Index last updated: 2026-04-03 01:39 UTC
Tuning problem on Polysix
2006-06-25 by Mike Thompson
I recently had my Polysix KLM-367 board serviced through Old Crow (replacement, rather)
and just got it back a few days ago.  Unfortunately I needed to re-calibrate the oscillators
and tune them since it sat for so long not being used.  But the tuning is still off - not really
a seperate oscillator problem so much as I can't get it to the right pitch using the tune
knob.  Even at the max to the right (sharp) I cannot get the unit to hit a perfect a-440.
And just to clear up the dummy-factor, I even made sure that the tune knob was set at
dead-center when I began the oscillator tuning, so i would have flexibility in both
directions if the tuning shifted.  I am about to re-do the process but I am curious if
anyone else has suggestions as to why this may happen even though I kept the pot at the
center?  Any help is appreciated, thanks.
~Mike
Re: [PolySix] Tuning problem on Polysix
2006-06-26 by Sam Larch
You can check the message history to find that a few P6 owners are having a
tuning problem.  The most likely culprit, it seems, is that an opto-isolator
(HTV-P1501) has failed which in turn is rendering the tune-high useless...so
the board won't tune correctly.
I've been unable to find a replacement opto-isolator - or a datasheet even.
If you - or anyone else for that matter - finds a supplier for these ICs, or
has a replacement circuit (even better) please let us all know.
> using the tune
> perfect a-440.
> was set at
> flexibility in both
> curious if
> the pot at the
> ~Mike
2006-06-26 by Johannes Hausensteiner
search the message archive for a message from Peter Andersson on
Tue Feb 10, 2004 3:30 pm (msg #646). He had the same problem and
found a replacement part for the opto isolator. I downloaded the
data sheet then. Now I have uploaded it to the files section of
the list.
Cheers,
Johannes
>>using the tune
>>perfect a-440.
>>was set at
>>flexibility in both
>>curious if
>>the pot at the
>>~Mike
> PolySix "Digiest" Page: http://www.acc.umu.se/~amber/Poly6
Re: Tuning problem on Polysix
2006-06-26 by Mike Thompson
Ok thanks.  It makes sense I guess, but I'm probably going to try tuning it one more time
because I really don't feel like putting any more effort into this keyboard if I can help it.  I
just got an OB-8 so I really don't need the P6, but I like the arpeggiator and SSM sound so
that's why I keep it around.  Any idea how much that part cost anyway?
--- In PolySix@yahoogroups.com, Johannes Hausensteiner <johau@...> wrote:
> Hi,
> the list.
> Cheers,
> Johannes
> >>using the tune
> >>perfect a-440.
> >>was set at
> >>flexibility in both
> >>curious if
> >>the pot at the
> >>~Mike
> > Yahoo! Groups Links
Re: [PolySix] Re: Tuning problem on Polysix
http://www.google.at/search?hl=de&q=VTL5C3&btnG=Google-Suche&meta=
>>Hi,
>>the list.
>>Cheers,
>>Johannes
>>>>using the tune
>>>>perfect a-440.
>>>>was set at
>>>>flexibility in both
>>>>curious if
>>>>the pot at the
>>>>~Mike
>>>Yahoo! Groups Links
