The Mellotron Group group photo
The Mellotron Group
Archive for newmellotrongroup.v1.
Index last updated: 2026-03-30 01:16 UTC
Effects
Effects
2013-02-10 by tron400
Do you use a tube preamp or EQ on your M400/MkV? I'm considering one or both for my M400.
Bernie
RE: [newmellotrongroup] Effects
2013-02-10 by Tom Doncourt
yes
From: newmellotrongroup@yahoogroups.com [newmellotrongroup@yahoogroups.com] on behalf of tron400 [tron400@yahoo.com]
Sent: Saturday, February 09, 2013 8:00 PM
To: newmellotrongroup@yahoogroups.com
Subject: [newmellotrongroup] Effects
Bernie
Re: Effects
OK, but which or both? Brands?
--- In newmellotrongroup@yahoogroups.com, Tom Doncourt wrote:
> yes
> From: newmellotrongroup@yahoogroups.com [newmellotrongroup@yahoogroups.com] on behalf of tron400 [tron400@...]
> Bernie
RE: [newmellotrongroup] Re: Effects
I really like my UA 610 ...I go from that into an amp(Reeves) and use the tone controls then miked .
Sent: Saturday, February 09, 2013 10:04 PM
Subject: [newmellotrongroup] Re: Effects
> yes
> Bernie
Re: Effects
Just looked at some on eBay. A little out of my price range, but it looks like a really nice unit.
Bernie
> --- In newmellotrongroup@yahoogroups.com , Tom Doncourt wrote:
> > yes
> > From: newmellotrongroup@yahoogroups.com [newmellotrongroup@yahoogroups.com ] on behalf of tron400 [tron400@]
> > Bernie
Hi Bernie,  Prosonus also makes a DI/Pre with a tube in it for a little over $100.I've used them on the tron as well and  I like it alot.
Sent: Sunday, February 10, 2013 8:19 AM
Bernie
> > yes
> > Bernie
Re: [newmellotrongroup] Effects
2013-02-10 by fdoddy@aol.com
Sadly, I generally don't use either when going into the computer. All my processing to date has been in the box.  Occasionally, I'll run it through my little ART Tubecomp (best $209 I ever spent) for a darker character. Once in a while it'll go through a guitar amp, and I have yet to dump it into my leslie cabinet
I am contemplating the next phase of my home studio, which will include at least one analog high end channel strip.  This will allow me to shape all the analog goodies.  My one real desire for the tron is to have a high pass filter and some nice EQ going in.  The tron output is hot so I would need something with a pad as well.
There are a lot of good options for channel strips out there, including those that feature tube as well as solid state circuits in the same unit.
fritz
To: newmellotrongroup <newmellotrongroup@yahoogroups.com>
Sent: Sat, Feb 9, 2013 8:01 pm
Bernie
Re: [newmellotrongroup] Re: Effects
At work I have a bunch of those Vintech NEVE knock offs and a few Summits.  I don't like the Summits.
 I also have a ProSonus TubePre!! I use it at least  fifty percent of the time. I would give the Prosonus stuff a look.  I know a lot of guys in the NY studios who keep s Prosonus strip and also an ART strip in their rack.  One friend calls his Prosonus strip his secret weapon....
fritz
Sent: Sun, Feb 10, 2013 8:19 am
Bernie
> > yes
> > Bernie
Just saw this. This is the little tube pre I use at work.  It's really nice!
fritz
Sent: Sun, Feb 10, 2013 9:13 am
Subject: RE: [newmellotrongroup] Re: Effects
Bernie
> > yes
> > Bernie
2013-02-10 by John Hammaren
Hi Bernie,
I use the ART Prochannel II. They offer a lot of value for the price. It’s hard to find a tube pre in the price range of these. I have another ART over ten years old and still works great.
Regards, John
From: newmellotrongroup@yahoogroups.com [mailto:newmellotrongroup@yahoogroups.com] On Behalf Of tron400
Bernie
> > yes
> > Bernie
Yes!  A very nice unit.
 Here is the link to the unit I've seen some folks using. I'm going to give it a try as well...
http://www.presonus.com/products/Studio-Channel
fritz
Sent: Sun, Feb 10, 2013 9:36 am
Hi Bernie,
Regards, John
Bernie
> > yes
> > Bernie
At the end link of my syatem there are two prosonus tubepres that give a little extra punch and route things to the monitor amps and the mains. That means that everything goes through them- and I have no complaints!!
From: newmellotrongroup@yahoogroups.com [newmellotrongroup@yahoogroups.com] on behalf of fdoddy@aol.com [fdoddy@aol.com]
Sent: Sunday, February 10, 2013 9:41 AM
Subject: Re: [newmellotrongroup] Re: Effects
fritz
Hi Bernie,
Regards, John
Bernie
> > yes
> > Bernie
Re: Effects
The ART Prochannel II and the PreSonus Channel strip both look really nice and the price is the same, but both of my Trons are going through a Joe Meek MC2 compressor, so the ART and PreSonus have more features than I really need. Maybe a PreSonus Blue Tube would be more my speed.
