chaos patching
chaos patching
2000-11-01 by Nathan Alan Hunsicker
ok, ever since i got the rr patch sheet, i've been plugging everything i
can find into itself in very strange feedback loops. i'm getting some
really strange and uncontrollable results. my biggest fear is that i am
going to blow something up. will someone please assure me that this
isn't going to harm my system. what comes out sounds so cool (sometimes)
but i feel like i am abusing my modular. any thoughts? -nate
Re: [motm] chaos patching
2000-11-02 by Paul Schreiber
Won't harm MOTM, but, amps, tweeters, and stray cats are at risk.
To: "MOTM Newsgroup" <motm@egroups.com>
Sent: Wednesday, November 01, 2000 5:30 PM
Subject: [motm] chaos patching
2000-11-02 by jwbarlow@aol.com
I've always heard that you should never plug a VCA output into either of its
inputs -- this seems like very good advice and I (even me!) have always
followed it due to the obvious end in a positive feedback loop. A VCA
actually probably has some upper limit to prevent it from destroying itself
(anybody want to clarify that for me). But why chance it when you can spend
your time plugging everything else into itself.
Speaking of positive feedback, I was thinking of its destructive nature and
realized that it probably was similarly destructive to guitars. For example,
I have long used the technique of holding the guitar about a foot away form
the speaker (with the volume and treble up to 10 naturally) which results in
a squealing pitch (often referred to as Tele feedback when it happens in less
deliberate circumstances). The pitch can be changed by changing the distance
and orientation of the guitar as well as the tone controls and PU selector.
However, it occurred to me that what is actually going on, with the PU going
microphonic like this, is the PU vibrating itself to death. I try to do this
less often with my older guitars nowadays.
JB
In a message dated 11/1/2000 4:34:54 PM, nate@... writes:
>i
Re: chaos patching
2000-11-02 by doc pendergast
h3y jb,
 try leggin' the output of the vca into a mixer/attenuater(<-sp?)
first and then back out to the input on your vca with a lower signal
level.  it's easier to control the amount of feedback this way.
 as far as the PU vibratin' itself to death, i've always been under
the (¿)delusion(?)that it's the strings vibratin' themselves to
death, not the  PU.
 have you tried feedback with an ebow?  i use a '63 gretsch
tennessean into a reissue '65 twin with no outboard overdrive, reverb
at max o' course.  by adjustin' the vibrato settin' carefully, while
slowly bendin' the bigsby, one can achieve a most interestin'
auditory journey.  much more beautiful than fully distorted
feedback.  kinda synthy-like...(at least that's what the keyboard
player i was jammin' with said when he found out he wasn't makin'
that noise...)
peace,
doc
either of its
always
VCA
destroying itself
can spend
nature and
example,
away form
results in
happens in less
distance
selector.
PU going
to do this
> JB
Re: [motm] Re: chaos patching
In a message dated 11/1/2000 8:18:06 PM, doc@... writes:
Do you do this? I'm still not sure I want to risk either my ARP VCA, my MOTM
(or other CEM 3330) VCA, or my Serge (go ahead and put it on an O'scope, it
still sounds great to me!) UAP to try this.
>death, not the  PU.
Two different kinds of feedback, but no good way to discuss the difference.
String feedback, as you know, with moderately high volume and distances of a
few to several feet between the guitar and speaker.
If you turn the volume up even higher and stick the PUs right into the
speaker (as close as you can, up against the grill cloth) the guitar will
produce a shrill squealing -- like a microphone. If you are able to
experiment with this, you will find the strings play no effect and even
strumming them has little effect on the sound which is dominated by the PU
going microphonic -- the PU (or parts of it) are behaving as an oscillator.
Warning! This is most certainly damaging to the ears as well.
>feedback.
Great set up! I love Gretschs, and the Bigsby really adds something to them.
The Gretsch is definitely on my wish list! Yes, I've been using an E-bow on
and off for almost 20 years, and I agree that with delay and reverb, you can
get some great sounds. I often use it to get those Ligeti tone clouds.
However, similar to what I was saying about the squealing PU feedback shaking
the PUs apart, if you do that "Birdman" style of string feedback, you maybe
damaging a hollow body guitar as well since the amplifier is causing the
guitar to vibrate possibly at levels greater than 100% of its ability to
vibrate -- do you follow this?
Only two ours of sleep last night, having nothing to do with Halloween!
JB
