multiple construction?
2000-11-10 by perpetual@uswest.net
doing a couple MOTM kits and a bunch of cables has given me the
confidence to think that i could whip a frac-rack multiple panel up
with little trouble.  is there anything more to it than just wiring
one jack to another?  are there ground considerations?
thanks,
alex
Re: [motm] multiple construction?
2000-11-10 by J. Larry Hendry
just wiring one jack to another?
That's it.  Just tie all the hot lugs together.
Just tie those same grounds together.  Do not actually ground them.  Jyust
tie the 4 grounds together (for a 4 jack mult).
Larry H
P.S. Did you get my note about the TM panel.  You still have a few hours if
you are interested
