Tronspotting Camel again
2010-01-14 by markpringnz
Index last updated: 2026-03-31 23:34 UTC
2010-01-14 by lsf5275@aol.com
My memory is going off a bit, probably the smell of roasted mouse shit coming out of the tron, so if I have asked this before forgive me.
http://www.youtube. com/watch? v=lST4QCeQsCc& feature=related
The kink should take you to Golf Girl by Camel. Until recently I would have sworn they were using Mark II 3 violins.
It isn't listed at Planet Mellotron, so is it tron an unusual use if so.
--- In newmellotrongroup@yahoogroups.com, lsf5275@... wrote:
> Sorry Mark, that's Caravan. Camel did "Badminton Boy."
> In a message dated 1/13/2010 7:30:26 P.M. Eastern Standard Time,
> markpringnz@... writes:
> _http://www.youtube.http://wwwhttp://www.yo&<WBR>feature=re_
> (http://www.youtube.com/watch?v=lST4QCeQsCc&feature=related)
2010-01-14 by Rick Blechta
Yes, and they all went to jail for it because he was underage!Sorry Mark, that's Caravan. Camel did "Badminton Boy."
2010-01-14 by Andy Thompson
To: <newmellotrongroup@yahoogroups.com>
Sent: Thursday, January 14, 2010 12:24 AM
Subject: [newmellotrongroup] Tronspotting Camel again
It is if you look at Caravan :-)
Andy T.
2010-01-15 by lsf5275@aol.com
To: <newmellotrongroup@ yahoogroups. com>
Andy T.
2010-01-15 by David Jacques
2010-01-15 by Mark Pring
--- On Fri, 1/15/10, lsf5275@aol.com <lsf5275@aol.com> wrote:
Subject: Re: [newmellotrongroup] Tronspotting Camel again
To: newmellotrongroup@yahoogroups.com
Date: Friday, January 15, 2010, 2:51 PM
Mark turned his brain on and started typing without allowing for a sufficient time to warm up and get his mental flywheel up to speed. ;-)In a message dated 1/14/2010 7:02:24 P.M. Eastern Standard Time, andy.thompson@ virgin.net writes:
Andy T.
2010-01-15 by Fritz Doddy
On Jan 14, 2010, at 9:36 PM, David Jacques <djacques@csulb.edu> wrote:
Just returned from my first day at NAMM, Saw Markus with the new
digital Mellotron. It sounds and plays great. Although it is still in
prototype stage you can play two sounds on it (3 Violins and Flute).
Eventually he will have over 100 loaded (including the entire
mellotron, optigin, and chamberlin sounds). What is REALLY cool is
that he uses the original SM400 keyboard... Completely wood with the
same length all the way back into the keyboard cartridge. in fact it
looks and feels exactly like a Mellotron keyboard unit. Completely
built out of wood and metal like the original, Very nice.
It was sitting in top of his new Mellotron and it sounded identical.
He said that he is looking at production models in two or three months.
--- On Fri, 1/15/10, David Jacques <djacques@csulb.edu> wrote:
Subject: [newmellotrongroup] NAMM Report
Date: Friday, January 15, 2010, 3:36 PM
Can't see the advantage of having a mellotron keyboard action, it's horrible! A nice weighted keyboard action would have been better. I suppose if you are used to tron action you might prefer it, but if you are used to tron action you probably won't be buying one of these.
To: newmellotrongroup@ yahoogroups. com
Subject: Re: [newmellotrongroup] NAMM Report
Date: Friday, January 15, 2010, 4:42 PMI was referring to the NEW mellotron keyboard that Markus designed for his Model 400. That has a pretty good feel to it. There is no way I would want to gig with my original SM400 keyboard!
On Jan 14, 2010, at 7:35 PM, Mark Pring wrote:Can't see the advantage of having a mellotron keyboard action, it's horrible! A nice weighted keyboard action would have been better. I suppose if you are used to tron action you might prefer it, but if you are used to tron action you probably won't be buying one of these.
2010-01-15 by ClayE
--- In newmellotrongroup@yahoogroups.com, Mark Pring <markpringnz@...> wrote:
> I haven't played one of those, how does it compare to an M4000?
> --- On Fri, 1/15/10, David Jacques <djacques@...> wrote:
> From: David Jacques <djacques@...>
> Â
> I was referring to the NEW mellotron keyboard that Markus designed for his Model 400. That has a pretty good feel to it. There is no way I would want to gig with my original SM400 keyboard!Â
> From: David Jacques <djacques@csulb. edu>
> Â
> Just returned from my first day at NAMM, Saw Markus with the newÂ
> digital Mellotron. It sounds and plays great. Although it is still inÂ
> prototype stage you can play two sounds on it (3 Violins and Flute).Â
> Eventually he will have over 100 loaded (including the entireÂ
> mellotron, optigin, and chamberlin sounds). What is REALLY cool isÂ
> that he uses the original SM400 keyboard... Completely wood with theÂ
> same length all the way back into the keyboard cartridge. in fact itÂ
> looks and feels exactly like a Mellotron keyboard unit. CompletelyÂ
> He said that he is looking at production models in two or three months.Â
--- On Fri, 1/15/10, ClayE <ecclesreinson@rogers.com> wrote:
Remember that "WTF!" moment when you first played one?
--- In newmellotrongroup@ yahoogroups. com, Mark Pring <markpringnz@ ...> wrote:
> --- On Fri, 1/15/10, David Jacques <djacques@.. .> wrote:
> From: David Jacques <djacques@.. .>
> Â
> Â
2010-01-15 by mattias
Maybe the action on yours is horrible. The actions on the ones I own and have worked on are very light and very fast.
In a message dated 1/14/2010 10:35:15 P.M. Eastern Standard Time, markpringnz@yahoo.com writes:
2010-01-15 by tronbros@aol.com
Hi Frank,
My tron playing experience is limited to 2 machines. The first mellotron I played was the first production model of the M4000 shortly before it was shipped. I have always assumed that the keyboard action of that machine was correctly adjusted.
I have spent many happy hours working on the keyboard of #1565 which is the second mellotron I played, I have aimed to get a similar action to the M4000 and have largely succeeded. I don't think it is quite as light as the M4000 but certainly it's a lot different to what I started out with which was much worse, playing it then was quite a good upper body work out.
I would be interested to compare both machines to a Mark VI but the photos I have seen don't suggest that the feel would be much different.
I can't remember who said it but playing a mellotron and certainly the M4000 I played can only be described as playing a sponge.
Don't get me wrong, I love my mellotron but I am not blind to its limitations. Compared to playing a piano or a good weighted action keyboard it has the action from hell. Just my opinion.
Mark
Date: Friday, January 15, 2010, 7:22 PM
Maybe the action on yours is horrible. The actions on the ones I own and have worked on are very light and very fast.In a message dated 1/14/2010 10:35:15 P.M. Eastern Standard Time, markpringnz@ yahoo.com writes:Can't see the advantage of having a mellotron keyboard action, it's horrible!
That is why when I record I only use samples and a nice midi keyboard and then at parties I pull out the Mellotron and play a bad version of Nights in white satin and Strawberry fields forever. It works great for me !
2010-01-15 by Tron400
> horrible!
2010-01-15 by Tom Doncourt
I have no complaints with my mellotron action, it’s distinct to itself and makes me feel very aware of the tapes underneath it. I hate playing mellotron samples on a cheap plastic remote keyboard.It seems considerate to me to use a similar action to the original on a dedicated digital mellotron, I would want this thing to be as close to the original instrument as possible in every way (except the weight and bulk).
The Nord wave also promised the entire Mellotron and Chamberlin library but has never actually come through on this to my knowledge.
There are many issues involved in getting the keyboard right. I can assure you that there is no "spongy" feel to my M4000 keyboard, nor could that term be used to describe the feel of the keyboards of the machines coming out of my shop.
In a message dated 1/15/2010 3:46:54 A.M. Eastern Standard Time, markpringnz@yahoo.com writes:
Just remembered- I‘m wrong about Nord-Wave and the Chamberlin sounds, Clavia never got those.
2010-01-15 by John Wright
In a message dated 1/15/2010 3:46:54 A.M. Eastern Standard Time, markpringnz@ yahoo.com writes:
2010-01-15 by djacques@csulb.edu
Sent via BlackBerry from T-Mobile
Yes, but the sound makes up for it, it's beyond me why anybody would want that kind of keyboard action playing samples.
> Â
> Â
2010-01-15 by ClayE
> Hi Frank,
> I have spent many happy hours working on the keyboard of #1565 which is the second mellotron I played, I have aimed to get a similar action to the M4000 Â and have largely succeeded. I don't think it is quite as light as the M4000 but certainly it's a lot different to what I started out with which was much worse, playing it then was quite a good upper body work out.
> Mark
> --- On Fri, 1/15/10, lsf5275@... <lsf5275@...> wrote:
> From: lsf5275@... <lsf5275@...>
> Â
> Â
> Can't
Any guesses as to the price on this machine?- I could see having it for live and an m4000 for studio use but the price would be a definite factor.
I believe that Markus has achieved what you may be looking for. The digital tron keeps the authentic feel of the original all the way down to the wood and paint of the cabinet.
Date: Fri, 15 Jan 2010 09:29:13 -0500
2010-01-15 by fdoddy@aol.com
Yes ,I agree- I feel a little guilt thinking about it.I love the process of the real thing
My Streetly refurb still feels pretty good after, what is it now, 7 years?! I like the fight, the pushback of a tron. It's like playing a guitar through a "gasp" real amplifier. Ya gotta work it.... Samples and a MIDI keyboard are too forgiving. Like the old Italian grandmas say about making risotto, "The rice must feel the pain"
Sent: Fri, Jan 15, 2010 3:42 am
In a message dated 15/01/2010 03:35:16 GMT Standard Time, markpringnz@yahoo.com writes:
Can't see the advantage of having a mellotron keyboard action, it's horrible!Wrong! Yours might be but that doesn't have to be the case!
M
Streetly Electronics - All Things Mellotronic
www.mellotronics.com <http://www.mellotronics.com/> UPDATED
M4000 tour de force - UK trailer http://thebox-movie.warnerbros.com/
US Sales East: Jimmy Moore JMoore6397@aol.com <http://JMoore6397@aol.com/>
US Sales West: Paul Cox pjc56@earthlink.net <http://pjc56@earthlink.net/>
Chloe Smith: myspace.com/chloesmithmusic <http://myspace.com/chloesmithmusic>
> I think someone posted $1,600-$1,900.00
> In a message dated 1/15/2010 11:18:39 A.M. Eastern Standard Time,
> tomdcour@... writes:
I'd be surprised if it was that cheap. Didn't someone post $2700? That seems more likely, but even that could be low.
