The Mellotron Group group photo
The Mellotron Group
Archive for newmellotrongroup.v1.
Index last updated: 2026-03-30 01:16 UTC
model 400 #1300 screwing up
2015-11-15 by tmconheady@yahoo.com
hi.
i'm doing  a lot of recording with #1300 and it started to give me problems. the motor is speeding up, slowing down, stopping and sometimes lurching fast and slow. i have one of Marcus' sms4 boards in it. when i touch the motor control cable connected to the board it seems to make the above mentioned problems go from one to another. maybe it's a short on the cable or the connector. any thoughts and or solutions from any of you owners out there?
the wires are yellow/white/green/red/ and a double gray, in that order.
i'd really appreciate any help you folks can offer.
thanks,
terry conheady  400s #1300 and #413
Re: [newmellotrongroup] model 400 #1300 screwing up
2015-11-15 by Andy Kinch
I had the same problem. It turned out to be the potentiometer of the pitch control itself. It may not be for you, but when mine was changed the problem went away.
Hope this helps?
Andy K
Sent from my iPad
On 15 Nov 2015, at 04:16, tmconheady@yahoo.com [newmellotrongroup] <newmellotrongroup@yahoogroups.com> wrote:
hi.
thanks,
2015-11-16 by Frank Stickle
I'm pretty sure the whole machine is ruined forever.
Sent from my iPad
On Nov 15, 2015, at 2:30 AM, Andy Kinch kinchmusic@aol.com [newmellotrongroup] <newmellotrongroup@yahoogroups.com> wrote:
Hope this helps?
Andy K
Sent from my iPad
hi.
thanks,
2015-11-16 by fdoddy@aol.com
hahahaha!
From: Frank Stickle lsf5275@aol.com [newmellotrongroup] <newmellotrongroup@yahoogroups.com>
To: newmellotrongroup <newmellotrongroup@yahoogroups.com>
Sent: Mon, Nov 16, 2015 7:18 am
Subject: Re: [newmellotrongroup] model 400 #1300 screwing up
Sent from my iPad
Hope this helps?
Andy K
Sent from my iPad
hi.
thanks,
2015-11-16 by John Barrick
For proper disposal, FREE OF CHARGE, simply ship to my convenient Iowa recycling facility, Terry.
On Mon, Nov 16, 2015 at 11:26 AM, fdoddy@aol.com [newmellotrongroup] <newmellotrongroup@yahoogroups.com> wrote:
hahahaha!
Sent from my iPad
Hope this helps?
Andy K
Sent from my iPad
hi.
thanks,
john barrick
*Leo got it right the first time*
*then he added a second pickup and got it righter*
2015-11-17 by gino wong
The "NOT" screaming cable rot.
On Mon, Nov 16, 2015 at 6:44 PM, John Barrick barrickjohn262@gmail.com [newmellotrongroup] <newmellotrongroup@yahoogroups.com> wrote:
hahahaha!
Sent from my iPad
Hope this helps?
Andy K
Sent from my iPad
hi.
thanks,
john barrick
Gino Wong Birgelo  BSComm, BSEE, PhP
ReRed Recording
Girard Hall Studios (ReRed Treehouse)
527 W. Girard Avenue
Philadelphia, PA 19123 USA
215 717 7059
2015-11-17 by Terry Conheady
hey.
suppose i detach the motor and install a hand crank.
i think it's in the cable as i was able to use it for a bit by taping the cable in a certain position that allowed it to play stable. that, however, stopped working. now all i get by moving the cable is real fast or stopped. could i shorten the cable and solder the cut end to the plug, or maybe just replace the cable with a new one or even use the cable from #413 as i rarely use it because it still has sms10 board in it.
On Monday, November 16, 2015 7:18 AM, "Frank Stickle lsf5275@aol.com [newmellotrongroup]" <newmellotrongroup@yahoogroups.com> wrote:
Sent from my iPad
Hope this helps?
Andy K
Sent from my iPad
hi.
thanks,
2015-11-17 by John Barrick
That's certainly worth trying, Terry.  I go for replacing the cable rather than stealing from your other machine.
On Mon, Nov 16, 2015 at 7:01 PM, Terry Conheady tmconheady@yahoo.com [newmellotrongroup] <newmellotrongroup@yahoogroups.com> wrote:
hey.
Sent from my iPad
Hope this helps?
Andy K
Sent from my iPad
hi.
thanks,
john barrick
2015-11-17 by lsf5275@aol.com
Check for a bad solder joint at both ends of the cable.
In a message dated 11/16/2015 9:04:38 P.M. Eastern Standard Time, newmellotrongroup@yahoogroups.com writes:
hey.
Sent from my iPad
Hope this helps?
Andy K
Sent from my iPad
hi.
thanks,
john barrick
2015-11-17 by Chris Dale
If you've got cable rot and you've moved the cable around, then you might now have magnetized tape heads as well.
Demagnetize.
