FW: [motm] I think I'm gonna arpeggiate
2001-01-03 by Tkacs, Ken
I love a good arpeggiator. I can't even begin to estimate the amount of man-hours that were killed in the 80's by my Korg Mono/Poly arpeggiator. But as a module... I'm not sure. To be as useful/fun as the Korg MP-4 unit, it would need to be flexible and controllable. The Korg arpegiator was "programmed" in real time by the scanned keyboard... how you would reasonably pull that off with CVs is not clear. Also, it may be that a mini-sequencer with CV or gate control of up/down/up-down, for instance, might do the same job but really be more of a flexible sequencer than an arpeggitor module. In the end, there may be more "modular" ways of doing a similar job. I have long been on a quest for a stable/flexible quantizer module. With that, you could feed in CV sweeps or the output from an S&H and get some arpeggiator-like effects. Sticking the lag between the S&H or an LFO and the quantizer would allow you various VC methods for shaping the curve and therefore the output of the quantizer, and so on. The subject is worth discussing.
-----Original Message----- From: sikorsky To: motm@egroups.com Sent: 01/02/2001 6:54 PM Subject: Re: [motm] I think I'm gonna throw up on topic comment: so no one liked the arpegiator module then..?
