Grounding Issue?
2012-02-24 by tron400
Index last updated: 2026-03-31 23:34 UTC
2012-02-24 by john barrick
On Fri, Feb 24, 2012 at 2:45 PM, tron400 <tron400@yahoo.com> wrote:--
#500 has had an intermittant hum for a while now. I thought that maybe it was related to the volume pedal jack, but I noticed yesterday that the volume of the hum changes when I move the track selector. Track C doesn't seem to have any hum, but Tracks A and B do. Any idea what the cause might be?
Berniejohn barrick*Leo got it right the first time**then he added a second pickup and got it righter*
On Fri, Feb 24, 2012 at 2:53 PM, john barrick <barrickjohn262@gmail.com> wrote:
Maybe the cable going from the head block to the preamp?On Fri, Feb 24, 2012 at 2:45 PM, tron400 <tron400@yahoo.com> wrote:
Bernie
-john barrick*Leo got it right the first time**then he added a second pickup and got it righter*
2012-02-25 by Bruce Daily
Bernie
2012-02-25 by lsf5275@aol.com
Bernie
Hey Bernie-The headblock must remain electrically isolated from the chassis to avoid this.Last time this happened to me I had a missing headblock roller (previous owner's fault, which I fixed). Therefore, the headblock was rubbing the chassis, which changed the hum when different tracks were selected. A bad cable can also cause this problem, but it is usually screechy(not good for tapes). Check the w-clips that hold down the headblock, their centering washers may be off-set or worn through, and may be causing the short. You may have to remove the headblock to fix this one.The track selector mechanism can also cause this short. However, if this is the machine that Jerry Korb refurbished, he probably already fixed this.Hope this helps, best of luck. More sugar!-Bruce Daily
To: newmellotrongroup@yahoogroups.com
Sent: Friday, February 24, 2012 1:55 PM
Subject: Re: [newmellotrongroup] Grounding Issue?
Try putting it in the C position and then wiggle the cable a bit while playing a note. That may reproduce it.
Bernie
2012-02-25 by tron400
--- In newmellotrongroup@yahoogroups.com, lsf5275@... wrote:
> Good call Bruce... I didn't see your post or I wouldn't have repeated the
> information.
> Frank
> In a message dated 2/25/2012 1:30:16 A.M. Eastern Standard Time,
> pocotron@... writes:
> Hey Bernie-
> avoid this.
> this.
> -Bruce Daily
> From: john barrick <barrickjohn262@...>
> On Fri, Feb 24, 2012 at 2:53 PM, john barrick <_barrickjohn262@..._
> On Fri, Feb 24, 2012 at 2:45 PM, tron400 <_tron400@..._
> Bernie
> john barrick
2012-02-26 by tron400
--- In newmellotrongroup@yahoogroups.com, "tron400" <tron400@...> wrote:
> Wouldn't you know, it's not acting up at the moment. I'll have to leave it running for a while.
> Jerry put a new cable in when he refurbished it. The old one had the screeching cable rot.
> BTW, anyone have an empty frame laying around?
> Bernie
> > information.
> > Frank
> > pocotron@ writes:
> > Hey Bernie-
> > avoid this.
> > this.
> > -Bruce Daily
> > From: john barrick <barrickjohn262@>
> > On Fri, Feb 24, 2012 at 2:53 PM, john barrick <_barrickjohn262@_
> > On Fri, Feb 24, 2012 at 2:45 PM, tron400 <_tron400@_
> > Bernie
> > john barrick
2012-02-26 by lsf5275@aol.com
Looks like it was one of the spring hooks that holds the head block in place. One of them was not in its hole.
Bernie
> Bernie
> > information.
> > Frank
> > pocotron@ writes:
> > Hey Bernie-
> > avoid this.
> > this.
> > -Bruce Daily
> > Bernie
> > john barrick
2012-02-26 by Mark
On 2/26/12, lsf5275@aol.com <lsf5275@aol.com> wrote:
> With Mellotrons, as with Harley Davidsons, start with the simplest
> possibility and work your way up. Most of the problems are resolved at
> 'simple."
> Glad you found and fixed it.
> Frank
> In a message dated 2/25/2012 7:34:31 P.M. Eastern Standard Time,
> tron400@yahoo.com writes:
> Bernie
> --- In _newmellotrongroup@yahoogroups.com_
> (mailto:newmellotrongroup@yahoogroups.com) , "tron400" <tron400@...> wrote:
>> Bernie
> the
>> > information.
>> > Frank
>> > pocotron@ writes:
>> > Hey Bernie-
>> > avoid this.
> (previous
> the
> bad
> for
> centering
> You may
> fixed
>> > this.
>> > -Bruce Daily
>> > To: _newmellotrongroup@yahoogroups.com_
> it
> doesn't seem
> be?
>> > Bernie
>> > john barrick
2012-02-26 by william Beith
Bernie
> Bernie
> > information.
> > Frank
> > pocotron@ writes:
> > Hey Bernie-
> > avoid this.
> > this.
> > -Bruce Daily
> > Bernie
> > john barrick
2012-02-26 by Bruce Daily
Hey Bernie-The headblock must remain electrically isolated from the chassis to avoid this.Last time this happened to me I had a missing headblock roller (previous owner's fault, which I fixed). Therefore, the headblock was rubbing the chassis, which changed the hum when different tracks were selected. A bad cable can also cause this problem, but it is usually screechy(not good for tapes). Check the w-clips that hold down the headblock, their centering washers may be off-set or worn through, and may be causing the short. You may have to remove the headblock to fix this one.The track selector mechanism can also cause this short. However, if this is the machine that Jerry Korb refurbished, he probably already fixed this.Hope this helps, best of luck. More sugar!-Bruce DailyFrom: john barrick <barrickjohn262@gmail.com>
Bernie
Frank-You taught us well, Obi-Wan, thank you! Looks like Bernie found it.-Bruce D.
Sent: Saturday, February 25, 2012 12:04 AM
Good call Bruce... I didn't see your post or I wouldn't have repeated the information.FrankIn a message dated 2/25/2012 1:30:16 A.M. Eastern Standard Time, pocotron@yahoo.com writes:Hey Bernie-The headblock must remain electrically isolated from the chassis to avoid this.Last time this happened to me I had a missing headblock roller (previous owner's fault, which I fixed). Therefore, the headblock was rubbing the chassis, which changed the hum when different tracks were selected. A bad cable can also cause this problem, but it is usually screechy(not good for tapes). Check the w-clips that hold down the headblock, their centering washers may be off-set or worn through, and may be causing the short. You may have to remove the headblock to fix this one.The track selector mechanism can also cause this short. However, if this is the machine that Jerry Korb refurbished, he probably already fixed this.Hope this helps, best of luck. More sugar!-Bruce DailyFrom: john barrick <barrickjohn262@gmail.com>
Bernie
> Actually, you led him to this one.
> In a message dated 2/26/2012 1:55:59 A.M. Eastern Standard Time,
> Frank-
> -Bruce D.
> From: "lsf5275@..." <lsf5275@...>
> information.
> Frank
> Hey Bernie-
> avoid this.
> this.
> -Bruce Daily
> Bernie
> john barrick