Bernie
--- In newmellotrongroup@ yahoogroups. com, lsf5275@... wrote:
> I think someone posted $1,600-$1,900. 00
Its a lot lower than that.
Bernie
--- In
lsf5275@... wrote:
>$1,600-$1,900. 00
2010-01-15 by Chris Dale
On Fri, Jan 15, 2010 at 12:48 PM, Tron400 <kornowicz@cox.net> wrote:
I'd be surprised if it was that cheap. Didn't someone post $2700? That seems more likely, but even that could be low.> I think someone posted $1,600-$1,900.00
> In a message dated 1/15/2010 11:18:39 A.M. Eastern Standard Time,> tomdcour@... writes:
2010-01-15 by gino wong
On Fri, Jan 15, 2010 at 1:39 PM, John Wright <john.wright@consona.com> wrote:
If true, Memotron is done for. Markus will hit a home run if pricing is that low.
From: newmellotrongroup@yahoogroups.com [mailto:newmellotrongroup@yahoogroups.com] On Behalf Of djacques@csulb.edu
Sent: Friday, January 15, 2010 1:32 PM
Subject: Re: [newmellotrongroup] Re: NAMM ReportIts a lot lower than that.
From: "Tron400" <kornowicz@cox.net>Date: Fri, 15 Jan 2010 17:48:51 -0000Subject: [newmellotrongroup] Re: NAMM Report
Bernie
魚手
Gino Wong
Employee
LBPH
(800) 222-1754
wongg@freelibrary.org
ginowong@gmail.com
The information contained within the referenced, linked, or directed email communication is intended to be a confidential communication between the original sender and recipient, and is to be treated as confidential. All works, ideas, or copy within are copyrighted by by Gino Wong Birgelo, the Wong Family Music Publishing Trust and Canicopia.com, and are not to be used in any manner other by which they were intended by Gino Wong Birgelo and authorised affiliated associates. Misuse of this communication may result in civil or criminal action.
2010-01-15 by Mattias Olsson
----- Original Message -----From: John WrightSent: Friday, January 15, 2010 7:39 PMSubject: RE: [newmellotrongroup] Re: NAMM Report
From: newmellotrongroup@ yahoogroups. com [mailto:newmellotro ngroup@yahoogrou ps.com] On Behalf Of djacques@csulb. edu
From: "Tron400" <kornowicz@cox. net>Date: Fri, 15 Jan 2010 17:48:51 -0000To: <newmellotrongroup@ yahoogroups. com>Subject: [newmellotrongroup] Re: NAMM Report
Bernie
----- Original Message -----From: gino wongSent: Friday, January 15, 2010 7:50 PMSubject: Re: [newmellotrongroup] Re: NAMM ReportIt is nothing but a ROMpler, it should be cheap. Until there is a breakthrough it has the same limitations and annoyances and excellent capabilities of a wavetable instrument or a sampler
The Streets could have (did) done it a long time ago. If they wanted to but they obviously knew what they were doing and why.
On Fri, Jan 15, 2010 at 1:39 PM, John Wright <john.wright@ consona.com> wrote:
From: newmellotrongroup@ yahoogroups. com [mailto:newmellotrongroup@ yahoogroups. com] On Behalf Of djacques@csulb. edu
From: "Tron400" <kornowicz@cox. net>Date: Fri, 15 Jan 2010 17:48:51 -0000Subject: [newmellotrongroup] Re: NAMM Report
Bernie
魚手
Gino Wong
Employee
LBPH
(800) 222-1754
wongg@freelibrary. org
ginowong@gmail. com
2010-01-15 by Pomeroy RH Ranch
From: newmellotrongroup@yahoogroups.com [mailto:newmellotrongroup@yahoogroups.com] On Behalf Of fdoddy@aol.com
Wrong! Yours might be but that doesn't have to be the case!In a message dated 15/01/2010 03:35:16 GMT Standard Time, markpringnz@ yahoo.com writes:Can't see the advantage of having a mellotron keyboard action, it's horrible!MStreetly Electronics - All Things Mellotronic
www.mellotronics. com UPDATED
M4000 tour de force - UK trailer http://thebox- movie.warnerbros .com/
US Sales East: Jimmy Moore JMoore6397@aol. com
US Sales West: Paul Cox pjc56@earthlink. net
Chloe Smith: myspace.com/ chloesmithmusic
2010-01-15 by Hessel Herder
I think...if it sounds and feels like a Mellotron with 100 sounds and its portable...I think a lot of people would be interested.It could actually not only affect the memotron but the whole used market as well.Buying a Chamberlin M1 for 7000 dollars wont really make as much sense anymore...But keep it a secret...// Mattias----- Original Message -----From: John WrightSent: Friday, January 15, 2010 7:39 PMSubject: RE: [newmellotrongroup] Re: NAMM Report
From: newmellotrongroup@ yahoogroups. com [mailto:newmellotro ngroup@yahoogroups.com] On Behalf Of djacques@csulb. edu
Bernie
On Fri, Jan 15, 2010 at 1:52 PM, Mattias Olsson <Mattias.olsson5@comhem.se> wrote:
Bernie
On Fri, Jan 15, 2010 at 2:18 PM, Pomeroy RH Ranch <punchbowl4@earthlink.net> wrote:
[Attachment(s) from Pomeroy RH Ranch included below]
My last turn at a Mellotron was Dave Kean's MkII (I need to get out more often) - I liked the feel well enough. What would you say the comparison is with a Chamberlin M-series?? - I find my M2 not-particularly-light, and having a fairly long key travel -- even when I have it adjusted for attack high on the key stroke, I push pretty far down as a matter of course.For a while now I've had the keyboard partly torn down because I want to replace the rubber key-bumpers (under the front of the key) -- anyone know where I can get these?? Without them, the keyboard looks dishevelled with keys at slightly different heights, some going down further than others, and the keys pushing down a bit crooked. I've attached a couple of small pic files to show what they are. Are there suitable substitutes that could help with the action??Vance ---- my rice must be masochists - no crying, only moans-----Original Message-----
Wrong! Yours might be but that doesn't have to be the case!In a message dated 15/01/2010 03:35:16 GMT Standard Time, markpringnz@yahoo.com writes:Can't see the advantage of having a mellotron keyboard action, it's horrible!MStreetly Electronics - All Things Mellotronic
www.mellotronics.com UPDATED
2010-01-15 by Rick Blechta
M400 violins do not sound identical to the MK II violins
2010-01-15 by tony1
----- Original Message -----From: Chris DaleSent: Friday, January 15, 2010 2:53 PMSubject: Re: [newmellotrongroup] Re: NAMM Report
Nah, I doubt this will make a difference to the "Chamberlin" market. If you ever had one or ever played one you'd know.Chamberlin sounds in a Mellotron do not sound the same as a real Chamberlin - just as the M400 violins do not sound identical to the MK II violins, nor do M300 sounds or MK II sounds sound like a real MK II or M300 if they're coming from an M400.This is my experience playing multiple Chamberlins and Mellotrons over the last 20 years. They're all unique and different.If you really spend time closely listening to all these instruments you can tell.Most people can't because they only use 1 machine at best. No A and B comparison can be made.This new digital version is for a different market anyway.I imagine Markus will continue to build the MK 6 alongside this digital tron, just as Streetly will continue with the M4000.And rightfully so.Anyone wanting authenticity and a product of real quality will buy an original tape version.Anyone wanting the sounds and feel with digital high quality will buy an authorized "tribute version"There's room for both.On Fri, Jan 15, 2010 at 1:52 PM, Mattias Olsson <Mattias.olsson5@ comhem.se> wrote:
Bernie
And rightfully so.
// Mattias
Bernie
--- In newmellotrongroup@yahoogroups.com <mailto:newmellotrongroup%40yahoogroups.com> , lsf5275@... wrote:
Out of curiosity... Do they really feel the same way today seeing a similar product ?John and I are absolutely okay with anyone attempting a digital 'tron and there have been several versions since we did our work many years ago. I still have Norm's plan of attack on reams of paper and when the Memotron arrived it felt like there had been a spy in the cab throughout our meetings!As previously said on many occasions, there are digital emulations of so many instruments including every model of grand piano going BUT people still buy grand pianos. It's the nuances that are missing from these boxes. What makes a Steinway can only be realised through a Steinway itself. Same goes for a 'tron. And what makes a mellotron sound the way it does is FAR MORE complex than replaying a sample every time you press a key. This is just the tip of the iceberg in making a digital 'tron mellotronic in nature. We have been building M4000s and restoring 'trons all the way through the rise of the Memotron, MTron and the rest. I doubt we have lost many orders from serious mellotron devotees to our digital rivals.One day maybe we'll bring out the emulation we have modelled but for now we are happy to machine, drill, tap and bolt metal together. It's hard work and each one is sweat and tears but ultimately it's rewarding if not an easy road to great wealth!Best,MartinStreetly Electronics - All Things Mellotronic
I think it all depends on how it is done. If it is a note for note sample full length...
And if the price is 2700 well..
I use my Mellotrons and old machines in the studio everyday but There are very few of my clients who actually gives a shit if its a Mellotron flute, Flute 2 or a Chamberlin flute. Ill give them suggestions. ..but in the end they decide and they pay the invoices. The people on this list care but in the “real”world a high quality collection of note for note samples in a dedicated machine could go a very long way...
Computers and midi keyboards will never be sexy.
// Mattias
Den 2010-01-15 20.53, skrev "Chris Dale" <unobtainiumkeys@ gmail.com>:
And rightfully so.
// Mattias
From: John Wright <mailto:john. wright@consona. com>
From: newmellotrongroup@ yahoogroups. com [mailto:newmellotron group@yahoogroup s.com] On Behalf Of djacques@csulb. edu
Bernie
--- In newmellotrongroup@ yahoogroups. com <mailto:newmellotron group%40yahoogro ups.com> , lsf5275@... wrote:
But you are correct in general. Would we expect a Strat to sound just like a Les Paul? Same thing with any instrument.