How about a graphic equalizer? Is it worthwhile having on an M400?
Bernie
> From: newmellotrongroup@yahoogroups.com [newmellotrongroup@yahoogroups.com] on behalf of fdoddy@... [fdoddy@...]
> fritz
> -----Original Message-----
> From: John Hammaren
> Hi Bernie,
> I use the ART Prochannel II. They offer a lot of value for the price. It's hard to find a tube pre in the price range of these. I have another ART over ten years old and still works great.
> Regards, John
> From: newmellotrongroup@yahoogroups.com [mailto:newmellotrongroup@yahoogroups.com ] On Behalf Of tron400
> Bernie
> > > yes
> > > Bernie
I'd go with parametric, or something tunable myself.
fritz
Sent: Sun, Feb 10, 2013 12:06 pm
Bernie
> fritz
> From: John Hammaren
> Hi Bernie,
> Regards, John
> Bernie
> > > yes
> > > Bernie
2013-02-10 by Jack Younger
I have this thing about using too much in the signal flow....I've found the only reason to go through anything other than a nice direct box (we have a few custom ones with Jensen xformers in 'em) and a decent compressor, is if the signal is going to digital.  BUT, the signal is, after all, tape-generated...should be more than enough ooey-gooey goodness coming right out of the tron.  A tube pre or compressor will simply add more touches of harmonic distortion, which is fine if you are going for something darker, murky or sizzly.
It's a concept I always argue about with audiophiles who swear by tube preamplification;  There should be as little signal interruption and coloration between the sound and your ears.  Solid state preamps/amps will give you wider bandwidth and a cleaner signal with a much flatter response.  Granted, they aren't nearly as romantic and don't look as cool, but we're talking sound quality, here.
Also, when speaking of preamps and compressors, while the ART and Presonus stuff is inexpensive, they are really just using the tube stage for color as opposed to using the tube within the circuit as part of it's function, which is what makes things like UA, Ampex and Pultec so special.
I would say, for recording, if you are unable to afford a pro tube unit, just go direct.  Or mic a decent amp if you want a little rectifier push from some tube wattage.  For live use, just keep it as simple as possible.  Less is more.
Then again, if you use one of the aforementioned devices to pleasant result, keep using them.  If it suits you, who am I to argue.
Sent: Sunday, February 10, 2013 1:05 PM
fritz
Bernie
> fritz
> From: John Hammaren
> Hi Bernie,
> Regards, John
> Bernie
> > > yes
> > > Bernie
Re: Effects
Just to clarify, here's my Mellotron path (and Hammond SK1 and Dotcom modular synth):
Tron --> Mackie DFX-12 |--> Joe Meek MC3 |-->
|--> Lexicon MX300 |--> Echo Mia sound card --> Onkyo TX-8511 --> JBL 4311's
I'm only considering adding a tube preamp and EQ to my M400, not my M4000 or other instruments.
Oh yeah, the Dotcom has its own dedicated Lexicon MX300, primarily for sequencer delay effects.
Bernie
> From: "fdoddy@..."
> fritz
> From: tron400
> Bernie
> > From: newmellotrongroup@yahoogroups.com [newmellotrongroup@yahoogroups.com] on behalf of fdoddy@ [fdoddy@]
> > fritz
> > From: John Hammaren
> > Hi Bernie,
> > Regards, John
> > Bernie
> > > > yes
> > > > Bernie
Re: Effects
Well that didn't format too well. The MC2 and MX300 are both sidechained (I think).
Bernie
> Bernie
> > From: "fdoddy@"
> > fritz
> > From: tron400
> > Bernie
> > > fritz
> > > From: John Hammaren
> > > Hi Bernie,
> > > Regards, John
> > > Bernie
> > > > > yes
> > > > > Bernie
2013-02-10 by lsf5275@aol.com
So all you newcomers to the group, this is how, after you make a pretty convincing point, you carefully CYA.  Nice one!
In a message dated 2/10/2013 2:41:44 P.M. Eastern Standard Time, e4103s@yahoo.com writes:
2013-02-10 by john barrick
Hey!  Maybe I can use that one at work!
john barrick
*Leo got it right the first time*
*then he added a second pickup and got it righter*
2013-02-11 by fdoddy@aol.com
It's true though...whatever gets it done!
Sent: Sun, Feb 10, 2013 5:01 pm
2013-02-11 by Jack Younger
If it's one thing I've learned over all these years, it's that everyone is allowed to hear what ever they want to.
Sent: Sunday, February 10, 2013 5:01 PM
2013-02-11 by lsf5275@aol.com
Everyone except for... Hellen Keller
In a message dated 2/10/2013 11:33:08 P.M. Eastern Standard Time, e4103s@yahoo.com writes:
