The Mellotron Group group photo
The Mellotron Group
Index last updated: 2026-03-31 01:43 UTC
Re: [newmellotrongroup] Re: mellotron problem...resolved :-)))
2012-11-02 by Casterman Jean
Hello Guys,
Sorry for this late reply but thanks so much for your responses :-)
I finally resolved the problem,it seems that my tron works great now.
In fact it was a problem with the metal lid of the storage box.
The metal lid was so far from the pinchroller (5 or 6 mm)
I put the metal lid l on the storage box (without fixing it) about 3 mm from the pinch roller away and it's seems that the tron works again (I only had a problem with One tape,I think that the tape have some creases and is really damaged but for the rest,it's perfect)
I never found the problem without the help of klaus hoffmann and martin from streetly.
I made a video with the problem and send this video to klaus and martin...and I don't know how but those guys found directly the problem,it was really awesome...those guys are really incredible.
It's really great that's those guys are not business man but really passionnate and helpful.
I bought this mellotron from klaus hoffmann some month ago and I'm more than happy because this guy is nicest seller and so helpful and up for grabs.he is really a passionnate by the mellotron and gives some soul to my tron.
Martin was soooo helpful and nice too.those guys are fantastics.
I tought that it was only business but now I found nice poeple who can help me without any profit and it's so rare nowadays....
If you need to repair your tron in Europe,the best places are Klaus and streetly for sure.
I can't imagine buying mellotron stuff in another places now.
Thanks again to all of us who help me and an HUUUGGGEEE thanks to martin and Klaus
Jean
Ps sorrry for my pooor english
To: newmellotrongroup@yahoogroups.com
Sent: Thursday, October 11, 2012 6:04 AM
Subject: Re: [newmellotrongroup] Re: mellotron problem...
Yes these are the correct adjustments for all this.
But be sure that your rollers and pressure pads are clean and free of dust, and that the tape heads, and tape guides, and tape spillbox also don't have tape particle dust all over them.
Tape particle dust creates an extra friction that occasionally gets in the way of proper performance especially with older machines that haven't been serviced.
Basically everything needs to be clean before these adjustments are done, and then everything works great.
And don't forget any screwdriver must be de-magnetized before bringing it near the machine. :)
It wouldn't hurt to also remove any magnetic metal watches. You'll want to take your time anyway
On Wed, Oct 10, 2012 at 8:46 AM, tron400 <tron400@yahoo.com> wrote:
Jean, Martin posted the following information about keyboard adjustments a while ago. It was really helpful for me. Maybe it will be helpful to you. If not, keep asking questions. Someone will be able to answer them. Pads: a good pad should come from silence to a full sound in 1/4 turn of the adjustment screw. From there you should add 1/2 turn further to establish a good setting. Rollers: a good roller should come up to full speed from stall in 1/2 turn max. From there you should add 1 full turn to establish a good setting. Keys: undo the backnut until the key drops away from the bar. Now tighten the nut until the key just touches the rubber strip and add 1/8 turn. This is the correct back pressure. Too little and the key will flap, too much and it will feel like a girder. Key depth: press down a black ket between two white keys at either end of the keyboard. The key should be no more than 1/6th of an inch above the white key otherwise the action will feel shallow and 'orrible. If you have the above settings your tron will be a delight. If you don't, it won't.
Bernie --- In mailto:newmellotrongroup%40yahoogroups.com, Casterman Jean <jycasterman@...> wrote: >
> Thanks for your mail Bernie,it's fair ;-)
> Â
> I knew this web page but I'm really new in the mellotron world and I'm not sure to understand very well all the mechanical stuffs
> Yesterday,I tried to adjust (pinchroller and pressure screw)Â only one key but it doesn't change anything on this particular key...the tape was crinkle in the pinch roller... > Â
> Once again thanks for your help > >
> ________________________________ > From: tron400 <tron400@...>
> To: mailto:newmellotrongroup%40yahoogroups.com > Sent: Wednesday, October 10, 2012 12:26 PM > Subject: [newmellotrongroup] Re: mellotron problem... > >
> Â
> > Jean, sounds like your keyboard needs adjusting. Please read this for symptoms and adjustment instructions: > > http://www.kleonard.com/mellotron/mellotronia/techtalk.htm > > Bernie >
> --- In mailto:newmellotrongroup%40yahoogroups.com, Casterman Jean <jycasterman@> wrote: > > > > Hi Guys, > >  > > I bought a M400 some months ago .it is a refurbished mellotron (with a new tapeframe and the old CMC 10)
> > The mellotron works perfectly until last week. > > Here's my problem:
> > I don't know why but a lot of tapes/notes (16 notes/tapes per sound bank)  gets hung up(jam,crinkle) in the pinchrollers and won't come back out, the tapes wont'fall. > > I cleaned the pinchrollers,capstan,tape heads,pads with isopropyl alchool but the problem is still present and the some tape are a little bit damaged(some creases on the tapes).
> > I don't know how can I resolve this problem but it's really tricky....
> > Â
> > It' seems it's a comon problem but I don't know what's the cause of this problems ,I have a dry room with a dehumidifier (No more than 53% moisture in my studio)
> > Â
> > I feel a little bit helpless to resolve this problem
> > Â
> > Thanks for your help and sorry for my bad english
> > Â > > Â > > Jean > > >
2012-11-02 by lsf5275@aol.com
Everyone knows Klaus, but who is this 'Martin'?
Sent from my Verizon Wireless 4G LTE DROID
Casterman Jean &lt;jycasterman@yahoo.com&gt; wrote:
Hello Guys,
Jean
> Â
> Â
> > Â
> > Â
> > Â
"Everyone knows Klaus, but who is this 'Martin'?"
I tought everybody knows(.... as leonard cohen say...) that martin smith was the brother of robert....he help me to find............ a cure..........for my tron
To: Casterman Jean <jycasterman@yahoo.com>
Cc: newmellotrongroup@yahoogroups.com
Sent: Friday, November 2, 2012 6:55 PM
Subject: Re: [newmellotrongroup] Re: mellotron problem...resolved :-)))
Hello Guys,
Jean
> Â
> Â
> > Â
> > Â
> > Â
Everybody knows... A great song by LC.
Hello Guys,
Jean
> Â
> Â
> > Â
> > Â
> > Â