From: djacques@csulb.eduSent: Friday, January 15, 2010 9:27 PMSubject: Re: [newmellotrongroup] Re: NAMM ReportJust spoke to markus. Around 1800 dollars and production in three to four months.
From: mattias <Mattias.olsson5@ comhem.se>Date: Fri, 15 Jan 2010 21:09:51 +0100Subject: Re: [newmellotrongroup] Re: NAMM ReportI think it all depends on how it is done. If it is a note for note sample full length...
// Mattias
And rightfully so.
// Mattias
Bernie
On Fri, Jan 15, 2010 at 3:02 PM, Rick Blechta <rick@rickblechta.com> wrote:
On Jan 15, 2010, at 2:53 PM, Chris Dale wrote:
M400 violins do not sound identical to the MK II violinsUh, Chris, I hate to break this to you: they aren't identical. The M400 violins have a completely different EQ.But you are correct in general. Would we expect a Strat to sound just like a Les Paul? Same thing with any instrument.
Its a lot lower than that.Sent via BlackBerry from T-MobileFrom: "Tron400" <kornowicz@cox. net>Date: Fri, 15 Jan 2010 17:48:51 -0000Subject: [newmellotrongroup] Re: NAMM Report
Bernie
Chris –
Yep – The pins and springs are fine.
I turn off the amp and listen so I have the pinch roller adjustment at the same
barely-disengaged point – amp back on and double
(Message over 64 KB, truncated)
2010-01-15 by tony1
From: fdoddy@aol.comSent: Friday, January 15, 2010 4:25 PMSubject: Re: [newmellotrongroup] Re: NAMM Report
Be very wary of buying anything used unless you have a good tech and know what to look for. If you are looking for something used, see if you can get it in your set up for a while.
Gonna be tough finding something that's over 32 channels that isn't geared more for live unless you've got some bucks to spend.
Please stay away from digital mixers. Yes, they're convenient but sound like shit.
Old Mackie 8-buss mixers still sound nice and you can probably find a side car for them. Mackie Digital 8-buss are absolute nightmares.
New stuff? I'm liking the Chinese made Toft ATB series. They all have a monitor section so a 32 channel board can net you 64 discrete inputs. They sound very nice too for the money.
SSL AWS 900 kicks sublime ass but it's pricey. It would be my desert island desk. We have one at work...maybe they won't miss it :>)
fd-----Original Message-----
Sent: Fri, Jan 15, 2010 3:03 pm
Speaking for myself, I find something interesting in about every musical instrument around.I need a larger mixer (40+ chan) and I would appreciate an honest reccomendation fellas!Thanks in advance,TonyNeve is a bit out of my reach lol.----- Original Message -----From: Chris DaleSent: Friday, January 15, 2010 2:53 PMSubject: Re: [newmellotrongroup] Re: NAMM ReportNah, I doubt this will make a difference to the "Chamberlin" market. If you ever had one or ever played one you'd know.Chamberlin sounds in a Mellotron do not sound the same as a real Chamberlin - just as the M400 violins do not sound identical to the MK II violins, nor do M300 sounds or MK II sounds sound like a real MK II or M300 if they're coming from an M400.This is my experience playing multiple Chamberlins and Mellotrons over the last 20 years. They're all unique and different.If you really spend time closely listening to all these instruments you can tell.Most people can't because they only use 1 machine at best. No A and B comparison can be made.This new digital version is for a different market anyway.I imagine Markus will continue to build the MK 6 alongside this digital tron, just as Streetly will continue with the M4000.And rightfully so.Anyone wanting authenticity and a product of real quality will buy an original tape version.Anyone wanting the sounds and feel with digital high quality will buy an authorized "tribute version"There's room for both.On Fri, Jan 15, 2010 at 1:52 PM, Mattias Olsson <Mattias.olsson5@ comhem.se> wrote:
Buying a Chamberlin M1 for 7000 dollars wont really make as much sense anymore...But keep it a secret...// Mattias----- Original Message -----From: John WrightSent: Friday, January 15, 2010 7:39 PMSubject: RE: [newmellotrongroup] Re: NAMM ReportIf true, Memotron is done for. Markus will hit a home run if pricing is that low.
Subject: Re: [newmellotrongroup] Re: NAMM ReportIts a lot lower than that.Sent via BlackBerry from T-MobileFrom: "Tron400" <kornowicz@cox. net>Date: Fri, 15 Jan 2010 17:48:51 -0000Subject: [newmellotrongroup] Re: NAMM Report
Bernie
There is a “real world” for mellotrons? I was not aware
I use my Mellotrons and old machines in the studio everyday but There are very few of my clients who actually gives a shit if its a Mellotron flute, Flute 2 or a Chamberlin flute. Ill give them suggestions...but in the end they decide and they pay the invoices. The people on this list care but in the “real”world a high quality collection of note for note samples in a dedicated machine could go a very long way...
// Mattias
Den 2010-01-15 20.53, skrev "Chris Dale" <unobtainiumkeys@gmail.com>:
And rightfully so.
// Mattias
Bernie
----- Original Message -----From: fdoddy@aol.comSent: Friday, January 15, 2010 4:25 PMSubject: Re: [newmellotrongroup] Re: NAMM Report
fd
Bernie
Finally! The rumors are confirmed.
In a message dated 1/15/2010 2:52:31 A.M. Eastern Standard Time, Mattias.olsson5@comhem.se writes:
2010-01-15 by tony1
From: fdoddy@aol.comSent: Friday, January 15, 2010 5:36 PMSubject: Re: [newmellotrongroup] Re: NAMM Report
Glad to help. We still have one of the first Mackie 8-buss mixers delivered to NY. It has the shit beat out of it and it still sounds fine. I have a first gen 1604 ganged to a 1604 VLZ. That's what I tracked and mixed my record on. Can't kill those Mackie boards. If there is a Hall of Fame for mixers, the first gen 1604 has got to get in :>) Not one problem in 18 years.
Sent: Fri, Jan 15, 2010 4:49 pm
Hey Fritz,I don't buy used for a lot of reasons.Former AES member too, so no stranger to this stuff.Out of practice sure, but my ears still spot on tunings etc, as I was the synth tech for a major store here and drew clients from all over the Tampa/St. Pete/Clearwater area (over 3 million folks).I like the Mackie stuff and am 90% sure they make a 48 channel board, plus I still have my "ins" from those days locally.I remember the unvieling of the Solid State Logic board at the 1979 AES convention in Los Angeles. What a piece of gear as well as the Neve!Going to have a look at Toft stuff in a few.Thanks for your suggestions, I'll let you know what I end up with.Best,Tony----- Original Message -----From: fdoddy@aol.comSent: Friday, January 15, 2010 4:25 PMSubject: Re: [newmellotrongroup] Re: NAMM ReportBe very wary of buying anything used unless you have a good tech and know what to look for. If you are looking for something used, see if you can get it in your set up for a while.
Bernie
Trouble maker!
Didnt you get the T-shirt and bumper sticker ?
2010-01-16 by Gary Brumm
Are you ~seriously~ comparing replicating a Steinway Grand Piano with sampling to doing the same to a Mellotron?
There is no comparison between the two. Come on Martin…only on this list could you get away with such a statement.
Grand pianos will be around long after the last “tape based” Mellotron has rolled off the assembly line.
From: newmellotrongroup@yahoogroups.com [mailto:newmellotrongroup@yahoogroups.com] On Behalf Of tronbros@aol.com
Sent: Friday, January 15, 2010 12:26 PM
In a message dated 15/01/2010 18:57:31 GMT Standard Time, Mattias.olsson5@comhem.se writes:
Out of curiosity...Do they really feel the same way today seeing a similar product ?
Best,
Martin
2010-01-16 by Pomeroy RH Ranch
I think the idea is that the physical
dynamics of >any< instrument are lost in the “canned” world
of the digital reproducer. At least an Ampico or
Duo-Art reproducer does it on the instrument itself. It is likely that after a few hundred years
there will be piano-forte instruments and a way out thing like a Mellotron will only be seen in quirky museums, but the sound
doesn’t just come from the base source (like three ladies in Harry Chamberlin’s bedroom), but from >all< the
inputs from the reproducing dynamics of the machine that makes the sound that
comes out the soundboard or, in our case, the speakers
2010-01-16 by tronbros@aol.com
2010-01-16 by Mike Dickson
I wouldn't.
Sampling a Steinway (or at least 'getting an accurate digital picture of one') is probably much easier as Steinways are way more consistent in their sound than a Mellotron. You can play the same note ten times on a Mellotron and they won't sound the same every time, in the same way my upright piano doesn't play the same way two days in a row. Steinways on the other hand have centuries of engineering refinement in them that gives you a very consistent sound.
I am also assured that how good a grand piano sounds is about 50% down to the piano and 50% down to the room.
I don't think he has said otherwise. The longevity of the instrument isn't an issue anyone was discussing.
This re-states an interesting question. What state is the 'used' market in? As far as I can tell, everyone who wanted a real Mellotron has one until the last one sold out. The market is probably nowhere near as fluid as it was before, where they were changing hands a lot more. People advertising them on e-Bay usually give the reasons 'need more room' or 'need the money' rather than 'the thing is fucked and I hate the sound'.
Did it ever? :-)
M400 violins are EQed off at the top end to remove some of the 'shriek'. That's primarily why they sound different.
I totally agree. The thing that has (to my ears) torpedoed samples is the fact that they are always being meddled with.
EQ. Tuning. Interpolation. Noise reduction. Normalisation.
They all wreck what would otherwise be a piss easy job to do. You're right. People just want the sound. So why meddle with the sound if that is what people want?
2010-01-16 by fdoddy@aol.com
----- Original Message -----From: fdoddy@aol.comSent: Friday, January 15, 2010 5:36 PMSubject: Re: [newmellotrongroup] Re: NAMM Report
fd
fd
Bernie
I wouldn't.
2010-01-16 by ClayE
--- In newmellotrongroup@yahoogroups.com, fdoddy@... wrote:
> I've done the same with my tron Mike. I sampled it all and didn't process the samples. It's only one articulation, but it still sounds better than an M-tron or whatever.
