The Mellotron Group group photo
The Mellotron Group
Archive for newmellotrongroup.v1.
Index last updated: 2026-03-30 01:16 UTC
Head block to preamp cable replacement
2018-05-25 by fazeka@gmail.com
Hi all,
I will be adding a 47k resistor to my M400 preamp input to minimize the chance of magnetization of my heads/potential erasure of tapes. I want to also do another form of preventative maintenance and replace the head block to preamp cable to avoid cable rot which I also understand can magnetize heads and lead to partially (fully?) erased tapes, as well.
Sorry for the following ignorant questions but what kind of cable? Any specific specification? What gauge AWG? Single conductor shielded? Spiral, braided, foil shield? How about Belden 9965 or 9961? Coax (RG-59/U)? Other?
Cheers,
Chris
Re: [newmellotrongroup] Head block to preamp cable replacement
2018-05-25 by Bruce Daily
Hi-
Attached is a pic of my modified headblock setup. It shows the added resistor, maximum shield microphone cable (thanks Parts Express), phono connector, and grounding solder tab. Yes, I also modified the preamp box with a phono jack.
I bought enough cable to re-wire all the audio paths in my machine.
I didn't try to re-use the original headblock plug & jack, but I did keep them.
One thing to check: make sure the headblock is isolated from any part of the of the frame below it. It must not make contact with any part of the frame, or else noise will result. In other words, both plastic rollers must be present for ground isolation, and to allow left-right movement of the headblock. And, the headblock hold-down clips should all have plastic isolation washers.
Good luck on your 'tron adventure!
-Bruce Daily
#1221
On Fri, 5/25/18, fazeka@gmail.com [newmellotrongroup] <newmellotrongroup@yahoogroups.com> wrote:
Subject: [newmellotrongroup] Head block to preamp cable replacement
To: newmellotrongroup@yahoogroups.com
Date: Friday, May 25, 2018, 2:46 AM
Hi all,
well.
Coax (RG-59/U)? Other? ,
Cheers,
Chris
#yiv0045645030 #yiv0045645030 --
#yiv0045645030ygrp-mkp {
0;padding:0 10px;}
#yiv0045645030 #yiv0045645030ygrp-mkp hr {
border:1px solid #d8d8d8;}
#yiv0045645030 #yiv0045645030ygrp-mkp #yiv0045645030hd {
0;}
#yiv0045645030 #yiv0045645030ygrp-mkp #yiv0045645030ads {
margin-bottom:10px;}
#yiv0045645030 #yiv0045645030ygrp-mkp .yiv0045645030ad {
padding:0 0;}
#yiv0045645030 #yiv0045645030ygrp-mkp .yiv0045645030ad p {
margin:0;}
#yiv0045645030 #yiv0045645030ygrp-mkp .yiv0045645030ad a {
#yiv0045645030 #yiv0045645030ygrp-sponsor
#yiv0045645030ygrp-lc {
font-family:Arial;}
#yiv0045645030ygrp-lc #yiv0045645030hd {
margin:10px
#yiv0045645030ygrp-lc .yiv0045645030ad {
#yiv0045645030 #yiv0045645030actions {
#yiv0045645030 #yiv0045645030activity {
#yiv0045645030 #yiv0045645030activity span {
font-weight:700;}
#yiv0045645030 #yiv0045645030activity span:first-child {
text-transform:uppercase;}
#yiv0045645030 #yiv0045645030activity span a {
#yiv0045645030 #yiv0045645030activity span span {
color:#ff7900;}
.yiv0045645030underline {
text-decoration:underline;}
#yiv0045645030 .yiv0045645030attach {
0;width:400px;}
#yiv0045645030 .yiv0045645030attach div a {
#yiv0045645030 .yiv0045645030attach img {
#yiv0045645030 .yiv0045645030attach label {
#yiv0045645030 .yiv0045645030attach label a {
#yiv0045645030 blockquote {
margin:0 0 0 4px;}
#yiv0045645030 .yiv0045645030bold {
#yiv0045645030 .yiv0045645030bold a {
#yiv0045645030 dd.yiv0045645030last p a {
#yiv0045645030 dd.yiv0045645030last p span {
span.yiv0045645030yshortcuts {
margin-right:0;}
#yiv0045645030 div.yiv0045645030attach-table div div a {
#yiv0045645030 div.yiv0045645030attach-table {
width:400px;}
#yiv0045645030 div.yiv0045645030file-title a, #yiv0045645030
div.yiv0045645030file-title a:active, #yiv0045645030
div.yiv0045645030file-title a:hover, #yiv0045645030
div.yiv0045645030file-title a:visited {
#yiv0045645030 div.yiv0045645030photo-title a,
#yiv0045645030 div.yiv0045645030photo-title a:active,
#yiv0045645030 div.yiv0045645030photo-title a:hover,
#yiv0045645030 div.yiv0045645030photo-title a:visited {
#yiv0045645030 div#yiv0045645030ygrp-mlmsg
#yiv0045645030ygrp-msg p a span.yiv0045645030yshortcuts {
#yiv0045645030 .yiv0045645030green {
color:#628c2a;}
#yiv0045645030 .yiv0045645030MsoNormal {
margin:0 0 0 0;}
#yiv0045645030 o {
font-size:0;}
#yiv0045645030 #yiv0045645030photos div {
float:left;width:72px;}
#yiv0045645030 #yiv0045645030photos div div {
border:1px solid
#666666;min-height:62px;overflow:hidden;width:62px;}
#yiv0045645030 #yiv0045645030photos div label {
#yiv0045645030 #yiv0045645030reco-category {
font-size:77%;}
#yiv0045645030 #yiv0045645030reco-desc {
font-size:77%;}
#yiv0045645030 .yiv0045645030replbq {
margin:4px;}
#yiv0045645030 #yiv0045645030ygrp-actbar div a:first-child {
#yiv0045645030 #yiv0045645030ygrp-mlmsg {
sans-serif;}
#yiv0045645030 #yiv0045645030ygrp-mlmsg table {
font-size:inherit;font:100%;}
#yiv0045645030 #yiv0045645030ygrp-mlmsg select,
#yiv0045645030 input, #yiv0045645030 textarea {
#yiv0045645030 #yiv0045645030ygrp-mlmsg pre, #yiv0045645030
code {
font:115% monospace;}
#yiv0045645030 #yiv0045645030ygrp-mlmsg * {
line-height:1.22em;}
#yiv0045645030 #yiv0045645030ygrp-mlmsg #yiv0045645030logo {
padding-bottom:10px;}
#yiv0045645030 #yiv0045645030ygrp-msg p a {
font-family:Verdana;}
p#yiv0045645030attach-count span {
#yiv0045645030 #yiv0045645030ygrp-reco
#yiv0045645030reco-head {
#yiv0045645030 #yiv0045645030ygrp-reco {
#yiv0045645030 #yiv0045645030ygrp-sponsor #yiv0045645030ov
li a {
li {
ul {
margin:0;padding:0 0 0 8px;}
#yiv0045645030 #yiv0045645030ygrp-text {
font-family:Georgia;}
#yiv0045645030 #yiv0045645030ygrp-text p {
margin:0 0 1em 0;}
#yiv0045645030 #yiv0045645030ygrp-text tt {
font-size:120%;}
#yiv0045645030 #yiv0045645030ygrp-vital ul li:last-child {
border-right:none !important;
#yiv0045645030
