Re: [motm] Future Utility Forum
2000-11-15 by CHRIS PARKER
Some utility functions I've thought about are: 1. Foot Pedal Interface 2. Fixed Voltage Source 3. Input/Output Jacks separated by Momentary Switches 4. Attenuators/Reversing Attenuators/Inverters Also, I recall each of the following being discussed on the list at one time or another: 1. Moog Ladder Filter 2. Voltage-Controlled DADSR Envelope Generator 3. Multi-mode Xpander Filter Anybody else have $0.02 to put into the mix? -Chris- >>> djthomaswhite@... 11/15/00 12:01PM >>> >Suggestions for others are welcome!-PS Thanks for the update Paul!!! This brings to mind a poll of useful utility modules to think about. The list has been a little quite and I know all of you have some opinions in this area so speak up! Paul has mentioned making these modules in the future so our information and voices will eventually be heard and some made into reality, exciting huh? I would like to see small 1u versions of the following functions (some can be combinations on one panel if there is room as well)... 1.Attenuator module with 0-10 attenuator and a reversible attenuator or two, maybe with an inverter on the bottom as well. 2.Alternate noise source (Dare I say Digital/Pseudo random?) 3.Small series of different ring-mod circuits if they really can sound as different as recently described on the list. 4.Clipper/Rectifier or maybe bigger module like Oakley Wavefolder 5.CV Buffer/Multiple module (One in buffer with 3 outs or so?) 6.Headphone monitoring module (Stereo/Mono) 7.Really dreaming here... 3u module with small power amp and 3" to 4" grilled speaker with input jack and volume attenuator, HA! Maybe a 4-6" oval speaker? Imagine 2 of these in the bottom corners of your plush wooden cabinet. Doing this one without a machine shop means cutting a big oval or circular hole into a 3u panel, YIKES!!! ARP 2600 Style 8. Simple LFO so I can stack them in my cabinet thick. Maybe a dual LFO in 1u with a knob for each frequency and 4 waveforms out per LFO? Well, thats just a few of my dreams. What about you? Stand up and be heard people, I know I'm curious. Far out shi* appreciated greatly Thomas White >If case everyone has forgotten, the modules planned (in no particular >order) >are: > >microVCO >AC/DC Mixer >SEM filter >dual VCA/Pan/Fade >Triple preamp (1U) >Envelope Follower/Compressor >VC'd Pulse Divider >some 1U utility modules (need a RM) >VC'd Phase Shifter (pretty complicated!) >delayed Vibrato > >Suggestions for others are welcome! _________________________________________________________________________ Get Your Private, Free E-mail from MSN Hotmail at http://www.hotmail.com. Share information about yourself, create your own public profile at http://profiles.msn.com.