> fd
> From: Mike Dickson <mike.dickson@...>
> Sent: Sat, Jan 16, 2010 4:43 am
> My keyboard action still feels okay too despite having been given acomplete battering over the last two years. I know it needs aservice, but the action feels okay to me. As for 'sponginess', I'veplayed a MemoryMoog and found that had the weirdest action I've everfelt in a keyboard. There is the contact...and there is a bitmore afterwards that doesn't do anything. It's just a matter of gettingused to what you're dealing with. Mellotron keyboards run on wood,rubber and sprung metal. It's never going to rock-solid on that basis,but by no means is it as heavy as (say) a Birotron (which has keys thatfeel like they were weighted on leaf springs) or some of the morerevolting plasticky things that troubled us in the 1980s.
> What I positively like about the touch on a Hammond or aMellotron or (direct action) pipe organ is the feeling that you are partof the machine. You can either feel the mechanics of the systemunder your fingertips. There is a bit of work involved there perhaps,but I don't mind it as much as I mind the feeling that I'm simplyplaying a series of rather dead digital switches.
> As for samples and MIDI, they have their place. They make a lot ofthings a lot easier and have obviously opened doors to many many thingsthat were previously impossible to encompass, but to me they just playback with monotonous regularity. I've been messing about a little withthat RedTron plugin and frankly the Mk-V version (for some reason)sounds better, for some reason. The problem is that the samples arelousy and there is really no way round that. Okay, so Mellotrons havetheir off days too (as we all know) but they get better. With this,you're stuck with a picture of what someone else thoughtsounded great. It's like the difference between making an Airfix kitaeroplane model and a balsa model. With one you are tied to otherpeople's ideas and that (to me) is limiting.
> Having said all that, I'll qualify it by saying that I've sampled3-violins myself and I'd defy anyone to A/B a scale of it and the M400whence it came and tell the difference. I just didn't treat the samplesat all. Someone might learn this trick one day. We'll see.
> Mike
> fdoddy@... wrote:
> MyStreetly refurb still feels pretty good after, what is it now, 7years?! I like the fight, the pushback of a tron. It's like playing aguitar through a "gasp" real amplifier. Ya gotta work it.... Samplesand a MIDI keyboard are too forgiving. Like the old Italian grandmassay about making risotto, "The rice must feel the pain"
Absolutely Mike, I agree as well. The samples I have used that sound the best have been right off the Mellotron. If I feel the need to
add reverb, EQ, or whatever I will add it myself. The point I was trying to make between the Grand Piano and Mellotron samples was that
the frequency response and the velovity at which the string is struck is what makes the piano more difficult to sample than the playback of a
string instrument (for example) that is played back through a very limited response system such as the Mellotron. However it is the lack
of response that gives it it’s unique character and made the Mellotron the fascinating instrument it is. Even the limited duration of the notes
small number of keys, wow and flutter, which could all be considered limitations, add to the overall sound we have come to know and love.
All of these characteristics can be sampled and if done well and played properly when sitting in a mix are virtually indistinguishable from the
original IMHO. I have always loved the Mellotron and think it brought a new and wonderful sound that was made even better by the limited
technology who’s “limitations” created it’s character and most likely by accident more than by design made it famous (some might say infamous J).
From: newmellotrongroup@yahoogroups.com [mailto:newmellotrongroup@yahoogroups.com] On Behalf Of Mike Dickson
Sent: Saturday, January 16, 2010 5:01 AM
2010-01-16 by djacques@csulb.edu
fd
fd
Bernie
2010-01-16 by tony1
From: fdoddy@aol.comSent: Saturday, January 16, 2010 9:30 AMSubject: Re: [newmellotrongroup] Re: NAMM Report
Nice sounding mic pre's on the onyx series.
Digital tron? I dunno...It's pretty. Somedays my tron just doesn't want to sound good or in tune on a track, so I just do something else because it wasn't meant to be. The days it wants to play nicely, it's magic. I imagine the digital tron will sound just fine everyday but I anticipate there won't be any magic for me.
Sent: Fri, Jan 15, 2010 6:04 pm
Agreed I have a small Mackie for my practice room and I like the little sucker.Their Oynx 80 looks good to me.That ought to piss the neighbors off.Have a great weekend and thanks for your valued input (no pun).Best,TonyPS what do you think of this digital Mellotron?I'm wating for M5000 #2.----- Original Message -----From: fdoddy@aol.comSent: Friday, January 15, 2010 5:36 PMSubject: Re: [newmellotrongroup] Re: NAMM ReportGlad to help. We still have one of the first Mackie 8-buss mixers delivered to NY. It has the shit beat out of it and it still sounds fine. I have a first gen 1604 ganged to a 1604 VLZ. That's what I tracked and mixed my record on. Can't kill those Mackie boards. If there is a Hall of Fame for mixers, the first gen 1604 has got to get in :>) Not one problem in 18 years.
Bernie
Hi Michale,
The point I was trying to make is that the Mellotron is great at what it does but you could never get a good grand piano (for example) due to
the velocity sensitivity of the tumbrel nuances caused be the touch of the player. 16k would put it on par with an inexpensive cassette deck. But if
we never had the Mellotron I think we would have lost the classic sound that would not have “naturally” occurred in a sampler with more
response, less noise, etc. Have you ever run a test tape through a machine to plot a response curve? I would bet you are probably down 3db at 16k.
Are the heads in the current machines the same as in the older ones? For the record I was not trying to criticize the Mellotron and I know and respect
that you manufacture these machines as a labor of love. So please do not take any offense. There are a lot of bad samples out there as well as some good
ones. Mike D. pointed out that many of the bad ones are pre processed and I would prefer to make any of those decisions myself starting with the original
basic sound of the instrument.
Cheers,
Gary
Sent: Saturday, January 16, 2010 9:20 AM
In a message dated 16/01/2010 16:33:53 GMT Standard Time, gabru@comsec.net writes:
Actually the mellotron is capable of great frequency response. It's the old recordings that are mitigated. We have put fresh recordings through it and get up to 16k back. Not many people know that!
Michale Caine
2010-01-16 by Mark Pring
I can't believe you are serious Mike. My piano teacher's Steinway is the only instrument I would consider swapping my mellotron for. The amount of control you have over the sound is amazing, you would have to have hundreds of samples per note to duplicate the sound.
I much prefer a mellotron to samples but surely the differences in playing a single note ten times are mainly differences of pitch, not dynamics and tonal quality as on a piano. Altough you get different sounds from a mellotron I am not convinced you have that much control over them.
With the new mellotron there will be no difference so why bother replicating the keyboard ( my dislike of the action being just my honest opinion) and making it look like a mellotron which it isn't. Other than the obvious point of making it sell. It is just a very expensive device to play back samples.
Mark
PS I know it wasn't your post but the Steinway is about as much use for rock music as the mellotron is for baroque.
I wasn't suggesting sampling a Steinway on a Mellotron, for crying out loud! I think we were talking at cross purposes.
Incidentally, when Technics brought out their digitally sampled piano (FX-1? I forget now) in the 1980s it was a pretty good approximation of 'the real thing', even then. They sampled a Steinway too. The sampled every note at 17 different rates of velocity to build a very complete picture of the instrument. They housed it in dummy casework and attached dummy hammers to the weighted keys so it even felt like the real thing. Reportedly they spent hundreds of thousands of dollars in researching this to see how to record the piano, how many different timbres it had, how the samples should be stored etc etc. And yes, it sounded 'real'. However, it sounded exactly like a Steinway that you had your head pressed up against. Every key had been close miked to get every last possible nuance of sound which meant that when you played it back it sounded like a close miked Steinway. They had forgotten that so much of a piano's sound is in the room where it is played, and adding that digitally (then) was next to impossible. In seeking the perfect sampler they had invented the world's most absurd sounding piano.
It's an expensive device to play back very specific samples. Plus it looks like the real thing too, in some measure. Personally, I reckon he will sell about a dozen of them, though I may be wrong. Who is it aimed at? The Mellotron freaks and purists won't want one because 'it's a sampler', and the normal people out there who just want the sounds will take one look at this, one look at the M-Tron and then another look at the (free) Red-Tron. I'm certain I know which I would go for. (Having played with it for a couple of days now, I think the Red-Tron sounds better than the M-Tron!) As Mattias said, people just want the sounds. It could come in a plywood box, a plastic box or a bunch of pixels and electrical impulses on a PC. Generally speaking, who cares? If people were such purists then the M-Tron would not have sold ten copies, it sounds that bad. But most people don't know the difference.
http://www.mikedickson.org.uk/private/V4S-1.mp3
http://www.mikedickson.org.uk/mellotronworks/04%20Air%20on%20the%20G%20String.mp3
Mike
2010-01-16 by Chris Dale
Chris –
Yep – The pins and springs are fine. I turn off the amp and listen so I have the pinch roller adjustment at the same barely-disengaged point – amp back on and double check -- then I adjust the pushpad for a just-firm-enough engagement for full sound without any drag/wobble. The problem with the keyboard is mostly the ugly disarray of the keys which also effects how they are “located” as run through their short arc when they are played.
Yeah, the measurement and number of turns is much finer distance than Mellotrons.My MAIN issue is actually some of the return spools (after it warms up for 10 mins or so – this seems to be an M2/long return spindle issue – my old M1 didn’t need to warm up but 2 mins) making gobs of squeaky, whining racket – some of which makes through into the signal and out the speakers – argh! - But I want to get these rubber keyboard pieces sorted out before I dive into that. I’ve done some return spool adjustment screw tweaking, but it won’t help some of them – do I need to re-felt the spools?? I hope not….
About the rubber pieces - you might have to make those out of something else. I'll look and see if I have those, but I don't think I do. You might try taking silicone and making a "copy" of one by drying the silicone out in the shape of one. That's the cheapest way!And for the return rings, I think the allen screw is touching the return shaft on several keys, I'd actually try removing them entirely on the keys that don't cooperate just to see if they're causing the noise.That's how I knew they were making noise on mine. Then I put them back and very finely adjusted them.On mine I find that after it's been warmed up for 15-30 min that problem goes away. It may just need a warm up.Your M2 is longer than the M1 and it takes longer for the heat to move around.If you still have noise after backing off / removing the allen screws then yeah you may need to re-felt the spools. That's a BIG job and I'd rather bring it to Richard (...if.... he's up for that) unless you have the time to do it.The only other cause for this noise (and hopefully it isn't this) is a bearing in the shaft has gone and it's grinding - but that's unlikely.For now I'd try to get the rubber bits made. Please let me know about that because I don't know if I have any, and I'll need them too.Chris
From: newmellotrongroup@yahoogroups.com [mailto:newmellotrongroup@yahoogroups.com] On Behalf Of Chris Dale
Sent: Friday, January 15, 2010 11:59 AM
Subject: Re: Mellotron v. Chamberlin keyboard (was RE: [newmellotrongroup] NAMM Report)
Hi Vance:
Have you tried adjusting the back of the keys? Are the pins /springs okay?
