Correction 2000-10-06 by Paul Schreiber The 1U mult is 4X4. I'm *guessing* $79, unless the labor is $$$ then $89. So far: MOTM-101 is leading by a 2:1 margin Paul S.
Correction 2002-11-05 by Paul Schreiber Hmmm...Micro Linear bailed on that product line.... I've used these as well: http://www.jrkerr.com/icprod.html These are pre-programmed PICs, you need an H-bridge IC driver or you can use 4 FETs. You step the bow back and forth with the CVs. Paul S.
