Jean,
Martin posted the following information about keyboard adjustments a while ago. It was really helpful for me. Maybe it will be helpful to you. If not, keep asking questions. Someone will be able to answer them.
Pads: a good pad should come from silence to a full sound in 1/4 turn of the adjustment screw. From there you should add 1/2 turn further to establish a good setting.
Rollers: a good roller should come up to full speed from stall in 1/2 turn max. From there you should add 1 full turn to establish a good setting.
Keys: undo the backnut until the key drops away from the bar. Now tighten the nut until the key just touches the rubber strip and add 1/8 turn. This is the correct back pressure. Too little and the key will flap, too much and it will feel like a girder.
Key depth: press down a black ket between two white keys at either end of the keyboard. The key should be no more than 1/6th of an inch above the white key otherwise the action will feel shallow and 'orrible.
If you have the above settings your tron will be a delight. If you don't, it won't.
> Thanks for your mail Bernie,it's fair ;-)
> Â
> I knew this web page but I'm really new in the mellotron world and I'm not sure to understand very well all the mechanical stuffs
> Yesterday,I tried to adjust (pinchroller and pressure screw)Â only one key but it doesn't change anything on this particular key...the tape was crinkle in the pinch roller...
> Â
> Once again thanks for your help
> From: tron400 <tron400@...>
> Â
> --- In mailto:
newmellotrongroup%40yahoogroups.com, Casterman Jean <jycasterman@> wrote:
> > Hi Guys,
> > Â
> > I bought a M400 some months ago .it is a refurbished mellotron (with a new tapeframe and the old CMC 10)
> > The mellotron works perfectly until last week.
> > Here's my problem:
> > I don't know why but a lot of tapes/notes (16 notes/tapes per sound bank)  gets hung up(jam,crinkle) in the pinchrollers and won't come back out, the tapes wont'fall.
> > I cleaned the pinchrollers,capstan,tape heads,pads with isopropyl alchool but the problem is still present and the some tape are a little bit damaged(some creases on the tapes).
> > I don't know how can I resolve this problem but it's really tricky....
> > Â
> > It' seems it's a comon problem but I don't know what's the cause of this problems ,I have a dry room with a dehumidifier (No more than 53% moisture in my studio)
> > Â
> > I feel a little bit helpless to resolve this problem
> > Â
> > Thanks for your help and sorry for my bad english
> > Â
> > Â
> > Jean
