Panel Idea
1999-07-04 by Tentochi
Paul--
Thanks for designing the MOTM so that it fits in the SKB pop-up mixer case
so well. Too bad it isn't 15U. Actually none of the regular SKBs are
greater than 15U. Oh well. I just wish I could somehow protect the exposed
PCBs a bit more when the rack is popped up. Ideas?
I am currently using a Novation BassStation rack as my MIDI-to-CV
converter. To bring my connections to the front, I am using the incredible
Behringer patch panel. Really, the patch panel is overkill. What would be
great is when the MOTM-9X0 multi comes out, that it would have several
pass-throughs from the rear of the rack to allow CV, Gate, Trigger and
effects to be passed through. MIDI passthrough? The latter might be good
when you are using the MOTM in the SKB in fully reclined position.
On that note, what are the (heat) issues with leaving the SKB fully
reclined or leaving the rear cover on a full sized SKB when to full "racks"
of MOTM gear in installed and no empty spaces are left in the rack?
Thanks!
Todd
Thanks!
Todd
