I have isolated the problem to the MG section - the patches will not hold in memory (new
board, new battery) correctly; when the patch is first heard it has distortion and long
release, which can be changed by turning off the level in the mod section (causing most of
the problem). This was the same problem I had prior to the battery issue which was fixed.
The tuning issue seems to have subsided. Can anyone figure out what may be going
wrong here? The patches will not hold the MG settings though either, or the release...
--- In PolySix@yahoogroups.com, "Mike Thompson" <tubmyk2@...> wrote:
> Ugh.. ok. I re-tuned the oscillators today, but I was noticing the other day that the
> patches all are messed up, have max. release time and are distorted. WTF?? So I
retuned
> everything, and it seems a little better but do I need to have factory patches reloaded?
> They were loaded previously by the tech who replaced my KLM board. What should I do?
