Index last updated: 2026-04-03 18:16 UTC
Trident mkI filter problem
2007-08-23 by roisto
I just got this synth and it has something wrong with 7th and 8th
voices. When i´m adjusting eg intensity, filters for the last two
voices are working opposite way :) i opened it and found that all the
vcf:s were SSMT2044 except voice 8 wich was SSM2044 (maybe someone
has changed one or all of them?!) and MC14066B chip at the 8th voice
has been replaced with F 4066BPC (having "indiana" text on it)..
anyways battery was brand new inside the trident, and everything else
seems to work 100%. Any ideas how to fix this?
Re: Trident mkI filter problem
2007-08-25 by gil_we
What do you mean by "opposite way" ??
The replacements seems fine to me.
2007-09-20 by roisto
I mean that filter of the last two oscillators has somehow turned to
work negative. When cutoff filter is opened, one oscillator plays it
closed (like lowpass effect), and vice versa, when filter is closed,
one oscillator plays filter totally opened. Two modes at the Eg-mode
seems to change this effect between 7th and 8th osc. Thank you for
you reply.
-t
someone
voice
else
2007-10-05 by gil_we
Does it happen only to one of the 8 oscillators ? if so, replace its
SSM2044 chip....
to
it
closed,
mode
> you reply.
> -t
8th
two
all
> the
> someone
> voice
it)..
everything
> else
2007-10-08 by roisto
thanks, i will try that. it does happen with 7th and 8th oscillators,
but only one at time. changing eg-mode seems to affect wich one is
malfunctioning.
> SSM2044 chip....
> to
> it
> closed,
> mode
> > you reply.
> > -t
> 8th
> two
> all
> > the
> > someone
> > voice
> it)..
> everything
> > else
2007-10-09 by gil_we
Very strange.... any battery leakage ?
Also, you may want to try to replace any logic IC connected directly
with the problematic control, placed on the front panel's pcb...
oscillators,
> malfunctioning.
its
> > SSM2044 chip....
turned
> > to
plays
> > it
> > closed,
> > mode
for
> > > you reply.
> > > -t
and
> > 8th
last
> > two
that
> > all
> > > the
> > > someone
8th
> > > voice
> > it)..
> > everything
> > > else
2008-03-06 by roisto
fixed! my friend specialized to repair old gear replaced some IC´s. he
told me that someone has earlier tried to fix it also, and there was
some amateur-soldering made. someone had manually, by soldering,
tresspassed two IC´s functions. how weird is that :)
thanks for helping!
> oscillators,
> > malfunctioning.
> its
> > > SSM2044 chip....
> turned
> > > to
> plays
> > > it
> > > closed,
> > > mode
> for
> > > > you reply.
> > > > -t
> and
> > > 8th
> last
> > > two
> that
> > > all
> > > > the
> > > > someone
> 8th
> > > > voice
> > > it)..
> > > everything
> > > > else
