Re: [motm] Re: NPN/PNP?
2000-12-07 by John E Blacet
With regard to that emitter arrow, a helpful mental trick is to think of
NPN as "Not Pointing iN" and PNP as "Pointing iN ...".
Regards.
John Blacet
Blacet Research Music Electronics
http://www.blacet.com
blacet@...
Are you on our mailing list?
http://www.blacet.com/mailform2.html
RE: [motm] NPN/PNP?
2000-12-07 by Tkacs, Ken
Transistors.
What do I win?
Sent:	Thursday, 07 December, 2000 3:25 PM
To:	motm@egroups.com
Subject:	[motm] NPN/PNP?
sorry, i know this has probably been covered but an archives search
didn't turn up any messages.
what is referred to by NPN/PNP?
thanks,
alex
NPN/PNP?
2000-12-07 by perpetual@uswest.net
thanks,
alex
RE: [motm] NPN/PNP?
2000-12-07 by Brousseau, Paul E (Paul)
You win... a drink from the fire hose!  <grin>
I believe the difference between NPN and PNP is the current flow direction
between the collector and emitter.  Unfortrunately, I can't find or recall
what the "N" and "P" stand for.  (It's not something as simple as positive
and negative, is it?)
--PBr
> -----Original Message-----
> From:	Tkacs, Ken [SMTP:ken.tkacs@...]
> Sent:	Thursday, December 07, 2000 12:23 PM
> To:	'motm@egroups.com'
> Subject:	RE: [motm] NPN/PNP?
> Transistors.
> What do I win?
> From: 	perpetual@... [mailto:perpetual@...]
Re: [motm] NPN/PNP?
2000-12-07 by Paul Schreiber
NPN = Negative-Positive-Negative
PNP = Positive-Negative-Positive
Transistors are 3 layers of silicon with added ions (called 'doping
impurities').
To: <motm@egroups.com>
Sent: Thursday, December 07, 2000 2:24 PM
> thanks,
> alex
Re: NPN/PNP?
2000-12-07 by Dave Bradley
As a practical matter, the electrical symbol for the NPN transistor
will show the emitter arrow pointing AWAY from the junction, while
the PNP will show the arrow pointing TO the junction. This coincides
with the direction of conventional (NOT electron) current flow.
Moe
> impurities').
> Paul S.
> From: <perpetual@u...>
search
> > thanks,
> > alex
Re: [motm] NPN/PNP?
2000-12-07 by J. Larry Hendry
And, to help you recognize them on schematics, the arrow points
away from the base on NPN (I remember it as Not-Pointed-iN)
Current flow is opposite the arrow direction.
Stooge Larry
Sent: Thursday, December 07, 2000 2:42 PM
Subject: Re: [motm] NPN/PNP?
impurities').
> thanks,
> alex