From: newmellotrongroup@yahoogroups.com [mailto:newmellotrongroup@yahoogroups.com] On Behalf Of fdoddy@aol.comMy Streetly refurb still feels pretty good after, what is it now, 7 years?! I like the fight, the pushback of a tron. It's like playing a guitar through a "gasp" real amplifier. Ya gotta work it.... Samples and a MIDI keyboard are too forgiving. Like the old Italian grandmas say about making risotto, "The rice must feel the pain"
M
2010-01-16 by ClayE
--- In newmellotrongroup@yahoogroups.com, djacques@... wrote:
> Or disappointment. Like that new sex robot that is now available for 7000 dollars.
> From: fdoddy@...
> Date: Sat, 16 Jan 2010 09:30:44
> fd
2010-01-16 by sdavmor
Mellotron keyboards run on wood, rubber and sprung metal. It's never going to rock-solid on that basis, but by no means is it as heavy as (say) a Birotron (which has keys that feel like they were weighted on leaf springs) or some of the more revolting plasticky things that troubled us in the 1980s.
What I positively like about the touch on a Hammond or a Mellotron or (direct action) pipe organ is the feeling that you are part of the machine. You can either feel the mechanics of the system under your fingertips. There is a bit of work involved there perhaps, but I don't mind it as much as I mind the feeling that I'm simply playing a series of rather dead digital switches.
As for samples and MIDI, they have their place. They make a lot of things a lot easier and have obviously opened doors to many many things that were previously impossible to encompass, but to me they just play back with monotonous regularity. I've been messing about a little with that RedTron plugin and frankly the Mk-V version (for some reason) sounds better, for some reason. The problem is that the samples are lousy and there is really no way round that. Okay, so Mellotrons have their off days too (as we all know) but they get better. With this, you're stuck with a picture of what someone else thought sounded great. It's like the difference between making an Airfix kit aeroplane model and a balsa model. With one you are tied to other people's ideas and that (to me) is limiting.
Having said all that, I'll qualify it by saying that I've sampled 3-violins myself and I'd defy anyone to A/B a scale of it and the M400 whence it came and tell the difference. I just didn't treat the samples at all. Someone might learn this trick one day. We'll see.
Mike
2010-01-16 by kinchmusic@aol.com
as the mellotron is for baroque.And of course, if it's not baroque, then don't fix it!I have to confess, that if I want a tron for the road, then I find the Memotron works brilliantly, and it is very light to carry, and to these eyes, looks fantastic!I just would not risk my tron being bounced around in the back of the car unless I had to. The cabinet creaks a bit to much nowadays for me to move it.The fact that I have my gear upstairs also might have something to do with it.Andy K
http://www.mikedick son.org.uk/ private/V4S- 1.mp3
> fd
> From: Mike Dickson <mike.dickson@ ...>
> My keyboard action still feels okay too despite having been given acomplete battering over the last two years. I know it needs aservice, but the action feels okay to me. As for 'sponginess' , I'veplayed a MemoryMoog and found that had the weirdest action I've everfelt in a keyboard. There is the contact...and there is a bitmore afterwards that doesn't do anything. It's just a matter of gettingused to what you're dealing with. Mellotron keyboards run on wood,rubber and sprung metal. It's never going to rock-solid on that basis,but by no means is it as heavy as (say) a Birotron (which has keys thatfeel like they were weighted on leaf springs) or some of the morerevolting plasticky things that troubled us in the 1980s.
> As for samples and MIDI, they have their place. They make a lot ofthings a lot easier and have obviously opened doors to many many thingsthat were previously impossible to encompass, but to me they just playback with monotonous regularity. I've been messing about a little withthat RedTron plugin and frankly the Mk-V version (for some reason)sounds better, for some reason. The problem is that the samples arelousy and there is really no way round that. Okay, so Mellotrons havetheir off days too (as we all know) but they get better. With this,you're stuck with a picture of what someone else thoughtsounded great. It's like the difference between making an Airfix kitaeroplane model and a balsa model. With one you are tied to otherpeople' s ideas and that (to me) is limiting.
> Mike
fd
fd
Bernie
----- Original Message -----From: fdoddy@aol.comSent: Saturday, January 16, 2010 9:30 AMSubject: Re: [newmellotrongroup] Re: NAMM Report
fd
fd
fd
Bernie
Mike - on the Birotron you played - was there some kind of adjustment for how heavy or light the keys would play? I'm not talking about pinch rollers / pressure pads obviously. I mean was there some kind of global mechanical rod that adjusted the feel of the keys?
Not to my knowledge, but then again I never went looking for it I admit. The clattering of the cartridges was actually more distracting than the touch of the thing.
2010-01-16 by David Jacques
Fritz where did you see pics of the digital unit?I agree with you about lacking the "magic" of the real deal.Digital control I like, but not for sound generation.Best,Tony----- Original Message -----
From: fdoddy@aol.comSent: Saturday, January 16, 2010 9:30 AMSubject: Re: [newmellotrongroup] Re: NAMM ReportNice sounding mic pre's on the onyx series.
Subject: Re: [newmellotrongroup] Re: NAMM ReportAgreed I have a small Mackie for my practice room and I like the little sucker.Their Oynx 80 looks good to me.That ought to piss the neighbors off.Have a great weekend and thanks for your valued input (no pun).Best,TonyPS what do you think of this digital Mellotron?I'm wating for M5000 #2.----- Original Message -----From: fdoddy@aol.comSent: Friday, January 15, 2010 5:36 PMSubject: Re: [newmellotrongroup] Re: NAMM ReportGlad to help. We still have one of the first Mackie 8-buss mixers delivered to NY. It has the shit beat out of it and it still sounds fine. I have a first gen 1604 ganged to a 1604 VLZ. That's what I tracked and mixed my record on. Can't kill those Mackie boards. If there is a Hall of Fame for mixers, the first gen 1604 has got to get in :>) Not one problem in 18 years.
Subject: Re: [newmellotrongroup] Re: NAMM ReportHey Fritz,I don't buy used for a lot of reasons.Former AES member too, so no stranger to this stuff.Out of practice sure, but my ears still spot on tunings etc, as I was the synth tech for a major store here and drew clients from all over the Tampa/St. Pete/Clearwater area (over 3 million folks).I like the Mackie stuff and am 90% sure they make a 48 channel board, plus I still have my "ins" from those days locally.I remember the unvieling of the Solid State Logic board at the 1979 AES convention in Los Angeles. What a piece of gear as well as the Neve!Going to have a look at Toft stuff in a few.Thanks for your suggestions, I'll let you know what I end up with.Best,Tony----- Original Message -----From: fdoddy@aol.comSent: Friday, January 15, 2010 4:25 PMSubject: Re: [newmellotrongroup] Re: NAMM ReportBe very wary of buying anything used unless you have a good tech and know what to look for. If you are looking for something used, see if you can get it in your set up for a while.
Subject: Re: [newmellotrongroup] Re: NAMM ReportSpeaking for myself, I find something interesting in about every musical instrument around.I need a larger mixer (40+ chan) and I would appreciate an honest reccomendation fellas!Thanks in advance,TonyNeve is a bit out of my reach lol.----- Original Message -----From: Chris DaleSent: Friday, January 15, 2010 2:53 PMSubject: Re: [newmellotrongroup] Re: NAMM ReportNah, I doubt this will make a difference to the "Chamberlin" market. If you ever had one or ever played one you'd know.Chamberlin sounds in a Mellotron do not sound the same as a real Chamberlin - just as the M400 violins do not sound identical to the MK II violins, nor do M300 sounds or MK II sounds sound like a real MK II or M300 if they're coming from an M400.This is my experience playing multiple Chamberlins and Mellotrons over the last 20 years. They're all unique and different.If you really spend time closely listening to all these instruments you can tell.Most people can't because they only use 1 machine at best. No A and B comparison can be made.This new digital version is for a different market anyway.I imagine Markus will continue to build the MK 6 alongside this digital tron, just as Streetly will continue with the M4000.And rightfully so.Anyone wanting authenticity and a product of real quality will buy an original tape version.Anyone wanting the sounds and feel with digital high quality will buy an authorized "tribute version"There's room for both.On Fri, Jan 15, 2010 at 1:52 PM, Mattias Olsson <Mattias.olsson5@ comhem.se> wrote:Buying a Chamberlin M1 for 7000 dollars wont really make as much sense anymore...But keep it a secret...// Mattias----- Original Message -----From: John WrightSent: Friday, January 15, 2010 7:39 PMSubject: RE: [newmellotrongroup] Re: NAMM ReportIf true, Memotron is done for. Markus will hit a home run if pricing is that low.From: newmellotrongroup@ yahoogroups. com [mailto:newmellotrongroup@ yahoogroups. com] On Behalf Of djacques@csulb. edu
Bernie
2010-01-16 by ClayE
--- In newmellotrongroup@yahoogroups.com, Chris Dale <unobtainiumkeys@...> wrote:
> In general - these new digital trons are made with the contemporary music of the 90's and 2000's in mind - little or no adventurous Mellotron use. So I think if you only want a generic Mellotron atmosphere, these latest digital incarnations are fine.
2010-01-16 by tony1
From: David JacquesSent: Saturday, January 16, 2010 5:11 PMSubject: Re: [newmellotrongroup] Re: NAMM ReportMarkus has it set up on top of his Mellotron Mark V, and you cannot tell the difference in sound.
On Jan 16, 2010, at 2:02 PM, fdoddy@aol.com wrote:
Fritz where did you see pics of the digital unit?I agree with you about lacking the "magic" of the real deal.Digital control I like, but not for sound generation.Best,Tony----- Original Message -----From: fdoddy@aol.comSent: Saturday, January 16, 2010 9:30 AMSubject: Re: [newmellotrongroup] Re: NAMM ReportNice sounding mic pre's on the onyx series.
Bernie
Are you on DRUGS Chris? If someone wanted to be adventurous live or in the studio using a new digital Mellotron, there is nothing holding them back.
