Patching Question
Patching Question
2000-10-07 by weld
I bought a used Doepler MAQ 16/3 yesterday (only until the MOTM is done, Paul
I swear  : )
Is the a way i can have the MAQ drive both of my  320 vco's ? I dont have any
mults yet, but may attempt to build something today if this is pretty easy.
Any suggestions?
Jim
Paul Schreiber wrote:
> The 1U mult is 4X4. I'm *guessing* $79, unless the labor is $$$ then $89.
> So far: MOTM-101 is leading by a 2:1 margin
> Paul S.
Re: [motm] Patching Question
2000-10-07 by Paul Schreiber
A mult is just sets of jacks wired in parallel.
a) connect the ground lugs together
b) connect the 'tip' lugs together
I use 'tinned buss wire' that is 20ga. But any wire should work. You can
also go to
RatShack and get a 'Y' cord.
To: <motm@egroups.com>
Sent: Saturday, October 07, 2000 8:27 AM
Subject: [motm] Patching Question
Paul
> I swear  : )
any
easy.
> Any suggestions?
> Jim
$89.
> > Paul S.
2000-10-07 by improv@peak.org
>I swear  : )
Hey, I love my MAQ, and when the MOTM comes out, I'll use it right next to
the MAQ. You can never ever have enough analog sequencers. That Future
Retro box is lookin mighty purty too...
>Any suggestions?
>Jim
I built a simple breakout panel that brings the CV outs of the MAQ to the
front, with 2 jacks for each of the CV and gates. Whoever decided to put
the CV jacks on the lower rear corner of the MAQ had to be stoned, it's the
most inconvenient spot possible, makes it impossible to use the box on a
tabletop. I wired each set of 2 jacks tip-to-tip and ring-to-ring, and then
attached a shielded cable to one of the jacks, with an 1/8" plug on the
end.
____________________________________________
Dave Trenkel : improv@...
Minus Web Site: http://listen.to/minusmusic
Minus MP3's: http://www.mp3.com/-minus-
2000-10-08 by James Holloway
James Holloway
jimh54@... - email
(972) 993-2023 x1188 - voicemail/fax
> done, Paul
> >I swear  : )
> next to
> have any
> easy.
> >Any suggestions?
> >Jim
> to the
> put
> it's the
> on a
> and then
> the
> end.
> If you bring out the gates and want a combined gate output so you can
have a 48 step sequence you should use diodes to keep them from loading
each other.
FREE voicemail, email, and fax...all in one place.
Sign Up Now! http://www.onebox.com
