Re: ring mod leakage
1999-07-11 by Paul Schreiber
>Now that I have VCOs (beautiful! amazing!) I have started patching allAgain, this subject has re-appeared again, so I will reiterate.
>kinds of neat stuff, and have noticed a few things about my older modules.
>Should I expect to be able to trim the MOTM-110 ring modulator to absolute
>silence with one input zeroed? I feed a high-C sine wave into X IN with X
>LEVEL at 10, Y LEVEL at 0, X and Y both AC-coupled, Y IN unconnected. By
>turning the X trimpot I can render the original sine wave nearly
>inaudible, but a frequency-doubled version appears at the output and
>cannot be trimmed away. Exchange X and Y, and the doubled wave is much
>louder (clearly audible at "reasonable" volume levels). In addition the
>output clips if I turn Y LEVEL past 9, but I guess this is to be expected
>(driving from a 300).
1) The MOTM-110 is specifically designed for LARGE signals. NOT guitars, NOT
the output
jacks of synths.
2) The best way to boost signals to be '110 happy are:
a) use the headphone output
b) use the SEND buss of a mixer
c) use a 'direct box'
d) gnash teeth while waiting for 1U triple pre-amp
3) ALL ring-mods have carrier leakage. The carrier "nulling" is input
amplitude *dependent*.
If you adjust the 2 trims pots at one level (say 2V pk-pk) then if you input
8V pk-pk the null
is greatly reduced. So, Rule #1 when setting the trimpots: use the largest
signal you plan to see.
Like, VCO outputs.
Also, the null amount is basically *not* all that great: say 30-35 dB down.
You *will* be able to hear that.
But, in general a good null point, coupled with enveloping BOTH X & Y
inputs, will keep the
*perceived* leakage to a minimum.
Of course, the UNBAlance control *adds* leakage!
4) Remember: the best RM sounds use a SINE or TRI wave for Y and the "audio"
into X. Shoving 2
presets into X & Y will get noisy fast! In fact, you may HEAR "extra noise"
coming out of the '110
which is the by-product of the RM.
5) The '110 has a *built-in* gain REDUCTION of 5. The reason: if you put in
2 5V pk signals, 5 * 5 /5 = 5V out
which is what we want.
You put in 2 1Vpk-pk signals, like the OUT of a synth, and you get out
(.5)(.5)/5 = 50mv = not much there!!!
Careful level adjustments plus proper nulling using the trimmers will get
you some great effects!
POP QUIZ!!!
Why is Chris seeing a "doubled" waveform??
