Re: [motm] Re: Balanced/Unbalanced - P.S.
2001-02-04 by ivancu@aol.com
In a message dated 2/3/01 8:15:14 PM, mate_stubb@... writes:
<< It's such a hard  thing to do, that many solutions just use active
electronics instead of passive transformers. >>
Active balancing doesn't provide isolation, and quite often is not properly
balanced to provide true Common-Mode Rejection.  If you can afford them, GOOD
(Jensen) transformers are the way to go.
Ivan
2001-02-04 by J. Larry Hendry
If you are careful to match the input resistors can't you get
good common mode rejection with active balancing? Attached
is a small GIF with a schematic from Midwest Analog.  I notice
in the lower corner he makes note of the "subtle" challenges of making
this circuit referring to an article from Poly mag.  Anyone have
that article or would care to comment?
Having said all that, I normally use the pre-packaged transformers sold
by many of the microphone manufacturers that have the connectors
built onto a case with the transformer inside.  I even used the ones
RS sells and have no problem with them except the ground is tied
across so you have no "lift" switch.
Larry Hendry
is not properly balanced to provide true Common-Mode
Rejection.
Ivan
2001-02-04 by jhaible@t-online.de
No, you can't.
The circuit is ok for some applications, but there are two problems
(in addition to the lack of isolation that was already mentioned):
(1) The two opamp inputs show quite different behaviour in this
      circuit. One is a low impedance (near zero) summing node,
the other has high impedance (depending on the resistors used).
You have the choice between the opamp seeing different impedance
on both inputs (not optimal for bias currents, and for stray
capacitance, see point 2.) or the input having different impedance
for both branches (very bad - kills common mode suppression).
(2) Capacitance. Even when the circuit is perfectly balanced at
      low frequencies, it is certainly not for 1kHz or 10kHz.
      Stray capacitance is always there, and with different resistance
      on both branches even a symmetrcial layout with equal
      capacitance on both sides will result in different pole locations
      for the two inputs. So the circuit may be ok to suppress 50Hz
     (or 60Hz), bit not higher frequency common mode noise.
JH.
