,
dizz
