Index last updated: 2026-04-28 23:40 UTC
fault location advice needed
2006-01-30 by jure zitnik
here's the thing:
i'm not repairing the polysix myself but i'm still pretty involved
since the man repairing it doesn't have that much experience with
analogue synths. and i have zero experience with actual physical work
on synths :/
so - the polysix:
the battery leaked but the traces were repaired. this guy probably did
it all correctly but i'm not 100% sure. let's say they're alright now.
we also replaced IC31 (the lower of the 2 identical 4xAND gates) but
the symptoms are still the same as they were before the repair:
- synth usually works okay for the first half hour or so. except the
patch storage.
- patch programmer: bank 3 and prog 3 are lit all the time. you can
select another bank and program but nothing can be saved.
- the attenuator 13 way switch doesn't work at all.
- after some time other controls stop responding (and stay like they
were set): waveform selector, VCA gate mode and effect selector.
- usually when this happens some program and bank leds (actually bank
1 and 2 and program 2) start dimly blinking like there's some short
circuit or something. this gives me doubts whether it's really CPU
(IC21) fault. if it were faulty it would probably just die or
something... right?
so - what would you guys check next? how possible do you think it is
that it's the CPU? what about the 18-pin SRAM IC? any other ICs that
usually fail?
i really appreciate your help so far!
thanks!
jure
Re: fault location advice needed
2006-01-30 by gil_we
It sounds like the KLM-267A is not fully functioning yet
--- In PolySix@yahoogroups.com, jure zitnik <kokoon@g...> wrote:
> here's the thing:
work
> on synths :/
> so - the polysix:
did
now.
> patch storage.
bank
> something... right?
> usually fail?
> thanks!
> jure
Re: [PolySix] Re: fault location advice needed
you mean KLM-367?
i wonder what could cause that led flashing?
jure
> > here's the thing:
> work
> > on synths :/
> > so - the polysix:
> did
> now.
> > patch storage.
> bank
> > something... right?
> > usually fail?
> > thanks!
> > jure
> PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6
Yah I ment 367...
It looks like it hasn't be 100% repaired...
Can you see corrosion on other boards as well ?
> you mean KLM-367?
> jure
> > > here's the thing:
involved
with
> > work
> > > on synths :/
> > > so - the polysix:
probably
> > did
alright
> > now.
gates) but
except the
> > > patch storage.
can
they
> > bank
short
CPU
> > > something... right?
it is
that
> > > usually fail?
> > > thanks!
> > > jure
> > Yahoo! Groups Links
no not on other boards. just the 367. but that one's also cleaned now
and all...
> Yah I ment 367...
> > you mean KLM-367?
> > jure
> > > > here's the thing:
> involved
> with
> > > work
> > > > on synths :/
> > > > so - the polysix:
> probably
> > > did
> alright
> > > now.
> gates) but
> except the
> > > > patch storage.
> can
> they
> > > bank
> short
> CPU
> > > > something... right?
> it is
> that
> > > > usually fail?
> > > > thanks!
> > > > jure
> > > Yahoo! Groups Links
2008-01-20 by Daniel Akzinor
This describes my problem exactly... Did you ever find a fix?
- Daniel
--- In PolySix@yahoogroups.com, jure zitnik <kokoon@...> wrote:
> here's the thing:
work
> on synths :/
> so - the polysix:
did
now.
> patch storage.
bank
> something... right?
> usually fail?
> thanks!
> jure
2008-01-21 by jure zitnik
yes, i've fixed it eventually. i've posted this a few times already
but here goes again:
REMOVE all the traces that look even remotely damaged by the battery
leak. seriously. just jumping them won't do it, you have to REMOVE
them. i dug them out with an exacto, just like old crow says.
i also replaced the resistor array in that area.
make sure you assemble the programmer switch board so, that none of
the keys are too tightly pressed to the frontpanel, at one point i
found out that was causing my problem of some LEDs being lit all the
time (keys were actually pressed)
and, once more, REMOVE EVERY SINGLE TRACE that looks corroded.
good luck!
jure
> - Daniel
> > here's the thing:
> work
> > on synths :/
> > so - the polysix:
> did
> now.
> > patch storage.
> bank
> > something... right?
> > usually fail?
> > thanks!
> > jure