I'm struggling to think of many of the revered Prog Gods who used the Mellotron 'adventurously'. It's not a particularly 'adventurous' instrument. You can use it up front, play it melodically, harmonise all over the place, and certainly you can process the sound or do whatever else you like with it, but adventurous? You can dick about with synths adventurously because you can make them say what you want them to say, but a Mellotron string section is always going to sound like a cello, a viola and three violins, all vaguely out of tune and all sounding monolithic. Ninety nine percent of the people who have put hand to Tron have used it for block chords. Where is the adventure?
It's still a welcome surprise to hear it at all. I heard it on the intro a fairly nondescript pop song a year or so ago while seated in the dentist's chair and exclaimed 'gucking gell!' as I was having my mouth seen to my an astonished dentist who thought she had accidentally probed through a raw nerve.
2010-01-16 by Paul Watson
I think Tangerine Dream on Phaedra and Rubicon
used it adventurously by tweaking the hell out
of their trons.
Sent: Sunday, 17 January 2010 12:32 PM
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4778 (20100116) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
Then I presume the units are similiar to the size of a Memotron?I'd sure like to see some pictures of it!Best,Tony----- Original Message -----
Bernie
2010-01-16 by ClayE
> Best,
> Tony
> From: David Jacques
> Best,
> Tony
> From: fdoddy@...
> fd
> From: tony1 <atm655@...>
> Best,
> Tony
> From: fdoddy@...
> fd
> Hey Fritz,
> Best,
> Tony
> From: fdoddy@...
> fd
> Thanks in advance,
> Tony
> From: Chris Dale
> And rightfully so.
> On Fri, Jan 15, 2010 at 1:52 PM, Mattias Olsson <Mattias.olsson5@...> wrote:
> // Mattias
> From: John Wright
> From: newmellotrongroup@yahoogroups.com [mailto:newmellotrongroup@yahoogroups.com] On Behalf Of djacques@...
> From: "Tron400" <kornowicz@...>
> Bernie
2010-01-16 by tony1
----- Original Message -----From: ClayESent: Saturday, January 16, 2010 6:42 PMSubject: [newmellotrongroup] Re: NAMM ReportTony:
You should try this new thing called google. It's really cool!
http://www.mellotro n.com/digital- mellotron. html
> Best,
> Tony
> From: David Jacques
> Best,
> Tony
> From: fdoddy@...
> fd
> Best,
> Tony
> From: fdoddy@...
> fd
> Hey Fritz,
> Best,
> Tony
> From: fdoddy@...
> fd
> Thanks in advance,
> Tony
> From: Chris Dale
> And rightfully so.
> On Fri, Jan 15, 2010 at 1:52 PM, Mattias Olsson <Mattias.olsson5@ ...> wrote:
> // Mattias
> From: John Wright
> From: newmellotrongroup@ yahoogroups. com [mailto:newmellotrongroup@ yahoogroups. com] On Behalf Of djacques@...
> From: "Tron400" <kornowicz@. ..>
> Bernie
2010-01-16 by markpringnz
> Yep I'm familiar with it.
> Just overlooked using it, my mistake.
> I looks like it means business.
> Tony
> From: ClayE
> Tony:
> http://www.mellotron.com/digital-mellotron.html
> > Best,
> > Tony
> > From: David Jacques
> > Best,
> > Tony
> > From: fdoddy@
> > fd
> > From: tony1 <atm655@>
> > Best,
> > Tony
> > From: fdoddy@
> > fd
> > Hey Fritz,
> > Best,
> > Tony
> > From: fdoddy@
> > fd
> > Thanks in advance,
> > Tony
> > From: Chris Dale
> > And rightfully so.
> > On Fri, Jan 15, 2010 at 1:52 PM, Mattias Olsson <Mattias.olsson5@> wrote:
> > // Mattias
> > From: John Wright
> > From: "Tron400" <kornowicz@>
> > Bernie
2010-01-17 by MAinPsych@aol.com
2010-01-17 by David Jacques
Just looked at the photo again, apologies if this has already been pointed out but the digital mellotron in the picture starts on F and my M400 starts on G. What's going on? Is the photo "faked" or is it just going to have 2 redundant keys to look nice?
> Tony
> From: ClayE
> Tony:
> > Best,
> > Tony
> > From: David Jacques
> > Best,
> > Tony
> > From: fdoddy@
> > fd
> > Best,
> > Tony
> > From: fdoddy@
> > fd
> > Hey Fritz,
> > Best,
> > Tony
> > From: fdoddy@
> > fd
> > Thanks in advance,
> > Tony
> > From: Chris Dale
> > And rightfully so.
> > On Fri, Jan 15, 2010 at 1:52 PM, Mattias Olsson <Mattias.olsson5@ > wrote:
> > // Mattias
> > From: John Wright
> > Bernie
2010-01-17 by lsf5275@aol.com
"only...a generic Mellotron atmosphere" <- WTF is that? You are suggesting that the new digital Mellotron will be a poor substitute for the real thing. That's just nonsense.
Clay
2010-01-17 by Richard Lowman
--- On Sat, 1/16/10, MAinPsych@aol.com <MAinPsych@aol.com> wrote:Awwwww, she sure looks sweet too!'Might as well start saving up for one.... :)===============================================================In a message dated 1/16/2010 3:32:59 P.M. Pacific Standard Time, atm655@verizon.net writes:Then I presume the units are similiar to the size of a Memotron?I'd sure like to see some pictures of it!Best,TonyAsk and ye shall receive...
Hey, where do get one of those?Or disappointment. Like that new sex robot that is now available for 7000 dollars.
I believe you can go to The Consumer Electronics show... Her name os "Roxxxy".. Here is the link:
Sex only goes so far – then you want to be able to talk to the person,"
I just want it to say, "Oh GODDDDD! YESSSSS!" Then I want it to say, "Turn on the game. I'll go make you a sandwwich."In a message dated 1/16/2010 8:48:10 P.M. Eastern Standard Time, djacques@csulb. edu writes:I believe you can go to The Consumer Electronics show... Her name os "Roxxxy".. Here is the link:
Check out the video with "The Creator" Funny and sad at the same time...
http://www.sfgate. com/cgi-bin/ blogs/abraham/ detail??blogid=95&entry_id=55095
2010-01-17 by kinchmusic@aol.com
2010-01-17 by Mike Dickson
2010-01-17 by Andy Thompson
----- Original Message -----From: kinchmusic@aol.comSent: Sunday, January 17, 2010 7:57 AMSubject: Re: [newmellotrongroup] Re: NAMM ReportCould have invested in some decent switchgear though. That On/Off switch looks very homemade.
Andy K
I thought you were talking about the robot for a minute...Andy T.
2010-01-17 by Mattias Olsson
Andy
K
2010-01-17 by fdoddy@aol.com
fd
fd
fd
Bernie
--- In newmellotrongroup@ yahoogroups. com, Chris Dale <unobtainiumkeys@ ...> wrote:
2010-01-17 by ClayE
> Andy K
> From: MAinPsych@...
> Sent: Sun, Jan 17, 2010 12:20 am
> In a message dated 1/16/2010 2:11:56 P.M. Pacific Standard Time, djacques@... writes:
> My 2 pence worth: Putting aside all the theorizing, at NAMM, David and I did direct A-B comparisons between the digitial Mellotron and a MkVI. I would defy anyone to tell the difference in sound (no one could), even in the feel of the keyboard (the difference there is very slight). At $1800. and 41 pounds with 100 sounds and (BTW) parameter control, it's one hell of a machine.
> Frank1
> Frank1
2010-01-17 by Thomas C. Doncourt
> It looks like the same type of on/off switch found on most amplifiers
> (Vox, Fender, Orange, Hiwatt). My MK-VI has the same type of switch. It
> looks and feels like a switch to me. It makes a nice click sound. Not a
> mushy click or a spongy click, a nice snappy click.
>> Andy K
>> From: MAinPsych@...
>> To: newmellotrongroup@yahoogroups.com
>> Frank1
>> Frank1
2010-01-18 by gino wong
On Sat, Jan 16, 2010 at 12:20 PM, <tronbros@aol.com> wrote:
Actually the mellotron is capable of great frequency response. It's the old recordings that are mitigated. We have put fresh recordings through it and get up to 16k back. Not many people know that!In a message dated 16/01/2010 16:33:53 GMT Standard Time, gabru@comsec.net writes:The point I was trying to make between the Grand Piano and Mellotron samples was that
Michale CaineStreetly Electronics - All Things Mellotronic
魚手
Gino Wong
Employee
LBPH
(800) 222-1754
ginowong@gmail.com
2010-01-18 by john barrick
>And Gene Pitney just rolled over in his grave...
> It Hz to be in love...
> I
2010-01-18 by Chris Dale
Clay
of their trons.
http://www.eset.com
2010-01-18 by Mike Dickson
Agreed - good example.On Sat, Jan 16, 2010 at 6:38 PM, Paul Watson <progrocker@xtra. co.nz> wrote:
of their trons.
2010-01-19 by lsf5275@aol.com
I define 'adventurous use' as pushing a tape based instrument beyond what it's expected use might be, rather than just using it as a string pad - which is what you mostly get in the music of the last 20 years.
2010-01-19 by Chris Dale
On Sat, Jan 16, 2010 at 8:34 PM, <lsf5275@aol.com> wrote:
Be nice to Chis.In a message dated 1/16/2010 5:40:05 P.M. Eastern Standard Time, ecclesreinson@rogers.com writes:Are you on DRUGS Chris? If someone wanted to be adventurous live or in the studio using a new digital Mellotron, there is nothing holding them back.
Clay
On Mon, Jan 18, 2010 at 9:09 PM, <lsf5275@aol.com> wrote:
So If I use my Mellotron as a giant paper weight I'm, "adventurous?" Or suppose someone were to push their Mellotron beyond the top step of the second flight leading up to their apartment and it took out that annoying Mrs. Bainbridge who lives across the hall and was on her way home from shopping. Would that be "adventurous?"In a message dated 1/18/2010 4:08:07 P.M. Eastern Standard Time, unobtainiumkeys@gmail.com writes:I define 'adventurous use' as pushing a tape based instrument beyond what it's expected use might be, rather than just using it as a string pad - which is what you mostly get in the music of the last 20 years.
2010-01-19 by Mike Dickson
Pitch increase from the motor controller (not control panel) in the middle of Battle Of Glass Tears (1971)
It sounds daft!
