polysix -- What does IC 31 on KLM-367 do?
2007-11-09 by spistrich
Index last updated: 2026-04-28 23:40 UTC
does anyone know what IC 31... on board klm-367 does? it would be the first chip to be damaged from the acid leak....it is a 74LS08 type chip. readily available from Digikey, but I really would like to know what functions it controls. this info might help explain my polysix's odd behavior after battery leakage rather than just blaming the traces.
2007-11-09 by Chromatest J. Pantsmaker
It's probably the traces... unless the corrosion has leached into that chip. Personally, I've not seen anything "break" inside a P6 other than the corrosion and normal wear and tear. Sorry I can't help answer your actual question though. On 11/9/07, spistrich <wasteking@verizon.net> wrote: > does anyone know what IC 31... on board klm-367 does? it would be the > first chip to be damaged from the acid leak....it is a 74LS08 type > chip. readily available from Digikey, but I really would like to know > what functions it controls. this info might help explain my polysix's > odd behavior after battery leakage rather than just blaming the traces. > > > > PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6 > Yahoo! Groups Links > > > > -- .sig -Chromatest J. Pantsmaker http://www.chromatest.net
2007-11-09 by klosmon
At 10:55 AM 11/9/2007, you wrote: >does anyone know what IC 31... on board klm-367 does? it would be the >first chip to be damaged from the acid leak....it is a 74LS08 type >chip. readily available from Digikey, but I really would like to know >what functions it controls. this info might help explain my polysix's >odd behavior after battery leakage rather than just blaming the traces. Look at the schematic (and by the way, it's pretty much impossible to achieve any successful repairs on the P6 without referring to the schematics) -- ICs 31 & 30 are quad AND gates, basically serving to buffer the eight data lines between the CPU chip and the rest of the circuitry. Each of these lines is crucial to the correct performance of the synth; if any one is missing or shorted, it can cause any number of malfunctions of the front panel, memory, patch control voltages, etc. Also note that each data line connects to numerous points on the board; even if most of them are good, having only one missing can still cause havoc. The easiest way to observe all this is with a scope; referring to the schematic, view each line starting at the CPU & continuing to the IC30 (or 31) input, then from the IC30 or 31 output to the other indicated points. Any bad or missing signal should be immediately obvious. Note that the 4042 latch "IC34" on the schematics is labelled incorrectly; it should be IC24. The lengthier process is to use your meter in continuity mode (this, of course, is done with the power off); check for proper continuity for each data and address line (for example, pin 12 of the CPU should connect to pin 4 of IC 31 and to pin 14 of the RAM chip; pin 6 of IC 31 should connect to IC26 pin 13, to connector CN06 pin 3, IC28 pin 4, etc etc etc). It sometimes happens that IC31 (or one of the other CMOS chips in the battery leak area) is indeed dead; but the most frequent cause of nonfunction is a bad circuit trace. ~GMM (repairing battery-damaged PolySixes for longer than I'd care to think about) > > >No virus found in this incoming message. >Checked by AVG Free Edition. >Version: 7.5.503 / Virus Database: 269.15.26/1119 - Release Date: >11/8/2007 5:55 PM ---------- No virus found in this outgoing message. Checked by AVG Free Edition. Version: 7.5.503 / Virus Database: 269.15.26/1119 - Release Date: 11/8/2007 5:55 PM [Non-text portions of this message have been removed]
--- In PolySix@yahoogroups.com, "Chromatest J. Pantsmaker" <chromatest@...> wrote: > > It's probably the traces... unless the corrosion has leached into that > chip. Personally, I've not seen anything "break" inside a P6 other > than the corrosion and normal wear and tear. > > Sorry I can't help answer your actual question though. > > On 11/9/07, spistrich <wasteking@...> wrote: > > does anyone know what IC 31... on board klm-367 does? it would be the > > first chip to be damaged from the acid leak....it is a 74LS08 type > > chip. readily available from Digikey, but I really would like to know > > what functions it controls. this info might help explain my polysix's > > odd behavior after battery leakage rather than just blaming the traces. > > > > > > > > PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6 > > Yahoo! Groups Links > > > > > > > > > > > -- > .sig > -Chromatest J. Pantsmaker > http://www.chromatest.net > `well, the reason im wondering about IC 31 is that in the repair exaple shown on the Old Crow synth repair site...he said he had to replace the IC 31 in addition to trace repair, but didnt describe what the problem with the chip was.....i can understand how corroded traces could loose continuity...a couple did on my polysix, but the odd behavior i see is almost like 'too much' continuity-- things that dont turn off. this could be explained by conductive acid getting into the IC... Because i cant see a problem with the traces now, and continuities are fine. The replacement 74LS08 chip is cheap ...and i would have to pull the old one to check/repair the traces under it. I just wonder what the IC 31 does? does it control track selection and/or memory to tape download ? (p.s. i have had to replace voice chips on a dead voice...but the LED's in each voice channel made diagnosing that easy.)