On Mon, Nov 16, 2015 at 9:05 PM, lsf5275@aol.com [newmellotrongroup] <newmellotrongroup@yahoogroups.com> wrote:
hey.
Sent from my iPad
Hope this helps?
Andy K
Sent from my iPad
hi.
thanks,
john barrick
Re: model 400 #1300 screwing up
2015-11-17 by Berington Van Campen
Hey Terry,
Andy's comment about replacing the pitch control pot got me thinking. That was really painful, but it happened. My experience has been that 99.9947% of the time, give or take a digit or two, (did I just refer to "digital?"), a quick shot of good contact cleaner will fix any bad contact in the pot, unless it IS a bad solder joint - but that's actually pretty rare - and you'll be up and running in literally a minute or two.
Not long ago, I saved our keyboard player a couple hundred dollars to a tech guy with his Kurzweil 2661, when a key or two went out. A few minutes of minor surgery, some reference to a "Kurzweil Guru" online, and my trusty contact cleaner, and we had all his under-key contacts AND while we were there, all the other electrical/audio/PCB connections, cleaned and working perfectly in short order.  Not much unlike cleaning, de-magging the heads and other such sorta tedious-but-not-unpleasant maintenance in your Mellotron, except cleaning the pot's that much easier.  Definitely give it a try before going into surgery for a pot transplant!
Note: I'm SURE it needn't be said, but do keep in mind, considering my above reference, that contact cleaner, tape head cleaner, WD-40 and/or alcohol, etc., are NOT one and the same.  I've seen people cross-use those things (my keyboard player would be one to do that, God love 'im), with disastrous results.  The contact cleaner is what you want.  "DeOx-It" [sp?] is one of the best.  Save the alcohol til your 'Tron's working perfectly again, then apply liberally and systemically if you'd like, preferably with friends or S.Os. That COULD be compared by some to "head cleaner"... or not.  (-:  A pint of Guinness works nicely in that regard.  Here's to your Happy Pitch Control!
Cheers!
B
Van Campen Productions / V.C.MusiCorp Scoring Services / Sessions
VCMusiCorp1@yahoo.com
The BEATUNES - Beatles Tribute Band
www.TheBeatunes.com
(626) 458-4474 - Home/Office
www.facebook.com/beringto
Not likely since the cable in question is from the pitch pot to the SMS. This has nothing to do with the tape heads.
In a message dated 11/17/2015 2:49:46 A.M. Eastern Standard Time, newmellotrongroup@yahoogroups.com writes:
Demagnetize.
hey.
Sent from my iPad
Hope this helps?
Andy K
Sent from my iPad
hi.
thanks,
john barrick
Okay, sorry I thought it was the headblock cable.
In this case, yeah I'd clean the cables and connectors, and proceed from there.
On Tue, Nov 17, 2015 at 12:40 PM, lsf5275@aol.com [newmellotrongroup] <newmellotrongroup@yahoogroups.com> wrote:
Demagnetize.
hey.
Sent from my iPad
Hope this helps?
Andy K
Sent from my iPad
hi.
thanks,
john barrick
2015-11-18 by Bruce Daily
Hi guys-
Here is a suggestion. If wiggling the cable at the control box causes the speed changes, yep, it is something in the box or the potentiometer. If wiggling the cable at the SMS card end causes the speed changes, first try cleaning the card edge connector. The pads on the card edge can be cleaned with a fresh pencil eraser (remember pencils?), followed with some alcohol or contact cleaner. Be careful cleaning the connector. Be creative and try not to bend the contacts. If still no workee, resolder the offending wires to the connector. While you're at it, it might be a good idea to clean both connectors on the SMS card. Hope this helps.
-Bruce Daily
On Tue, 11/17/15, Chris Dale unobtainiumkeys@gmail.com [newmellotrongroup] <newmellotrongroup@yahoogroups.com> wrote:
To: newmellotrongroup@yahoogroups.com
Date: Tuesday, November 17, 2015, 4:50 PM
In this case, yeah
there.
heads.
Standard Time,
writes:
Demagnetize.
writes:
Terry.  I go for
other machine.
On Mon, Nov 16,
wrote:
hey.
install a hand
crank.
allowed it to play
get by moving the
with a new one or
sms10 board in it.
On
forever.
Sent from my
iPad
but when mine was
Hope this helps?