Tension backed off pitch roller for detuned wobbly Brass sound in Talking Drum intro (1974)
That's not a Mellotron. That's a tube with weird kind of bag attached to it that Fripp whirled about his head in the studio. Sid Smith's book has a photo of it.
2010-01-20 by NormLeete@aol.com
2010-01-20 by ClayE
--- In newmellotrongroup@yahoogroups.com, NormLeete@... wrote:
> In a message dated 18/01/2010 21:08:06 GMT Standard Time,
> unobtainiumkeys@... writes:
> _http://www.youtube.com/watch?v=c-e2sTyzCHc_
> (http://www.youtube.com/watch?v=c-e2sTyzCHc) - some flywheel wrestling...
2010-01-20 by Sean
> fd
2010-01-20 by Mike Dickson
It seems that most all the M-Tron sounds (with exceptions like the cello) have much poorer signal to noise ratio than the real deal. I don't recall the Moodies or Crimson Mellotrons sounding hissy in unflattering ways. Mr. Dickson's recordings certainly don't sound that way.
My recordings were filtered track-by-track through a very good noise reduction system indeed to eliminate the white noise overhead. Pile up 40 tracks of that and it would swamp everything. The thing is that what you record on Monday has a different sonic picture the following day. They are such fickle creatures.
I just don't much care for the M-Tron sounds. They seem muffled to death at times and some appear to have been recorded with a mike at the Mk II speakers. I mean...there is 'authentic' and there is 'needlessly hopeful'.....
Mike
2010-01-21 by lsf5275@aol.com
Track A Track B Track C
1. Vibes MKII Violins Cello
2. Russian Choir Eight Choir Church Organ(St. John's)
3. MKII Brass Tenor Sax Trombone
4. Boys Choir Male Choir Female Choir
5. M300A Violins New Cello Cyndee’s Viola
6. MKII Church Organ McDonald Flute MKI Clarinet
7. New String Section Orchestra Watcher Mix
8. Bass Clarinet Oboe Glen Miller
Hey just thought of this. What tapes are on your wishlist? Mine would be (if I could afford the Melly and tapes of course)
MkII violins
M400 violins
MkII trombone
MkII church organ
MkII flute
clarinet (whichever M-Tron sampled)
orchestra
MkII brass
trumpets and trombones
MkII tenor sax
St. John's Wood organ
french horn
cello
cello viola mix
MkII organ #2 (does this have a different name? The one that sounds at home with the Lawrence Welk bubble machine)
2010-01-21 by Bruce Daily
Date: Wednesday, January 20, 2010, 6:25 PM
Interesting. Here is what's on my M4000. It nearly fills your list. The track blending is very good and many of the sounds were picked with that ability in mind.Track A Track B Track C
In a message dated 1/20/2010 6:21:45 P.M. Eastern Standard Time, fourtytwominds@ yahoo.com writes:Hey just thought of this. What tapes are on your wishlist? Mine would be (if I could afford the Melly and tapes of course)
MkII violins
M400 violins
MkII trombone
MkII church organ
MkII flute
orchestra
MkII brass
MkII tenor sax
french horn
cello
cello viola mix
2010-01-21 by Tron400
> I just don't much care for the M-Tron sounds. They seem muffled to deathSome of them were.
> hopeful'.....
> Mike
> MkII violins
> M400 violins
> MkII trombone
> MkII church organ
> MkII flute
> orchestra
> MkII brass
> MkII tenor sax
> french horn
> cello
> cello viola mix
> -Sean
Here's my list :
http://mikedickson.org.uk/tron/
Bernie
2010-01-21 by tspit74@comcast.net
Sent: Thursday, January 21, 2010 12:24:13 AM GMT -06:00 US/Canada Central
Here's my wish list (please send cash!)-MK2 BrassSplit Male/Female choirClassic StringsMedieval WoodwindsMK2 Tenor SaxSad StringsBass ClarinetVibesOkay, I like the classic sounds.-Bruce D.#1221
MkII violins
M400 violins
MkII trombone
MkII church organ
MkII flute
orchestra
MkII brass
MkII tenor sax
french horn
cello
cello viola mix
2010-01-22 by Bruce Daily
Date: Thursday, January 21, 2010, 7:22 AM
You forgot String Section w/ cello. My current favorite sound.
To: newmellotrongroup@ yahoogroups. com
MkII violins
M400 violins
MkII trombone
MkII church organ
MkII flute
orchestra
MkII brass
MkII tenor sax
french horn
cello
cello viola mix
2010-01-22 by Sean
>I think I just answered my own question just a little while ago. I fiddle-faddled with graphic EQ in real time and I think I gots it.
> > way.
> hopeful'.....
> Mike
2010-01-22 by lsf5275@aol.com
--- In newmellotrongroup@ yahoogroups. com, Mike Dickson <mike.dickson@ ...> wrote:
> > way.
> hopeful'.... .
> Mike
It's a 31 band EQ
For the MkII violins (M-Tron the "Violins 1" seems to be the MkII direct feed) Tone set to 12o'clock.
I've cut 14kHz and above -20. That seems to clear up the jaggies quite well.
12kHz -6
315Hz -just a little bit, and steep roll off below that to -20 by 150Hz, to reinforce the highpass I already had in place.
Pull 400Hz, 1kHz, and 2kHz slightly above zero (probably about +2) and the areas in between these maybe -2, slope smoothly.
the 4-8kHz range seems to be where most of the SCREAM is, so I've moderately scooped this out (-4 or -6 or something like that).
The 8kHz-10kHz range seems to bring it forward in a mix if left alone, if reduced say by 3dB it sits better as the typical Mellotron wall-of-sound- ness.
I've compared with the old King Crimson recordings and I think I'm pretty much there. In the Court seems to have tone set to 9o'clock, and the fundamentals a little hotter (the 400Hz area and near neighbors) and the harmonics a little less than what I have, especially, so it seems, everything above 3kHz is a bit less.
The megalithic In the Court sound seems to be the same for lower register notes, but upper register notes I'm guess are recorded with a different EQ that has less fundamental and more overtone, and the tone knob back at around 12o'clock.
Try it, tell me if I'm daft or not.
-Sean
Oh, lots of reverb too.
2010-01-22 by tspit74@comcast.net
Sent: Monday, January 18, 2010 1:26:52 PM GMT -06:00 US/Canada Central
> I
2010-01-22 by Tron400
--- In newmellotrongroup@yahoogroups.com, Bruce Daily <pocotron@...> wrote:
> No forgetting at all.
> It's on one of my frames:Â 2 Trumpets & 2 Trombones; String section w/'Cello; 8 Choir.
> Â Â Â Â Â
> Â
> -Bruce D.
> Â
> --- On Thu, 1/21/10, tspit74@... <tspit74@...> wrote:
> From: tspit74@... <tspit74@...>
> Â
> From: "Bruce Daily" <pocotron@yahoo. com>
> Â
> Â
> MK2 Brass
> Classic Strings
> Medieval Woodwinds
> MK2 Tenor Sax
> Sad Strings
> Bass Clarinet
> Vibes
> Â
> Â
> Â -Bruce D.
> Â #1221
> Â
> From: lsf5275@aol. com <lsf5275@aol. com>
> Â
> Â
> Â
> Â Â Â Â Â Â Â Â Â Track AÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Track BÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Track C
> Â
> Â
> 5.  M300A Violins             New Cello             Cyndeeâs Viola
> Â
> Â
> MkII violins
> M400 violins
> MkII trombone
> MkII church organ
> MkII flute
> orchestra
> MkII brass
> MkII tenor sax
> french horn
> cello
> cello viola mix
2010-01-22 by Rick Blechta
As George Harrison would sing, "Isn't it a Pitney?"
2010-01-22 by John Wright
And Andy Williams singing 'Moog River"
From: newmellotrongroup@ yahoogroups. com [mailto:newmellotro ngroup@yahoogrou ps.com] On Behalf Of Rick Blechta
Sent: Friday, January 22, 2010 9:23 AM
And then there's that Famous Christmas carol, "Arp! the Herald Angels Sing"
2010-01-22 by Nic Lewis
Oh Magog! I can't stand it anymore.
In a message dated 1/22/2010 9:27:50 A.M. Eastern Standard Time, john.wright@consona.com writes:
2010-01-23 by Bruce Daily
Date: Friday, January 22, 2010, 7:15 AM
Bruce,
How do you like the 2 Trumpets/2 Trombones? Is it a split or do both instruments run the full 3 octaves -1? How's the bottom end? I have the Pinder CD samples and M-Tron Pro, both of which have a trumpet/trombone sound, but I don't know if it's the same one that you have; both sound kind of thin at the bottom.
Bernie
--- In newmellotrongroup@ yahoogroups. com, Bruce Daily <pocotron@.. .> wrote:
> Â Â Â Â Â
> Â
> -Bruce D.
> Â
> --- On Thu, 1/21/10, tspit74@... <tspit74@... > wrote:
> From: tspit74@... <tspit74@... >
> Â
> Â
> Â
> MK2 Brass
> Classic Strings
> Medieval Woodwinds
> MK2 Tenor Sax
> Sad Strings
> Bass Clarinet
> Vibes
> Â
> Â
> Â -Bruce D.
> Â #1221
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> Â
> MkII violins
> M400 violins
> MkII trombone
> MkII church organ
> MkII flute
> orchestra
> MkII brass
> MkII tenor sax
> french horn
> cello
> cello viola mix
Date: Friday, January 22, 2010, 7:53 AM
Oh Magog! I can't stand it anymore.In a message dated 1/22/2010 9:27:50 A.M. Eastern Standard Time, john.wright@ consona.com writes:And Andy Williams singing 'Moog River"
2010-01-23 by Tron400
> Hi Bernie-
>   Mine spans the keyboard, it is not the split. Yeah, it's a little thin at the bottom, but it's good. MK2 Brass or Brass B would've given a Bigger Bottom (shades of SpinalTap!).
>   After living with my 'tron for a while, I've started to feel that a recording of a loud, blaring, razzy(?) brass section might be great ...with tubas, too! I don't want to start something, though. Hey, sustaining an 8-second loud note might make some of the players fall over and die.
> Â
> Â Â -Bruce Daily
> --- On Fri, 1/22/10, Tron400 <kornowicz@...> wrote:
> From: Tron400 <kornowicz@...>
> Â
> Bruce,
> Bernie
> --- In newmellotrongroup@ yahoogroups. com, Bruce Daily <pocotron@ .> wrote:
> > It's on one of my frames:ÃÂ 2 Trumpets & 2 Trombones; String section w/'Cello; 8 Choir.
> > ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ
> > ÃÂ
> > -Bruce D.
> > ÃÂ
> > --- On Thu, 1/21/10, tspit74@ <tspit74@ > wrote:
> > From: tspit74@ <tspit74@ >
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > MK2 Brass
> > Classic Strings
> > Medieval Woodwinds
> > MK2 Tenor Sax
> > Sad Strings
> > Bass Clarinet
> > Vibes
> > ÃÂ
> > ÃÂ
> > ÃÂ -Bruce D.
> > ÃÂ #1221
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ
> > ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ Track AÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ Track BÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ Track C
> > ÃÂ
> > ÃÂ
> > 1.ÃÂ ÃÂ Vibes ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ MKII ViolinsÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ Cello
> > 2.ÃÂ ÃÂ Russian ChoirÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ Eight ChoirÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ Church Organ(St. John's)
> > 3.ÃÂ ÃÂ MKII BrassÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ Tenor SaxÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ Trombone
> > 4.ÃÂ ÃÂ Boys ChoirÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ Male ChoirÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ Female Choir
> > 5.ààM300A ViolinsàààààààààààààNew CelloàààààààààààààCyndeeââ¬â¢s Viola
> > 6.ÃÂ ÃÂ MKII Church OrganÃÂ ÃÂ ÃÂ ÃÂ McDonald FluteÃÂ ÃÂ ÃÂ ÃÂ MKI Clarinet
> > 7.ÃÂ ÃÂ New String SectionÃÂ ÃÂ ÃÂ ÃÂ OrchestraÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ Watcher Mix
> > 8.ÃÂ ÃÂ Bass ClarinetÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ OboeÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ ÃÂ Glen Miller
> > ÃÂ
> > ÃÂ
> > MkII violins
> > M400 violins
> > MkII trombone
> > MkII church organ
> > MkII flute
> > orchestra
> > MkII brass
> > MkII tenor sax
> > french horn
> > cello
> > cello viola mix
2010-01-23 by lsf5275@aol.com
The Brass B interests me, but the tuning doesn't seem as good as the MkII Combined Brass.
Date: Friday, January 22, 2010, 7:34 PM
Thanks Bruce. From the samples I've tried, the solo Trombone has more bottom. Have you tried the GC3 Brass? It's not really a split but the lower half of the keyboard sounds different than the upper half; almost like the lower half is muted. The upper half has a nice, bright, piercing sound like trumpets. The Brass B interests me, but the tuning doesn't seem as good as the MkII Combined Brass.
Bernie
> Hi Bernie-
> Â
> Â Â -Bruce Daily
> --- On Fri, 1/22/10, Tron400 <kornowicz@. ..> wrote:
> From: Tron400 <kornowicz@. ..>
> Â
> Bruce,
> Bernie
> > It's on one of my frames: 2 Trumpets & 2 Trombones; String section w/'Cello; 8 Choir.
> >     ÂÂ
> > ÂÂ
> > -Bruce D.
> > ÂÂ
> > ÂÂ
> > ÂÂ
> > ÂÂ
> > MK2 Brass
> > Classic Strings
> > Medieval Woodwinds
> > MK2 Tenor Sax
> > Sad Strings
> > Bass Clarinet
> > Vibes
> > ÂÂ
> > ÂÂ
> >  -Bruce D.
> >  #1221
> > ÂÂ
> > ÂÂ
> > ÂÂ
> > ÂÂ
> > ÂÂ
> > ÂÂ
> > ÂÂ
> > ÂÂ
> > MkII violins
> > M400 violins
> > MkII trombone
> > MkII church organ
> > MkII flute
> > orchestra
> > MkII brass
> > MkII tenor sax
> > french horn
> > cello
> > cello viola mix
Date: Friday, January 22, 2010, 7:43 PM
Now that's saying something!In a message dated 1/22/2010 9:38:32 P.M. Eastern Standard Time, kornowicz@cox. net writes:The Brass B interests me, but the tuning doesn't seem as good as the MkII Combined Brass.
2010-01-23 by Rick Blechta
I've only heard the tape library samples. In its pure form the phasing interplay of the 3 'bones is a little annoying, but probably would work better in a mix. Interesting to note that the lower end seemed muted.IMHO a better split would be the solo trombone and trumpet (starting with the lowest notes on each). A better bottom.
> Bernie-
> Â
> Â Â -Bruce D.
> Â
> Bernie
> > Hi Bernie-
> > ÃÂ ÃÂ Mine spans the keyboard, it is not the split.ÃÂ Yeah, it's a little thin at the bottom, but it's good.ÃÂ MK2 Brass or Brass B would'veÃÂ given aÃÂ Bigger Bottom (shades of SpinalTap!).
> > ÃÂ ÃÂ After living with my 'tron for a while, I'veÃÂ started to feel that a recording of a loud, blaring, razzy(?) brass section might be great ...with tubas, too!ÃÂ I don't want to start something, though.ÃÂ Hey, sustaining an 8-second loud note mightÃÂ make some of the players fall over and die.
> > ÃÂ
> > ÃÂ ÃÂ -Bruce Daily
> > --- On Fri, 1/22/10, Tron400 <kornowicz@ ..> wrote:
> > From: Tron400 <kornowicz@ ..>
> > ÃÂ
> > Bruce,
> > Bernie
> > > It's on one of my frames:Ãâà2 Trumpets & 2 Trombones; String section w/'Cello; 8 Choir.
> > > ÃâàÃâàÃâàÃâàÃâÃÂ
> > > ÃâÃÂ
> > > -Bruce D.
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > MK2 Brass
> > > Classic Strings
> > > Medieval Woodwinds
> > > MK2 Tenor Sax
> > > Sad Strings
> > > Bass Clarinet
> > > Vibes
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > Ãâà-Bruce D.
> > > Ãâà#1221
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > ÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàTrack AÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàTrack BÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàTrack C
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > 1.ÃâàÃâàVibes ÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàMKII ViolinsÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàCello
> > > 2.ÃâàÃâàRussian ChoirÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàEight ChoirÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàChurch Organ(St. John's)
> > > 3.ÃâàÃâàMKII BrassÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàTenor SaxÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàTrombone
> > > 4.ÃâàÃâàBoys ChoirÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàMale ChoirÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàFemale Choir
> > > 5.ÃâàÃâàM300A ViolinsÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàNew CelloÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàCyndeeâââ‰â¢s Viola
> > > 6.ÃâàÃâàMKII Church OrganÃâàÃâàÃâàÃâàMcDonald FluteÃâàÃâàÃâàÃâàMKI Clarinet
> > > 7.ÃâàÃâàNew String SectionÃâàÃâàÃâàÃâàOrchestraÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàWatcher Mix
> > > 8.ÃâàÃâàBass ClarinetÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàOboeÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàÃâàGlen Miller
> > > ÃâÃÂ
> > > ÃâÃÂ
> > > MkII violins
> > > M400 violins
> > > MkII trombone
> > > MkII church organ
> > > MkII flute
> > > orchestra
> > > MkII brass
> > > MkII tenor sax
> > > french horn
> > > cello
> > > cello viola mix
2010-01-24 by Fritz Doddy
On Jan 23, 2010, at 3:12 PM, Rick Blechta <rick@rickblechta.com> wrote:
On Jan 23, 2010, at 2:44 PM, Bruce Daily wrote:I've only heard the tape library samples. In its pure form the phasing interplay of the 3 'bones is a little annoying, but probably would work better in a mix. Interesting to note that the lower end seemed muted.IMHO a better split would be the solo trombone and trumpet (starting with the lowest notes on each). A better bottom.They should b oth be rerecorded because you'd certainly have something better than the original recordings, both of which are of very poor quality. The trumpet player cacks the highest note, for Pete's sake. What was that all about? Sure it's really high, but there are a lot of pros around who could cut it.Someone floated the idea of a real brass section. I'd like to propose a brass quintet, all playing at the same time. It would sound AWESOME. I guarantee it. The problem most of the "mixed voice" is that they were recorded separately. It really won't work as well as musicians all playing at the same time. One reason the 3 violins still sounds so good to us? Harry C. used 3 violinists to play it. Not one violinist 3 times. That would have sounded crappy. I've tried it.There are inherent problems using several musicians at once. More chance of mistakes, for one thing, but pros do that stuff all the time and they can pull it off. It would be a very interesting experiment to record some of the multi-instrument voices with live players doing it all at once. The choirs are all recorded this way, come to think of it, and don't they sound great? Imagine getting a full orchestra (of pros) to all start on a low G and go up from there. Your bowels would move involuntarily at high volumes when that was played back on a mellotron (to quote our Martin). Of course, I can't imagine how much recording something like that would cost...We can dream, though!Rick
2010-01-24 by Rick Blechta
Say 65 players, which is decent size, coupla hours of studio time... 13.5k on the low end, 20k on the high end for top shelf NY players. Considering the tron is mono, you could nearly the same effect with far fewer players if voiced creatively.
Sorry for the brevity as I am replying from a remote region of iPhonekstan.
2010-01-24 by lsf5275@aol.com
2010-01-24 by fdoddy@aol.com
On Jan 24, 2010, at 10:04 AM, Fritz Doddy wrote:Say 65 players, which is decent size, coupla hours of studio time... 13.5k on the low end, 20k on the high end for top shelf NY players. Considering the tron is mono, you could nearly the same effect with far fewer players if voiced creatively.
2010-01-25 by lsf5275@aol.com
MomBlog
2010-01-25 by ClayE
2010-01-25 by jonesalley
--- In newmellotrongroup@yahoogroups.com, "ClayE" <ecclesreinson@...> wrote:
> This morning, I could use a sound with the opposite effect. I know, over-sharing, but Rick brought it up.
The "brown noise." SHouldn't that be a recorder?
2010-01-25 by Bruce Daily
Date: Monday, January 25, 2010, 2:12 PM
Hmmm, must be different than white noise.In a message dated 1/25/2010 12:11:44 P.M. Eastern Standard Time, jonesalley@cox. net writes:The "brown noise." SHouldn't that be a recorder?
2010-01-26 by trawnajim
>I'm green with envy, while hoping this doesn't make me red-faced with embarrasment.
> Methinks we're getting into a gray area here.
