2001-01-21 by J. Larry Hendry
Thanks for this Dave. I will save this for when I get to my TM. As far as
current draw, yes I will publish it for the 831 and 822. As of today's
modifications (see private note I am about to hit the send button on) the
831 current has increased 4mA and the 822 has increased by 6mA. Both are
still in the under 20 mA range. I'll get the exact numbers out soon.
To: <motm@egroups.com>
Sent: Sunday, January 21, 2001 4:01 PM
Subject: [motm] Re: time machine LEDs / current draw (longwinded!)
Use the LUMEX LED, is my recommendation. Why go to all the trouble to
buy cool panels to make it look like MOTM, if you aren't gonna make
it look like MOTM<g>?
The Lumex LED should be set up to draw 8-10 mA, no more. It may be
capable of drawing more, but your power supply doesn't need the extra
load, it's plenty bright with 10 mA, and that's how Paul sets it up
in the official MOTM modules, so you may as well match it.
It has been my intention to put up a web page describing the MOTM
panel conversion, and give details about the bypass switch and the
LED resistor. I just haven't gotten around to it because I'm on a
mission to build two big wooden cases, come hell or high water,
before I do anything else.
<LONG WINDED TECHNICAL EXPLANATION>
An LED's current draw, hence brightness, is controlled by the
resistor from the LED's cathode to the voltage source. Looking at my
Time Machine schematic, the voltage source is the output of the opamp
on the first schemo page labelled U12d, which is configured as an
open loop comparator. NOTE: THERE IS A MISTAKE ON THE SCHEMATIC.
ALTHOUGH LABELLED U12d, IT'S ACTUALLY U12C. THE PIN NUMBERS ARE
CORRECT AS SHOWN. R36 controls the LED current. R37 and R38 form a
voltage divider between ground and V+ to provide a fixed 1.7V
reference voltage to the inverting input of the opamp. The input
signal feeds the noninverting input. Since the opamp is a very high
gain (10,000x or so) differential amplifier in the open loop
configuration, the output clips to the positive or negative supply
rail depending on whether the input signal is above the reference
voltage or below it. If the output is at the positive rail, current
can flow through R36 and the LED, illuminating it.
To calculate the current, we need to know the following: what is the
maximum output voltage of the opamp (the positive supply voltage for
U12), what voltage is the anode of the LED (terminal to the right on
the schemo) connected to, and what voltage is across the LED when
it's active. Then you can figure out what the voltage across R36 will
be, and hence the current through it. Using good old Ohm's law V/I = R
(where V is voltage across the resistor, I is current through the
resistor, and R is resistance), we plug in our known voltage and
desired current to calculate the resistance.
Referring to the schemo, the anode is connected to -15V, and the
positive supply rail for U12 is +15V. This is good news, because we
will be drawing a little more current than the stock LED. Some ICs
onboard the TM are powered from onboard regulators, and we would have
to be careful to avoid drawing too much extra current from them if
they powered this LED. Since your external supply powers this chip,
we are safe pulling a few extra milliamps. The LUMEX LED has about
1.5V across it when active (I've measured it). Analyzing the stock
circuit and assuming the same voltage drop across the stock LED, we
have a total voltage drop across the resistor of 30V - 1.5V = 28.5V.
Divide that by the current R36 resistance of 5600 and you get about
5.1 mA. We want 10 mA, so just about halving the resistance should do
the trick. 28.5/.010 = 2850, so a 2.7K to 3.3K resistor will do the
trick nicely.
</LONG WINDED TECHNICAL EXPLANATION>
<SHORT EXPLANATION>
Replace R36 with a 2.7K to 3.3K resistor.
</SHORT EXPLANATION>
Here's a general caveat about current capability - always, always
make sure your system power supply is capable of supplying the
current you need. It's best to have one loafing along at about 60% -
75% of capacity. If I have a system that requires 1A total, I'd be
comfortable with a supply that supplied 1.5A. It will run cooler and
more reliably. Very bad things will happen if you try to draw more
current than your supply can handle. Your lovely high-fi and stable
MOTM modules will perform like sh*t if they don't actually burn
components.
Larry, we need to make sure that as we come up with popular DIY
modules such as the 822 and 831, we provide a published current
rating for them as well!
Moe
> From: Cap'n F.M. Bleep <bleep@w...>
> hey there...
> the time machine is imminent! there's only one last detail to smooth
> out... which LED to use? the lumex leds that paul uses (like on the
320)
> draw 10 - 25 mA, but mr. blacet's led only draws 2, so a lumex
would be
> quite dim. (he suggested i use the supplied led with an led holder)
> how are you other time machine owners dealing with this? are you
cleverly
> placing a resistor somewhere? i'm not very clever with resistors...
> bleep.
> out.