Andy K
Sent
from my iPad
wrote:
hi.
with #1300 and it
have one of Marcus'
out
there?
and a double gray,
in that order.
you folks can
offer.
thanks,
#413
john barrick
righter*
#yiv0056971448 #yiv0056971448 --
#yiv0056971448ygrp-mkp {
0;padding:0 10px;}
#yiv0056971448 #yiv0056971448ygrp-mkp hr {
border:1px solid #d8d8d8;}
#yiv0056971448 #yiv0056971448ygrp-mkp #yiv0056971448hd {
0;}
#yiv0056971448 #yiv0056971448ygrp-mkp #yiv0056971448ads {
margin-bottom:10px;}
#yiv0056971448 #yiv0056971448ygrp-mkp .yiv0056971448ad {
padding:0 0;}
#yiv0056971448 #yiv0056971448ygrp-mkp .yiv0056971448ad p {
margin:0;}
#yiv0056971448 #yiv0056971448ygrp-mkp .yiv0056971448ad a {
#yiv0056971448 #yiv0056971448ygrp-sponsor
#yiv0056971448ygrp-lc {
font-family:Arial;}
#yiv0056971448ygrp-lc #yiv0056971448hd {
margin:10px
#yiv0056971448ygrp-lc .yiv0056971448ad {
#yiv0056971448 #yiv0056971448actions {
#yiv0056971448 #yiv0056971448activity {
#yiv0056971448 #yiv0056971448activity span {
font-weight:700;}
#yiv0056971448 #yiv0056971448activity span:first-child {
text-transform:uppercase;}
#yiv0056971448 #yiv0056971448activity span a {
#yiv0056971448 #yiv0056971448activity span span {
color:#ff7900;}
.yiv0056971448underline {
text-decoration:underline;}
#yiv0056971448 .yiv0056971448attach {
0;width:400px;}
#yiv0056971448 .yiv0056971448attach div a {
#yiv0056971448 .yiv0056971448attach img {
#yiv0056971448 .yiv0056971448attach label {
#yiv0056971448 .yiv0056971448attach label a {
#yiv0056971448 blockquote {
margin:0 0 0 4px;}
#yiv0056971448 .yiv0056971448bold {
#yiv0056971448 .yiv0056971448bold a {
#yiv0056971448 dd.yiv0056971448last p a {
#yiv0056971448 dd.yiv0056971448last p span {
span.yiv0056971448yshortcuts {
margin-right:0;}
#yiv0056971448 div.yiv0056971448attach-table div div a {
#yiv0056971448 div.yiv0056971448attach-table {
width:400px;}
#yiv0056971448 div.yiv0056971448file-title a, #yiv0056971448
div.yiv0056971448file-title a:active, #yiv0056971448
div.yiv0056971448file-title a:hover, #yiv0056971448
div.yiv0056971448file-title a:visited {
#yiv0056971448 div.yiv0056971448photo-title a,
#yiv0056971448 div.yiv0056971448photo-title a:active,
#yiv0056971448 div.yiv0056971448photo-title a:hover,
#yiv0056971448 div.yiv0056971448photo-title a:visited {
#yiv0056971448 div#yiv0056971448ygrp-mlmsg
#yiv0056971448ygrp-msg p a span.yiv0056971448yshortcuts {
#yiv0056971448 .yiv0056971448green {
color:#628c2a;}
#yiv0056971448 .yiv0056971448MsoNormal {
margin:0 0 0 0;}
#yiv0056971448 o {
font-size:0;}
#yiv0056971448 #yiv0056971448photos div {
float:left;width:72px;}
#yiv0056971448 #yiv0056971448photos div div {
border:1px solid
#666666;height:62px;overflow:hidden;width:62px;}
#yiv0056971448 #yiv0056971448photos div label {
#yiv0056971448 #yiv0056971448reco-category {
font-size:77%;}
#yiv0056971448 #yiv0056971448reco-desc {
font-size:77%;}
#yiv0056971448 .yiv0056971448replbq {
margin:4px;}
#yiv0056971448 #yiv0056971448ygrp-actbar div a:first-child {
#yiv0056971448 #yiv0056971448ygrp-mlmsg {
sans-serif;}
#yiv0056971448 #yiv0056971448ygrp-mlmsg table {
font-size:inherit;font:100%;}
#yiv0056971448 #yiv0056971448ygrp-mlmsg select,
#yiv0056971448 input, #yiv0056971448 textarea {
#yiv0056971448 #yiv0056971448ygrp-mlmsg pre, #yiv0056971448
code {
font:115% monospace;}
#yiv0056971448 #yiv0056971448ygrp-mlmsg * {
line-height:1.22em;}
#yiv0056971448 #yiv0056971448ygrp-mlmsg #yiv0056971448logo {
padding-bottom:10px;}
#yiv0056971448 #yiv0056971448ygrp-msg p a {
font-family:Verdana;}
p#yiv0056971448attach-count span {
#yiv0056971448 #yiv0056971448ygrp-reco
#yiv0056971448reco-head {
#yiv0056971448 #yiv0056971448ygrp-reco {
#yiv0056971448 #yiv0056971448ygrp-sponsor #yiv0056971448ov
li a {
li {
ul {
margin:0;padding:0 0 0 8px;}
#yiv0056971448 #yiv0056971448ygrp-text {
font-family:Georgia;}
#yiv0056971448 #yiv0056971448ygrp-text p {
margin:0 0 1em 0;}
#yiv0056971448 #yiv0056971448ygrp-text tt {
font-size:120%;}
#yiv0056971448 #yiv0056971448ygrp-vital ul li:last-child {
border-right:none !important;
#yiv0056971448
