that special serge whatever..
2000-11-01 by Steve Maietta
paul,
care to shed some light about what exactly is going on in this scope
snapshot?
I follow the 1200hz squarewave in and then apply a  .5v to the cv in
to increase the amplitude.
Is it the fact that the wave no longer looks anything like a
squarewave, and that a VCA (obviously)shouldn't do that?(especially
not a 380 dollar one)
~Steve
Re: [motm] that special serge whatever..
2000-11-01 by Paul Schreiber
> paul,
> snapshot?
Er...that's my *point*!! :)
Maybe JH knows a good answer. I do know that the CA3280s used are kind of
strange.
Bernie Hutchins in Electronotes called them ' the most slippery ICs ever
designed", meaning
they have many undocumented...errr...."quirks".
2000-11-01 by J. Larry Hendry
slippery ICs ever designed", meaning they have many
Features !!  Remember Paul. These are undocumented "features."  People are
getting a built in buzz for their $$
LH
2000-11-02 by jhaible@t-online.de
Hmm, I will only comment on other's designs when I know a bit more about the
circuit.
One idea did strike me, however: In the common debate about "clean
and crisp" vs. "smooth" (attributes that are often adressed to Serge vs.
Moog,
just to name two examples) it's not necessarily the "smooth" circuit that is
adding something (like signal rounding, THD), but it might as well be the
"clean" one which shows the more serious artefacts.
> I do know that the CA3280s used are kind of strange.
But they are working well enough in Rev. 3 Prophet 5's.
> designed", meaning
I remember that - and it was Serge himself who helped to shed some light
on the then new LM13700 and CA3280 OTAs. If memory serves Serge
offered an explanation for the seemingly wrong design equations in
preceding EN issues. So in the context of that time and that EN
thread, it's fair to say that Serge was ahead of the others in understanding
that chip.
Not that *all* his conclusions would have been right, though. He also
proposed a scheme for the 13600 that allegedly would approximate
the current sources in theory (and resistors in real life) from the data
sheet better than the data sheet's own application circuits. The goal
was to improove the linearizing effect of the diodes. I once built
a circuit based on Serge's verbal description, and in fact it does
not improove the linearizing effect, but really performs on over-
compensation, thus bending the nonlinearity in the opposite direction.
It's J\ufffdrgen Bergfors's merit to find this out. I had published a
Morphing Programmer that used this circuit, and J\ufffdrgen measured it
and prooved it wrong.
Disclaimer: This is not a comment about Serge's production circuits, just
about a casual remark he had made in that EN article.
And that's all just good for anecdotes, IMO. If there really is a stability
problem with that particular Serge VCA, I doubt that it's a CA3280
problem.
The biggest "quirk" here in Europe is that CA3280's are practically
unavailable, and if so, just for a high price. That's why I stick to the
LM13700 family for simple applications, and lately I started to use
the BA6110 which apparently combines the benefits of the 3280
(real current sources and low noise) with the buffer of the 13700.
JH.
2000-11-03 by Tony Allgood
>... and lately I started to use the BA6110 which apparently combines
This is a superb OTA, but as with all good parts R-Ohm have now
discontinued it. Although stocks do remain moderately high right now.
3280s are available in the UK from Viewcom in Ilford, but are as Juergen
says, very pricey.
I would be interested to see what happens to a sinewave through that
Serge VCA at 1KHz and 10KHz. Its very odd that one sees so much ringing
with a square wave even with unterminated banana leads. In fact, it
would be hard to do that deliberately by bad layout alone. Perhaps it is
a deliberate design characteristic to create an 'exciting sound'. What's
the output do with no CV input I wonder, and does the overshoot get
worse with greater CV?
But I have just built a clone of the second stage of his Wave multiplier
(VCM) and that is very nice.
Tony Allgood  Penrith, Cumbria, England
Oakley Modular Synth and TB3030:
www.techrepairs.freeserve.co.uk/projects.htm
My music: www.mp3.com/taklamakan
2000-11-03 by Paul Schreiber
Although I no longer have the unit, I can say that the sine/tri waves don't
have this problem.
*Just guessing*, I think it is a combination of bad pcb layout (single-sided
pcb) and the
fact every IC is in cheap-o sockets.
Since no one got my hint: the root locus of the positive and negative
'spikes' are 60Hz amplitude
modulated. This introduces an overall huuuummmmm at these low CV settings.
At higher CV,
the spikes more or less disappear.
<Paul S>
