[motm] Blue case with MOTM modules
2001-01-26 by elhardt@aol.com
Just for completeness attached is a picture of my homemade blue case filled
with MOTM (now that my black screws arrived).
http://members.aol.com/elhardt/images/motmblue.jpg
RE: [motm] Blue case with MOTM modules
2001-01-26 by Tentochi
BEAUTIFUL!!!  Thanks for sharing the incredible us.  I hope Paul adds to the
web page with your permission.
Do you backwards mount your PSU?
It doesn't look like you have covers for the front and back; is this
correct?  If you do indeed have them, how do they attach?
Cheers!
Shemp
> -----Original Message-----
> From: elhardt@... [mailto:elhardt@...]
> Sent: Thursday, January 25, 2001 10:17 PM
> To: motm@egroups.com
> Subject: [motm] Blue case with MOTM modules
> case filled
Re: [motm] Blue case with MOTM modules
2001-01-27 by elhardt@aol.com
tentochi@... writes:
the web page with your permission.  Do you backwards mount your PSU?<<
Thanks for the compliments.  I was going to try to sell that blue case after
I built it for practice, but it looks so pretty I think I'll keep it.  And
yes, the PSU is mounted in the back of the case where it should be.
correct?  If you do indeed have them, how do they attach?<<
Since it's not actually meant ot be a shipped anywhere I have no front cover.
 In the back of the cases I will build there will either be a hinged door
that opens up for easy access to power connectors or just some kind of think
board that slips over some screws for the same purpose.  It will also help
keep the dust out.
-Elhardt
Re: Blue case with MOTM modules
2001-02-02 by GeorgeK
Very sharp!  Where did you get the color-coded plugs and wires?
case filled
