More FINE Control
More FINE Control
2001-01-01 by thomas white
Hi guys,
What if you left the circuit alone and replaced the single turn "FINE"
potentiometer to a ten-turn pot? Then you could have all the fine control
you want within the 11 semitone range. Just an idea inspired by my old Paia
Fatman and my battles to get its 2 oscillators to avoid locking at close
frequency. Ha! Not a problem with my 300's I tell ya
Thomas White
Get your FREE download of MSN Explorer at http://explorer.msn.com
Re: [motm] More FINE Control
2001-01-03 by J. Larry Hendry
That is certainly an option.  The one thing that might complicate it
slightly is the fact that the fine pot IS on the board.  SO you would want
to be careful what kind of pot you selected so that it fit properly.
Or, you could SWAP the fine and course pot resistors so that these pots
changed function and then the pot would be off board so you could use any 10
turn pot you wished, and then hack up the front panel with some label maker
tape to reflect the change..... Nawww..  Just kiddin'.
In a very stooge like mode tonight.
To: <motm@egroups.com>
Sent: Monday, January 01, 2001 6:11 PM
Subject: [motm] More FINE Control
Hi guys,
Thomas White
